10-28-2021, 07:39 | #1 (permalink) |
No Life Poster Join Date: Jul 2002 Location: Bucharest-Romania Age: 51
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | Samsung A02S [A025G] FRP solution? I have Samsung A025G with last security i try many manual solution but not work. I decided to reset FRP via test point but not work.... Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM26) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00002000 OPK_DATA : 8E3783B953129FB7E6FEC9EF1E855079B47690DBE55C27B893 4BC011292B39CE Initializing Protocol...OK Using Auto Loader Selection [3] Device may possibly not boot with this loader. Preparing Loader...Done Sending Loader [8953_036]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.3 Its any solution for this phone? Thanxs! BR! |
11-01-2021, 05:56 | #4 (permalink) |
No Life Poster Join Date: May 2001 Location: Bulgaria Age: 56
Member: 4627 Status: Offline Sonork: 57528:debeliamark Thanks Meter: 1,034 | @george_gsm Try to use SDM450 noAuth loader for A025G and repeat operation. |
11-01-2021, 08:25 | #5 (permalink) | |
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | Quote:
Thanx for your help! but still not work with this loader Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port : Qualcomm HS-USB QDLoader 9008 (COM26) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1A00900 [8953] 00002000 OPK_DATA : 8E3783B953129FB7E6FEC9EF1E855079B47690DBE55C27B893 4BC011292B39CE Initializing Protocol...OK Sending Loader [prog_emmc_firehose_8953_ddr.mbn]...Write Error! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 7.3 BR! | |
11-01-2021, 10:22 | #8 (permalink) |
Member: 14200 Status: Offline Sonork: Sonork id Thanks Meter: 117 | yes. i try. but in last security patch you can't install anymore Quick Shortcut Maker and Alliance Shield X or any app. phone don't allow to transfer any apps via Smart Switch or from samsung account backup. not work with android hidden settings or any trick. if any one have solution...? please share with us! BR! |
11-02-2021, 11:25 | #9 (permalink) | |
No Life Poster Join Date: Apr 2005 Location: America
Member: 138781 Status: Offline Thanks Meter: 850 | Quote:
https://forum.gsmhosting.com/vbb/f97...-king-2993081/ tested | |
12-11-2021, 15:27 | #11 (permalink) |
No Life Poster Join Date: Apr 2004 Location: Skopje , Macedonia Age: 40
Member: 61851 Status: Offline Sonork: 100.1604862 Thanks Meter: 117 | Alliance Shield X is not working cause phone doesn't have knox i do not know why anyone got an idea how to enable knox or work profile , maybe we can do it that way |
The Following User Says Thank You to iki For This Useful Post: |
