05-04-2021, 06:19 | #1 (permalink) |
No Life Poster Join Date: Oct 2007 Location: Bangladesh
Member: 621121 Status: Offline Thanks Meter: 366 | Redmi 9 Userdata not detected! Code: Operation : MTK One Click Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM8 Port Name: MediaTek USB Port_V1633 (COM8) Path: \\?\usb#vid_0e8d&pid_0003#6&944c330&0&4#{86e0d1e0-8089-11d0-9ce4-08003e301f73} Chipset: 0x0707, [MT6768] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM8) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Executing Flashing Task... Syncing with Target... Reading Partition Table... Storage : eMMC Data missing! Could not read information! Data missing! Could not read extended information! Userdata not detected! Seeking Userdata... - Not Found! Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
05-04-2021, 13:33 | #3 (permalink) |
Member: 621121 Status: Offline Thanks Meter: 366 | see log here Brand : Xiaomi Model : Redmi 9 Operateion : SafeFormat Connection Mode : BROM (Hold Key for BROM Mode) Hold VOL UP + DOWN and connect USB Cable. Some phone may have different key combination for BROM mode. Waiting for device in BROM mode... Port: COM8 Port Name: MediaTek USB Port_V1633 (COM8) Path: \\?\usb#vid_0e8d&pid_0003#6&944c330&0&4#{f9f3ff14-ae21-48a0-8a25-8011a7a931d9} Chipset: 0x0707, [MT6768] Hardware Info: 0x8A00, 0xCA00, 0x00 SecureBoot: True SLA: True DA Auth: True Disabling WatchDog... - Success Sending Payload data... - Payload sent Initiating Control Transfer... - Done Waiting for result... - Result: 0xA1A2A3A4 Disable Auth Success Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek USB Port_V1633 (COM8) Connect BROM failed: STATUS_SCATTER_HW_CHIP_ID_MISMATCH(-1073545201) Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 4.2] |
