07-01-2021, 19:08 | #1 (permalink) |
No Life Poster Join Date: Dec 2010 Location: saqez - iran
Member: 1474571 Status: Offline Sonork: 100.1614377 Thanks Meter: 72 | redmi note 6 pro not done frp why ? Code: Device : Xiaomi Redmi Note 6 Pro Operation : Reset FRP Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZpY2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVzcG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...Not Found! DebugData : BAAAABAAAAANAAAAAQAAAA== Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.9 Last edited by sagez gsm1; 07-01-2021 at 19:16. |
07-01-2021, 21:57 | #3 (permalink) |
Freak Poster Join Date: Sep 2016 Location: Earth
Member: 2620603 Status: Offline Thanks Meter: 40 | https://disk.yandex.ru/d/rVfWPPMDJdFBCw use this loader |
The Following User Says Thank You to red5ive For This Useful Post: |
07-01-2021, 22:27 | #4 (permalink) | |
Member: 1474571 Status: Offline Sonork: 100.1614377 Thanks Meter: 72 | Quote:
Code: Operation : Reset FRP Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8bG9nIHZhbHVlPSJTaWduYXR1cmUgVmVyaWZpY2F0aW9uIEZhaWxlZCIvPgo8L2RhdGE+PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID8+CjxkYXRhPgo8cmVzcG9uc2UgdmFsdWU9Ik5BSyIgLz4KPC9kYXRhPn== Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTQ2NkI0MjQxNDE0MTQxNDE1MTQzNDE2NzQ4NzY1MDM3NjM3NTZFNzE1MjY0NTM2QjRGMzU0QjQ2MzA0RDQzNjg3Nz== User declined using UMT Server. Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.9 | |
