10-09-2018, 17:10 | #18 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Try the following method: - Download same firmware as on Device. - In QcFire v3.1, load firmware, tick on Try Mi Relock Patch and Flash. - Now check if Relocks on WIFI, if yes, goto Recovery and Wipe Again. Br, UMT |
The Following 2 Users Say Thank You to U.M.T For This Useful Post: |
10-10-2018, 02:30 | #20 (permalink) |
Freak Poster Join Date: May 2016 Location: Colombia
Member: 2575005 Status: Offline Thanks Meter: 41 | That not done, i make flash whith patch but that was relock to conect wifi, i go recovery and wipe and that relock. Restore backup and said mi id account from the other phone backup but that relock when i login. Enviado desde mi Redmi 4X mediante Tapatalk |
10-10-2018, 06:34 | #22 (permalink) |
Member: 2575005 Status: Offline Thanks Meter: 41 | 1. Eraser all partitions=> Checking for existing devices...Found Port: Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info: HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID: E1C00C00 [8996] 00000000 OPK_DATA: F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware: MSM8996, eMMC, 64 GB LU Count: 1 [0x0747C000] Payload Info: In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Parsing Partition Entries...Done Erasing [switch]...OK Erasing [dpo]...OK Erasing [limits]...OK Erasing [ssd]...OK Erasing [sec]...OK Erasing [vbmeta]...OK Erasing [vbmetabak]...OK Erasing [storsec]...OK Erasing [storsecbak]...OK Erasing [apdp]...OK Erasing [msadp]...OK Erasing [keystore]...OK Erasing [frp]...OK Erasing [rpm]...OK Erasing [rpmbak]...OK Erasing [hyp]...OK Erasing [hypbak]...OK Erasing [pmic]...OK Erasing [pmicbak]...OK Erasing [cmnlib]...OK Erasing [cmnlibbak]...OK Erasing [cmnlib64]...OK Erasing [cmnlib64bak]...OK Erasing [abl]...OK Erasing [ablbak]...OK Erasing [dip]...OK Erasing [ddr]...OK Erasing [toolsfv]...OK Erasing [devcfgbak]...OK Erasing [devcfg]...OK Erasing [tz]...OK Erasing [tzbak]...OK Erasing [mdtpsecapp]...OK Erasing [mdtpsecappbak]...OK Erasing [keymaster]...OK Erasing [keymasterbak]...OK Erasing [bluetooth]...OK Erasing [sti]...OK Erasing [xbl]...OK Erasing [xblbak]...OK Erasing [misc]...OK Erasing [devinfo]...OK Erasing [logfs]...OK Erasing [dsp]...OK Erasing [bk1]...OK Erasing [mdtp]...OK Erasing [bk2]...OK Erasing [splash]...OK Erasing [persist]...OK Erasing [persistbak]...OK Erasing [logdump]...OK Erasing [rawdump]...OK Erasing [boot]...OK Erasing [recovery]...OK Erasing [cache]...OK Erasing [system]...OK Erasing [vendor]...OK Erasing [cust]...OK Erasing [userdata]...OK Operation Finished. QcFire Ver. 3.1 2. Flash Rom MIUI 10 => Operation : Flash Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info : HS Corporation, ghsser.sys, 10.2104.1.2 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00C00 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 64 GB LU Count : 1 [0x0747C000] Payload Info : In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Trying Mi Account Relock Patch.....OK Writing [storsec.mbn] -> [storsec] ...Done Writing [storsec.mbn] -> [storsecbak] ...Done Writing [rpm.mbn] -> [rpm] ...Done Writing [rpm.mbn] -> [rpmbak] ...Done Writing [hyp.mbn] -> [hyp] ...Done Writing [hyp.mbn] -> [hypbak] ...Done Writing [pmic.elf] -> [pmic] ...Done Writing [pmic.elf] -> [pmicbak] ...Done Writing [cmnlib.mbn] -> [cmnlib] ...Done Writing [cmnlib.mbn] -> [cmnlibbak] ...Done Writing [cmnlib64.mbn] -> [cmnlib64] ...Done Writing [cmnlib64.mbn] -> [cmnlib64bak] ...Done Writing [abl.elf] -> [abl] ...Done Writing [abl.elf] -> [ablbak] ...Done Writing [devcfg.mbn] -> [devcfgbak] ...Done Writing [devcfg.mbn] -> [devcfg] ...Done Writing [tz.mbn] -> [tz] ...Done Writing [tz.mbn] -> [tzbak] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecapp] ...Done Writing [mdtpsecapp.mbn] -> [mdtpsecappbak] ...Done Writing [keymaster.mbn] -> [keymaster] ...Done Writing [keymaster.mbn] -> [keymasterbak] ...Done Writing [BTFM.bin] -> [bluetooth] ...Done Writing [xbl.elf] -> [xbl] ...Done Writing [xbl.elf] -> [xblbak] ...Done Writing [dspso.bin] -> [dsp] ...Done Writing [mdtp.img] -> [mdtp] ...Done Writing [splash.img] -> [splash] ...Done Writing [persist.img] -> [persist] ...Done Writing [NON-HLOS.bin] -> [modem] ...Done Writing [boot.img] -> [boot] ...Done Writing [recovery.img] -> [recovery] ...Done Writing [cache.img] -> [cache] ...Done Writing [system.img] -> [system] ...Done Writing [vendor.img] -> [vendor] ...Done Writing [cust.img] -> [cust] ...Done Writing [userdata.img] -> [userdata] ...Done Writing [gpt_main0.bin] -> [PrimaryGPT] ...Done Writing [gpt_backup0.bin] -> [BackupGPT] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 3.1 3. Flash Partial Backup from other phone and show the id mi account of the other phone but try activate said updating account and relock for old account. Operation: Flash Checking for existing devices...Not Found Turn Off phone, hold Vol UP + Vol DOWN and insert USB cable. Some phones may need Special Boot Cable or TestPoint for EDL mode. Found Port: Qualcomm HS-USB QDLoader 9008 (COM3) Driver Info: HS Corporation, ghsser.sys, 10.2104.1.2 Connecting to phone...OK Waiting for response...OK Init Handshake Sequence...OK Hardware ID: E1C00C00 [8996] 00000000 OPK_DATA: F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Using Auto Loader Selection [1] Preparing Loader...Done Sending Loader [8996_016]...Done Executing Loader...OK Detecting Chip Type...OK Hardware: MSM8996, eMMC, 64 GB LU Count: 1 [0x0747C000] Payload Info: In: 262144 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Trying Mi Account Relock Patch.....OK Writing [switch_0.img] -> [switch]...Done Writing [dpo_0.img] -> [dpo]...Done [PROTECTIVE_FLASH] Skipping [fsc_0.img] -> [fsc] Writing [limits_0.img] -> [limits]...Done Writing [ssd_0.img] -> [ssd]...Done Writing [sec_0.img] -> [sec]...Done Writing [vbmeta_0.img] -> [vbmeta]...Done Writing [vbmetabak_0.img] -> [vbmetabak]...Done Writing [storsec_0.img] -> [storsec]...Done Writing [storsecbak_0.img] -> [storsecbak]...Done Writing [apdp_0.img] -> [apdp]...Done Writing [msadp_0.img] -> [msadp]...Done Writing [keystore_0.img] -> [keystore]...Done Writing [frp_0.img] -> [frp]...Done Writing [rpm_0.img] -> [rpm]...Done Writing [rpmbak_0.img] -> [rpmbak]...Done Writing [hyp_0.img] -> [hyp]...Done Writing [hypbak_0.img] -> [hypbak]...Done Writing [pmic_0.img] -> [pmic]...Done Writing [pmicbak_0.img] -> [pmicbak]...Done Writing [cmnlib_0.img] -> [cmnlib]...Done Writing [cmnlibbak_0.img] -> [cmnlibbak]...Done Writing [cmnlib64_0.img] -> [cmnlib64]...Done Writing [cmnlib64bak_0.img] -> [cmnlib64bak]...Done Writing [abl_0.img] -> [abl]...Done Writing [ablbak_0.img] -> [ablbak]...Done Writing [dip_0.img] -> [dip]...Done Writing [ddr_0.img] -> [ddr]...Done Writing [toolsfv_0.img] -> [toolsfv]...Done Writing [devcfgbak_0.img] -> [devcfgbak]...Done Writing [devcfg_0.img] -> [devcfg]...Done Writing [tz_0.img] -> [tz]...Done Writing [tzbak_0.img] -> [tzbak]...Done Writing [mdtpsecapp_0.img] -> [mdtpsecapp]...Done