06-06-2022, 10:20 | #1 (permalink) |
Freak Poster Join Date: Nov 2012 Age: 51
Member: 1835756 Status: Offline Thanks Meter: 741 | Vivo y12s frp done Model : Y83 Operation : Reset FRP Connection Mode : Preloader Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM_V1632 (Android) (COM5) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Connected to Download Agent.. Syncing with Target... Reading Partition Table... Storage : eMMC Reading Information... Build Date : Mon Mar 7 10:47:24 CST 2022 Build Flavor : full_k65v1_64_bsp-user Build Desc. : full_k65v1_64_bsp-user 11 RP1A.200720.012 eng.compil.20220307.105042 release-keys Android Ver. : 11 Display ID : RP1A.200720.012 release-keys Patch Level : 2022-03-01 Userdata is NOT ENCRYPTED Resetting FRP... FRP Reset Done. Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 5.0] |
11-02-2022, 10:34 | #2 (permalink) |
Freak Poster Join Date: Aug 2010 Location: ind
Member: 1383260 Status: Offline Thanks Meter: 62 | Brand : Vivo Model : Y12s Operation : Reset FRP Connection Mode : Preloader Waiting for Phone in Flash Mode... Connect Power Off phone within 30 secs... Port : MediaTek PreLoader USB VCOM (Android) (COM93) Connected to BROM. Sending Download Agent... connect DA end stage: 2, enable DRAM in 1st DA: 0 Failed to Connect DA: STATUS_BROM_CMD_SEND_DA_FAIL(-1073348605) Disconnect cable and Power ON phone. Please check if correct Platform/DA is selected Disconnect Battery/Cable and Power On Phone. [UltimateMTK Ver. 5.0] where is the problem |
The Following User Says Thank You to :Akintex: For This Useful Post: |
11-02-2022, 10:54 | #3 (permalink) | |
Product Supporter Join Date: Sep 2008 Location: UMT Support section Age: 34
Member: 869809 Status: Offline Thanks Meter: 1,714 | Quote:
no problem but your phone has latest patch security and it needs new download agent..or you may try to downgrade your phone(it's risky with newest security)or you may try via TP..for TP search on google closed b.r. | |
The Following User Says Thank You to bk.gsm For This Useful Post: |
