![]() | #4475 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2015 Location: INDIA Age: 34
Member: 2431049 Status: Offline Sonork: 100.1680262:hunnyck Thanks Meter: 966 | vivo v7 plus Format FS & FRP Reset Done Device : Vivo V7 Plus Operation : Format FS Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM4) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00000000 OPK_DATA : 30315EBED1DD09CEAAE927CAE0EE967076BC178CA33718DB4F FF8F02A0E7FAD2 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8953_003]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8953, eMMC, 64 GB LU Count : 1 [0x0747C000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : vivo vivo 1716 [msm8953] [msm8953_64] Software : OPM1.171019.026 release-keys, eng.compil.20191106.102945 [Wed Nov 6 10:29:45 CST 2019] Android Ver. : 8.1.0 Patch Level : 2019-11-01 Formatting userdata [SafeMode]...Done Resetting FRP Lock......Done Operation Finished. QcFire Ver. 5.0 |
The Following User Says Thank You to hunnyck For This Useful Post: |
![]() | #4476 (permalink) |
![]() | #4477 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Jul 2008 Location: Bangladesh
Member: 821462 Status: Offline Thanks Meter: 833 | symphony i21 FRP Remove Done Port : Fastboot Interface Baud Rate : Not Applicable Device : Generic Operation : Huawei SPD FRP Reset Searching for Device in FastBoot Mode... OK Reading Information... OK FastBoot Ver. : 1.0 Product Bootloader : Locked Bootloader is Locked. FRP Reset may fail! Removing FRP Lock... Done Operation Finished. Elapsed Time: 00:14 [Module Ver. 5.3] Log Saved to Logs\191128_124633.log |
![]() | #4478 (permalink) |
![]() | #4479 (permalink) |
No Life Poster ![]() ![]() ![]() ![]() ![]() Join Date: Mar 2019 Location: saturn
Member: 2901996 Status: Offline Thanks Meter: 917 | Nokia 2.2 TA-1183 FORMAT FS+FRP reset Done By UMT MTK Tool BOOT KEY: press both vol keys Format Fs: ![]() Code: Operation : Format FS CPU : MT6761 Storage : EMMC DA : Nokia 2.2 DA_UMT.bin [MTK_AllInOne_DA_v3.3001.2018/08/21.13:52] Using Custom DA! Qt: Untested Windows version 6.2 detected! Waiting for Phone in BROM Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1632 (COM73) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Data missing! Can not read information! Could not read specified bytes. Userdata is ENCRYPTED Formatting userdata... - Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 2.4] ![]() Regards |
![]() | #4480 (permalink) |
![]() | #4481 (permalink) |
Banned ![]() ![]() ![]() ![]() ![]() ![]() Join Date: Oct 2017 Location: pakistan kpk mansehra Age: 26
Member: 2765424 Status: Offline Thanks Meter: 1,039 ![]() | haier leisure l7 after flash dead haier leisure l7 after flash dead ![]() : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM79) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1F00400 [8937] 00000000 OPK_DATA : 9CBA94693C2333A562BCF0E0E981C558748817D002F543B2A2 6AB1B4B3F1CF9E Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8937]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : 8937, eMMC, 32 GB LU Count : 1 [0x03A3E000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 1048576, Sector Size: 512 Writing [NON-HLOS.bin] -> [modem] ...Done Writing [sbl1.mbn] -> [sbl1] ...Done Writing [sbl1.mbn] -> [sbl1bak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [adspso.bin] -> [dsp] ...Done [PROTECTIVE_FLASH] Skipping [dummy.bin] -> [modemst1] [PROTECTIVE_FLASH] Skipping [dummy.bin] -> [modemst2] Writing [fs_image.tar.gz.mbn.img] -> [fsg] ...Done Writing [sec.dat] -> [sec] ...Done Writing [splash.img] -> [splash] ...Done Writing [emmc_appsboot.mbn] -> [aboot] ...Done Writing [emmc_appsboot.mbn] -> [abootbak] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [system_1.img] -> [system] ...Done Writing [system_2.img] -> [system] ...Done Writing [system_3.img] -> [system] ...Done Writing [system_4.img] -> [system] ...Done Writing [system_5.img] -> [system] ...Done Writing [system_6.img] -> [system] ...Done Writing [system_7.img] -> [system] ...Done Writing [system_8.img] -> [system] ...Done Writing [system_9.img] -> [system] ...Done Writing [system_10.img] -> [system] ...Done Writing [system_11.img] -> [system] ...Done Writing [system_12.img] -> [system] ...Done Writing [system_13.img] -> [system] ...Done Writing [system_14.img] -> [system] ...Done Writing [system_15.img] -> [system] ...Done Writing [system_16.img] -> [system] ...Done Writing [system_17.img] -> [system] ...Done Writing [system_18.img] -> [system] ...Done Writing [system_19.img] -> [system] ...Done Writing [system_20.img] -> [system] ...Done Writing [system_21.img] -> [system] ...Done Writing [system_22.img] -> [system] ...Done Writing [system_23.img] -> [system] ...Done Writing [system_24.img] -> [system] ...Done Writing [system_25.img] -> [system] ...Done Writing [system_26.img] -> [system] ...Done Writing [system_27.img] -> [system] ...Done Writing [system_28.img] -> [system] ...Done Writing [system_29.img] -> [system] ...Done Writing [system_30.img] -> [system] ...Done Writing [system_31.img] -> [system] ...Done Writing [system_32.img] -> [system] ...Done Writing [system_33.img] -> [system] ...Done Writing [system_34.img] -> [system] ...Done Writing [system_35.img] -> [system] ...Done Writing [system_36.img] -> [system] ...Done Writing [system_37.img] -> [system] ...Done Writing [system_38.img] -> [system] ...Done Writing [system_39.img] -> [system] ...Done Writing [system_40.img] -> [system] ...Done Writing [cache_1.img] -> [cache] ...Done Writing [cache_2.img] -> [cache] ...Done Writing [cache_3.img] -> [cache] ...Done Writing [persist_1.img] -> [persist] ...Done Writing [rootm.mbn] -> [rootm] ...Done Writing [sysinfo.img] -> [sysinfo] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [userdata_1.img] -> [userdata] ...Done Writing [userdata_2.img] -> [userdata] ...Done Writing [userdata_3.img] -> [userdata] ...Done Writing [userdata_4.img] -> [userdata] ...Done Writing [userdata_5.img] -> [userdata] ...Done Writing [userdata_6.img] -> [userdata] ...Done Writing [userdata_7.img] -> [userdata] ...Done Writing [userdata_8.img] -> [userdata] ...Done Writing [userdata_9.img] -> [userdata] ...Done Writing [userdata_10.img] -> [userdata] ...Done Writing [userdata_11.img] -> [userdata] ...Done Writing [userdata_12.img] -> [userdata] ...Done Writing [userdata_13.img] -> [userdata] ...Done Writing [userdata_14.img] -> [userdata] ...Done Writing [userdata_15.img] -> [userdata] ...Done Writing [userdata_16.img] -> [userdata] ...Done Writing [userdata_17.img] -> [userdata] ...Done Writing [userdata_18.img] -> [userdata] ...Done Writing [userdata_19.img] -> [userdata] ...Done Writing [userdata_20.img] -> [userdata] ...Done Writing [userdata_21.img] -> [userdata] ...Done Writing [userdata_22.img] -> [userdata] ...Done Writing [userdata_23.img] -> [userdata] ...Done Writing [userdata_24.img] -> [userdata] ...Done Writing [userdata_25.img] -> [userdata] ...Done Writing [userdata_26.img] -> [userdata] ...Done Writing [userdata_27.img] -> [userdata] ...Done Writing [userdata_28.img] -> [userdata] ...Done Writing [userdata_29.img] -> [userdata] ...Done Writing [userdata_30.img] -> [userdata] ...Done Writing [userdata_31.img] -> [userdata] ...Done Writing [userdata_32.img] -> [userdata] ...Done Writing [userdata_33.img] -> [userdata] ...Done Writing [userdata_34.img] -> [userdata] ...Done Writing [userdata_35.img] -> [userdata] ...Done Writing [userdata_36.img] -> [userdata] ...Done Writing [userdata_37.img] -> [userdata] ...Done Writing [userdata_38.img] -> [userdata] ...Done Writing [userdata_39.img] -> [userdata] ...Done Writing [userdata_40.img] -> [userdata] ...Done Writing [userdata_41.img] -> [userdata] ...Done Writing [userdata_42.img] -> [userdata] ...Done Writing [userdata_43.img] -> [userdata] ...Done Writing [userdata_44.img] -> [userdata] ...Done Writing [userdata_45.img] -> [userdata] ...Done Writing [userdata_46.img] -> [userdata] ...Done Writing [userdata_47.img] -> [userdata] ...Done Writing [userdata_48.img] -> [userdata] ...Done Writing [userdata_49.img] -> [userdata] ...Done Writing [userdata_50.img] -> [userdata] ...Done Writing [userdata_51.img] -> [userdata] ...Done Writing [userdata_52.img] -> [userdata] ...Done Writing [userdata_53.img] -> [userdata] ...Done Writing [userdata_54.img] -> [userdata] ...Done Writing [userdata_55.img] -> [userdata] ...Done Writing [userdata_56.img] -> [userdata] ...Done Writing [userdata_57.img] -> [userdata] ...Done Writing [userdata_58.img] -> [userdata] ...Done Writing [userdata_59.img] -> [userdata] ...Done Writing [userdata_60.img] -> [userdata] ...Done Writing [userdata_61.img] -> [userdata] ...Done Writing [userdata_62.img] -> [userdata] ...Done Writing [userdata_63.img] -> [userdata] ...Done Writing [userdata_64.img] -> [userdata] ...Done Writing [userdata_65.img] -> [userdata] ...Done Writing [userdata_66.img] -> [userdata] ...Done Writing [userdata_67.img] -> [userdata] ...Done Writing [userdata_68.img] -> [userdata] ...Done Writing [userdata_69.img] -> [userdata] ...Done Writing [userdata_70.img] -> [userdata] ...Done Writing [userdata_71.img] -> [userdata] ...Done Writing [userdata_72.img] -> [userdata] ...Done Writing [userdata_73.img] -> [userdata] ...Done Writing [userdata_74.img] -> [userdata] ...Done Writing [userdata_75.img] -> [userdata] ...Done Writing [userdata_76.img] -> [userdata] ...Done Writing [userdata_77.img] -> [userdata] ...Done Writing [userdata_78.img] -> [userdata] ...Done Writing [userdata_79.img] -> [userdata] ...Done Writing [userdata_80.img] -> [userdata] ...Done Writing [userdata_81.img] -> [userdata] ...Done Writing [userdata_82.img] -> [userdata] ...Done Writing [userdata_83.img] -> [userdata] ...Done Writing [userdata_84.img] -> [userdata] ...Done Writing [userdata_85.img] -> [userdata] ...Done Writing [userdata_86.img] -> [userdata] ...Done Writing [userdata_87.img] -> [userdata] ...Done Writing [userdata_88.img] -> [userdata] ...Done Writing [userdata_89.img] -> [userdata] ...Done Writing [userdata_90.img] -> [userdata] ...Done Writing [userdata_91.img] -> [userdata] ...Done Writing [userdata_92.img] -> [userdata] ...Done Writing [userdata_93.img] -> [userdata] ...Done Writing [userdata_94.img] -> [userdata] ...Done Writing [userdata_95.img] -> [userdata] ...Done Writing [userdata_96.img] -> [userdata] ...Done Writing [userdata_97.img] -> [userdata] ...Done Writing [userdata_98.img] -> [userdata] ...Done Writing [userdata_99.img] -> [userdata] ...Done Writing [userdata_100.img] -> [userdata] ...Done Writing [userdata_101.img] -> [userdata] ...Done Writing [userdata_102.img] -> [userdata] ...Done Writing [userdata_103.img] -> [userdata] ...Done Writing [userdata_104.img] -> [userdata] ...Done Writing [userdata_105.img] -> [userdata] ...Done Writing [userdata_106.img] -> [userdata] ...Done Writing [userdata_107.img] -> [userdata] ...Done Writing [userdata_108.img] -> [userdata] ...Done Writing [userdata_109.img] -> [userdata] ...Done Writing [userdata_110.img] -> [userdata] ...Done Writing [userdata_111.img] -> [userdata] ...Done Writing [userdata_112.img] -> [userdata] ...Done Writing [userdata_113.img] -> [userdata] ...Done Writing [userdata_114.img] -> [userdata] ...Done Writing [userdata_115.img] -> [userdata] ...Done Writing [userdata_116.img] -> [userdata] ...Done Writing [userdata_117.img] -> [userdata] ...Done Writing [userdata_118.img] -> [userdata] ...Done Writing [userdata_119.img] -> [userdata] ...Done Writing [userdata_120.img] -> [userdata] ...Done Writing [userdata_121.img] -> [userdata] ...Done Writing [userdata_122.img] -> [userdata] ...Done Writing [userdata_123.img] -> [userdata] ...Done Writing [userdata_124.img] -> [userdata] ...Done Writing [userdata_125.img] -> [userdata] ...Done Writing [userdata_126.img] -> [userdata] ...Done Writing [userdata_127.img] -> [userdata] ...Done Writing [userdata_128.img] -> [userdata] ...Done Writing [userdata_129.img] -> [userdata] ...Done Writing [userdata_130.img] -> [userdata] ...Done Writing [userdata_131.img] -> [userdata] ...Done Writing [userdata_132.img] -> [userdata] ...Done Writing [userdata_133.img] -> [userdata] ...Done Writing [userdata_134.img] -> [userdata] ...Done Writing [userdata_135.img] -> [userdata] ...Done Writing [userdata_136.img] -> [userdata] ...Done Writing [userdata_137.img] -> [userdata] ...Done Writing [userdata_138.img] -> [userdata] ...Done Writing [userdata_139.img] -> [userdata] ...Done Writing [userdata_140.img] -> [userdata] ...Done Writing [userdata_141.img] -> [userdata] ...Done Writing [userdata_142.img] -> [userdata] ...Done Writing [userdata_143.img] -> [userdata] ...Done Writing [userdata_144.img] -> [userdata] ...Done Writing [userdata_145.img] -> [userdata] ...Done Writing [userdata_146.img] -> [userdata] ...Done Writing [userdata_147.img] -> [userdata] ...Done Writing [userdata_148.img] -> [userdata] ...Done Writing [userdata_149.img] -> [userdata] ...Done Writing [userdata_150.img] -> [userdata] ...Done Writing [userdata_151.img] -> [userdata] ...Done Writing [userdata_152.img] -> [userdata] ...Done Writing [userdata_153.img] -> [userdata] ...Done Writing [userdata_154.img] -> [userdata] ...Done Writing [userdata_155.img] -> [userdata] ...Done Writing [userdata_156.img] -> [userdata] ...Done Writing [userdata_157.img] -> [userdata] ...Done Writing [userdata_158.img] -> [userdata] ...Done Writing [userdata_159.img] -> [userdata] ...Done Writing [userdata_160.img] -> [userdata] ...Done Writing [userdata_161.img] -> [userdata] ...Done Writing [userdata_162.img] -> [userdata] ...Done Writing [userdata_163.img] -> [userdata] ...Done Writing [userdata_164.img] -> [userdata] ...Done Writing [userdata_165.img] -> [userdata] ...Done Writing [userdata_166.img] -> [userdata] ...Done Writing [userdata_167.img] -> [userdata] ...Done Writing [userdata_168.img] -> [userdata] ...Done Writing [userdata_169.img] -> [userdata] ...Done Writing [userdata_170.img] -> [userdata] ...Done Writing [userdata_171.img] -> [userdata] ...Done Writing [userdata_172.img] -> [userdata] ...Done Writing [userdata_173.img] -> [userdata] ...Done Writing [userdata_174.img] -> [userdata] ...Done Writing [userdata_175.img] -> [userdata] ...Done Writing [userdata_176.img] -> [userdata] ...Done Writing [userdata_177.img] -> [userdata] ...Done Writing [userdata_178.img] -> [userdata] ...Done Writing [userdata_179.img] -> [userdata] ...Done