Go Back   GSM-Forum > Product Support Sections > Hard/Software Products (official support) > Ultimate Multi Tool Box
Ultimate Multi Tool Box Multi GSM & CDMA Box
Old 02-21-2021, 01:54   #1 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 160
redmi note 9 pro joyeuse remover mi account?''
I would like to know if it is possible to remove my account from the redmi note 9 pro joyeuse because it is supposedly supported by umt but none of the operations is successful.
Checking for existing devices...Found
Port : Qualcomm HS-USB QDLoader 9008 (COM20)
Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7
Opening Port...OK
Init Handshake Sequence...OK
Hardware ID : E1901400 [SM6250] 00007200
OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7
Initializing Protocol...OK
Sending Loader [prog_ufs_firehose_sm6250_ddr.elf]...Done
Executing Loader...OK
Auth Enabled Device! You need Mi Auth Account to service!
Skipping Auth...Failed
Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+
Reading Auth Blob...OK
Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0MTY5NzY2RjQ3NUY0QjYzMz c0NzY0MkQ1NzQ0MzY2MzYzNkE3MzM5NTg2RjRBNEYzNjQ3NjQ3 Nz==
User declined using UMT Server.
Storage Initializaton Failed!
Please use correct loader and check USB port / cable.
QcFire Ver. 6.5
Device : Xiaomi Redmi Note 9 Pro
Operation : Reset Mi Account
Opening Port...OK
Using Auto Loader Selection [1]
Preparing Loader...Done
Sending Loader [SM6250]...Done
Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0MTY5NzY2RjQ3NUYzOTZGND g2OTU0NkI2RjUzNjk1ODRGMzc0NzYzMzY1RjY1NzYzMzc2NUE2 N0==
Requesting UMT Server for Auth Data...SERVER_TEMPORARY_OFFLINE
Operation Finished.
QcFire Ver. 6.5
Old 02-21-2021, 05:28   #2 (permalink)
U.M.T's Avatar
Member: 2465108
Sonork: No More Used
Thanks Meter: 13,432
This phone requires Auth for anything in EDL mode.
If you have Mi Service Account, you can use that to service this phone.
Br,
UMT
The Following 2 Users Say Thank You to U.M.T For This Useful Post:
Old 02-22-2021, 00:14   #3 (permalink)
Member: 381487
Sonork: 100.1659930
Thanks Meter: 160
Br,
UMT
So your server has been off for a long time and I have credits that I am not going to use at the moment. So what is the function that umt supports with this Xiaomi note 9 pro, that you in an update say that it supports it.
The Following User Says Thank You to alexis_01 For This Useful Post:
Old 02-22-2021, 15:34   #4 (permalink)
U.M.T's Avatar
Member: 2465108
Yes, it is supported, subject to use of Authorization, whether you agree or not, some people who have own Service Account access use it.
Br,
UMT
Page generated in 0.13401 seconds with 8 queries