Writing [mdtpsecappbak_0.img] -> [mdtpsecappbak]...Done Writing [keymaster_0.img] -> [keymaster]...Done Writing [keymasterbak_0.img] -> [keymasterbak]...Done Writing [bluetooth_0.img] -> [bluetooth]...Done Writing [sti_0.img] -> [sti]...Done Writing [xbl_0.img] -> [xbl]...Done Writing [xblbak_0.img] -> [xblbak]...Done Writing [misc_0.img] -> [misc]...Done Writing [devinfo_0.img] -> [devinfo]...Done Writing [logfs_0.img] -> [logfs]...Done Writing [fsg_0.img] -> [fsg]...Done [PROTECTIVE_FLASH] Skipping [modemst1_0.img] -> [modemst1] [PROTECTIVE_FLASH] Skipping [modemst2_0.img] -> [modemst2] Writing [dsp_0.img] -> [dsp]...Done Writing [bk1_0.img] -> [bk1]...Done Writing [mdtp_0.img] -> [mdtp]...Done Writing [bk2_0.img] -> [bk2]...Done Writing [splash_0.img] -> [splash]...Done Writing [persist_0.img] -> [persist]...Done Writing [persistbak_0.img] -> [persistbak]...Done Writing [logdump_0.img] -> [logdump]...Done Writing [modem_0.img] -> [modem]...Done Writing [rawdump_0.img] -> [rawdump]...Done Writing [boot_0.img] -> [boot]...Done Writing [recovery_0.img] -> [recovery]...Done Writing [gpt_main0.bin] -> [gpt_main0] ...Done Writing [gpt_back0.bin] -> [gpt_back0] ...Done Applying Patches................Done Resetting device...Done Operation Finished. QcFire Ver. 3.1 Last edited by TecnoLatinosGSM; 10-10-2018 at 06:42. |
10-10-2018, 10:43 | #23 (permalink) |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Thanks for the detailed log. Here I can see you made a mistake. First, You never need to erase phone. Second, you flashed firmware with Try Mi Relock Patch, but that firmware is not factory firmware. Please enable "Try Mi Relock Patch" and try to flash with Factory Firmware. Br, UMT |
The Following User Says Thank You to U.M.T For This Useful Post: |
10-10-2018, 15:50 | #24 (permalink) | |
Member: 2575005 Status: Offline Thanks Meter: 41 | Thanks for reply Team, Where can see factory firmware, can you guide what version of firmware can use. Thanks Quote:
10-11-2018, 16:04 | #28 (permalink) |
No Life Poster Join Date: Apr 2008 Location: -=Cellulare Zone Europ-EGYPT=-
Member: 762055 Status: Offline Sonork: -=664053=- Thanks Meter: 778 | http://forum.gsmhosting.com/vbb/f970.../#post13361108 Added: Xiaomi Anti Relock Method - Use Read & Tools > Xiaomi Special > Anti Relock - You need to connect phone with USB Debugging Enabled. - It will disable Account Relock on connecting to Internet. - You will not be able to use Mi Account feature. - To revert back, just Wipe phone. BR, -=MR_Gsm=- |
The Following 2 Users Say Thank You to -=MR_Gsm=- For This Useful Post: |
10-11-2018, 19:07 | #29 (permalink) |
Insane Poster Join Date: Jul 2004
Member: 74284 Status: Offline Thanks Meter: 9 | this working fine!! Thanks alot to UMT for this solution. Any hope to be able to use Mi Account feature solution and/or not revert back after wipe?? Operation : Mi Anti Relock Checking for device in ADB mode...Found! Searching for Device...Found Brand : xiaomi Model : Redmi Note 5 Product : whyred Device : whyred Andriod Ver. : 8.1.0 Patch Level : 2018-09-01 Bootloader : unknown Build ID : OPM1.171019.011 Build Date : Mon Sep 10 19:57:39 WIB 2018 Disabling Mi Account Relock...Verified OK... Done Operation Finished. QcFire Ver. 3.2 Last edited by U.M.T; 10-11-2018 at 19:15. |
10-11-2018, 19:17 | #30 (permalink) | |
Member: 2465108 Status: Offline Sonork: No More Used Thanks Meter: 13,432 | Quote:
We are looking for another method, but can't say anything at the moment. Br, UMT | |