Writing [userdata_180.img] -> [userdata] ...Done Writing [userdata_181.img] -> [userdata] ...Done Writing [userdata_182.img] -> [userdata] ...Done Writing [userdata_183.img] -> [userdata] ...Done Writing [userdata_184.img] -> [userdata] ...Done Writing [userdata_185.img] -> [userdata] ...Done Writing [userdata_186.img] -> [userdata] ...Done Writing [userdata_187.img] -> [userdata] ...Done Writing [userdata_188.img] -> [userdata] ...Done Writing [userdata_189.img] -> [userdata] ...Done Writing [userdata_190.img] -> [userdata] ...Done Writing [userdata_191.img] -> [userdata] ...Done Writing [userdata_192.img] -> [userdata] ...Done Writing [userdata_193.img] -> [userdata] ...Done Writing [userdata_194.img] -> [userdata] ...Done Writing [userdata_195.img] -> [userdata] ...Done Writing [userdata_196.img] -> [userdata] ...Done Writing [userdata_197.img] -> [userdata] ...Done Writing [userdata_198.img] -> [userdata] ...Done Writing [userdata_199.img] -> [userdata] ...Done Writing [userdata_200.img] -> [userdata] ...Done Writing [userdata_201.img] -> [userdata] ...Done Writing [userdata_202.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 5.0 |
![]() | #4482 (permalink) |
Junior Member ![]() Join Date: Jun 2017
Member: 2729872 Status: Offline Thanks Meter: 4 | Xiaomi MI 6 Mi Account Remove Operation : Disable Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM74) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1E00500 [8998] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8998_002]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, UFS, 64 GB LU Count : 6 [0x00D40800] [0x00000800] [0x00000800] [0x00008000] [0x00194000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi MI 6 [msm8998] [sagit] Software : OPR1.170623.027, V10.3.4.0.OCAMIXM [Mon May 27 21:17:58 CST 2019] Android Ver. : 8.0.0 Patch Level : 2019-03-01 Reading Data... Preparing Data...Done Trying to Disable Mi Account...Done Operation Finished. QcFire Ver. 5.0 Remove FRP Device : Xiaomi Mi 6 Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM74) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1E00500 [8998] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8998_002]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, UFS, 64 GB LU Count : 6 [0x00D40800] [0x00000800] [0x00000800] [0x00008000] [0x00194000] [0x00008000] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi MI 6 [msm8998] [sagit] Software : OPR1.170623.027, V10.3.4.0.OCAMIXM [Mon May 27 21:17:58 CST 2019] Android Ver. : 8.0.0 Patch Level : 2019-03-01 Resetting FRP Lock.......Done Operation Finished. QcFire Ver. 5.0 Finally Anti Relock Operation : Mi Anti Relock Checking for device in ADB mode...Found! Searching for Device in ADB Mode...Found Brand : Xiaomi Model : MI 6 Product : sagit Device : sagit Andriod Ver. : 8.0.0 Patch Level : 2019-03-01 Bootloader : unknown Build ID : OPR1.170623.027 Build Date : Mon May 27 21:17:58 CST 2019 Disabling Mi Account Relock...Verified OK... Done Operation Finished. QcFire Ver. 5.0 |
![]() | #4483 (permalink) |
Freak Poster ![]() ![]() ![]() ![]() Join Date: Jun 2009
Member: 1051138 Status: Offline Sonork: 123456 Thanks Meter: 382 | oppo a5s hard reset done Operation : Factory Reset (New) Checking for existing META ports... Found MediaTek USB VCOM (Android) (COM30) on COM30 Device Path : usb\vid_0e8d&pid_200e&rev_0409&mi_01 Configuring Communication Channel... Reading phone information... CPU : MT6765 SW Ver. : MOLY.LR12A.R2.TC16.SP.V50.5.P80 HW Ver. : OPPO_O1MP6_K65V1_64_BSP_HW Starting Factory Reset... Reset success Operation finished [UltimateMTK Ver. 2.3] |
