02-21-2021, 01:54 | #1 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Republica Dominicana Age: 40
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | redmi note 9 pro joyeuse remover mi account?'' Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Sending Loader [prog_ufs_firehose_sm6250_ddr.elf]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0MTY5NzY2RjQ3NUY0QjYzMz c0NzY0MkQ1NzQ0MzY2MzYzNkE3MzM5NTg2RjRBNEYzNjQ3NjQ3 Nz== User declined using UMT Server. Storage Initializaton Failed! Please use correct loader and check USB port / cable. QcFire Ver. 6.5 ------------------------------------------------------------------ Device : Xiaomi Redmi Note 9 Pro Operation : Reset Mi Account Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM20) Driver Info : Qualcomm Incorporated, qcusbser.sys, 2.1.2.7 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1901400 [SM6250] 00007200 OPK_DATA : 4B60244704D721E5B96DD5BB7233886E38F2198FBDE6433FCE 1D25A7B0472DD7 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [SM6250]...Done Executing Loader...OK Auth Enabled Device! You need Mi Auth Account to service! Skipping Auth...Failed Error Log : PD94bWwgdmVyc2lvbj0iMS4wIiBlbmNvZGluZz0iVVRGLTgiID 8+CjxkYXRhPgo8bG9nIHZhbHVlPSJFUlJPUjogU2lnbmF0dXJl IFZlcmlmaWNhdGlvbiBGYWlsZWQuIiAvPjwvZGF0YT48P3htbC B2ZXJzaW9uPSIxLjAiIGVuY29kaW5nPSJVVEYtOCIgPz4KPGRh dGE+CjxyZXNwb25zZSB2YWx1ZT0iTkFLIiByYXdtb2RlPSJmYW xzZSIgLz48L2RhdGE+ Reading Auth Blob...OK Blob : NDE1MTQxNDE0MTRDNzM0MjQxNDE0MTY5NzY2RjQ3NUYzOTZGND g2OTU0NkI2RjUzNjk1ODRGMzc0NzYzMzY1RjY1NzYzMzc2NUE2 N0== Requesting UMT Server for Auth Data...SERVER_TEMPORARY_OFFLINE Storage Initializaton Failed! Please use correct loader and check USB port / cable. Operation Finished. QcFire Ver. 6.5 |
02-21-2021, 05:28 | #2 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | This phone requires Auth for anything in EDL mode. If you have Mi Service Account, you can use that to service this phone. Br, UMT |
02-22-2021, 00:14 | #3 (permalink) | |
Member: 381487 Status: Offline Sonork: 100.1659930 Thanks Meter: 160 | Quote:
So your server has been off for a long time and I have credits that I am not going to use at the moment. So what is the function that umt supports with this Xiaomi note 9 pro, that you in an update say that it supports it. | |
The Following User Says Thank You to alexis_01 For This Useful Post: |
02-22-2021, 15:34 | #4 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Yes, it is supported, subject to use of Authorization, whether you agree or not, some people who have own Service Account access use it. Br, UMT |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
