04-29-2024, 08:20 | #1 (permalink) |
No Life Poster Join Date: May 2016 Location: Not Found...
Member: 2572504 Status: Offline Sonork: No More Use Thanks Meter: 441 | samsung a057f kg lock need help here is log Device : Samsung Galaxy A05s (SM-A057F) BIT2 Operation : Samsung KG Bypass Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. SAMSUNG : Turn Off phone, hold EDL Cable Button and insert to phone and press VOL DOWN + POWER on phone more than 3 times rapidly and then leave EDL Cable Button. Found Port : Qualcomm HS-USB QDLoader 9008 (COM42) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...Ignored Init Handshake Sequence...OK Hardware ID : E1801B00 [SM6225] 00002000 OPK_DATA : FE7A96F970CD7CE54D0256497B57539B3E3CBD084E89403B54 C5B4506C905ECD Initializing Protocol...OK Using Pre-Defined Loader [SM-A057F_BIT2_001.ufl] Preparing Loader...Done Sending Loader [SM-A057F_BIT2_001]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SM6225, UFS, 128 GB LU Count : 6 [0x01DA8C00] [0x00000800] [0x00000800] [0x00000400] [0x00020000] [0x00000800] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK [Sign] Build : A057FXXS2AWL5 Int. Build : SM-A057F_SEA_XXV_QKEY0 Bypassig KG Lock... Done Done Done Done Once phone reboot in Odin Mode, full flash your device. Operation Finished. QcFire Ver. 9.6 downgrade to android 13 but same Device : Samsung Galaxy A05s (SM-A057F) BIT2 Operation : Samsung KG Bypass Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. SAMSUNG : Turn Off phone, hold EDL Cable Button and insert to phone and press VOL DOWN + POWER on phone more than 3 times rapidly and then leave EDL Cable Button. Found Port : Qualcomm HS-USB QDLoader 9008 (COM15) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.3.5 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID : E1801B00 [SM6225] 00002000 OPK_DATA : FE7A96F970CD7CE54D0256497B57539B3E3CBD084E89403B54 C5B4506C905ECD Initializing Protocol...OK Using Pre-Defined Loader [SM-A057F_BIT2_001.ufl] Preparing Loader...Done Sending Loader [SM-A057F_BIT2_001]...Done Executing Loader...OK Detecting Storage Type...OK Hardware : SM6225, UFS, 128 GB LU Count : 6 [0x01DA8C00] [0x00000800] [0x00000800] [0x00000400] [0x00020000] [0x00000800] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 262144 [65536], Out: 16384, Sector Size: 4096 Reading Partition Table...OK Reading Device Information...OK [Sign] Build : A057FXXS2BXC3 Int. Build : SM-A057F_SEA_XXV_QKEY0 Bypassig KG Lock... Done Done Done Done Once phone reboot in Odin Mode, full flash your device. Operation Finished. QcFire Ver. 9.6 |
04-29-2024, 08:30 | #2 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,730 | Quote:
Once phone reboot in Odin Mode, full flash your device. also post here a screen shot of your phone here and the firmware you used as you know samsung firmware has 5 parts one of them has the name HOME CSC,you should not flash HOME CSC you should use CSC b.r. | |
