02-12-2021, 19:51 | #1 (permalink) |
No Life Poster Join Date: May 2000 Location: Bacau, Romania Age: 50
Member: 1447 Status: Offline Thanks Meter: 97 | realmi rmx2030 restart after umt module Is need full flash? Opening Device...Done Physical Details: Chip Size : 0xE8F800000 [58.24 GB] Sector Size : 0x0200 Sector Count : 0x0747C000 Reading Partition Data...OK Header Rev. : 0x00010000 Header Size : 0x5C Header CRC : 0x12337CB0 Current LBA : 0x00000001 Backup LBA : 0x0747BFFF First LBA : 0x00000022 Last LBA : 0x0747BFDE PIT Entry Size : 0x80 Disk GUID : FCE2CEDD43DB0A37BDB997C24D906E99 Sector Size : 0x0200 Parsing Partition Entries...OK Part Count : 69 Reading Device Information...OK Device : realme Android Ver. : 9 Formatting Userdata in Safe Mode...Done Turn on device to finalize operation. Operation Finished. Disabling Screen Locks...Done Operation Finished. |
02-13-2021, 07:05 | #4 (permalink) |
Member: 1447 Status: Offline Thanks Meter: 97 | Yes, already tryed but no success, still restart. Need another soluion, maybe software. In Recovery, is posibility to update from WIFI, but no network is discovered, like qcn is erased. Pls sugestion. TNX Cris |
02-17-2021, 10:41 | #6 (permalink) |
Member: 1447 Status: Offline Thanks Meter: 97 | Now I'm fix the interface, the 1.8 VCCQ has 3 Volts , not 1.8 , solved with 2 diodes in series, and after that use pullup 200 ohms resistors like in Internet picture for isp fix. The interface is good and connection with motherboard OK. In another topics, realmi restart was from altered userdata.img, after disable lock buton. Is safe to write Firmware with umt 0.3? Anybody succede it? Is firmware for RMX2030 in support, from original .ofp file. Tnx, Cris P..S. read is very slow...maybe 2-3 hours for entire disk |
02-17-2021, 20:12 | #7 (permalink) |
Member: 1447 Status: Offline Thanks Meter: 97 | try to write...error Opening Device...Done Physical Details: Chip Size : 0xC600C600 [3.09 GB] Sector Size : 0x0200 Sector Count : 0x00630063 Reading Partition Data...OK Header Rev. : 0x00010000 Header Size : 0x5C Header CRC : 0xA964419D Current LBA : 0x00000001 Backup LBA : 0x0747BFFF First LBA : 0x00000022 Last LBA : 0x0747BFED PIT Entry Size : 0x80 Disk GUID : FCE2CEDD43DB0A37BDB997C24D906E99 Sector Size : 0x0200 Parsing Partition Entries...OK Part Count : 129 Reading Device Information...OK Device : realme Android Ver. : 9 Nothing selected, please select a partition. [SPARSE] Writing partition [userdata]...Write Error!Failed Operation Failed. any support? |
