11-04-2022, 00:37 | #1 (permalink) |
Product Supporter Join Date: Jan 2021 Location: Jordan Age: 39
Member: 2979261 Status: Offline Thanks Meter: 101 | Hello LPro AIO - A10 iOS 15 without network iPhone 7/7 Plus ( iPad5th Wi-Fi supported NEW UPDATE DOESNT REQUIRE DCSD - NO NEED DCSD for A10/A11 Devices Only. Guide (AUTO METHOD ONLY) : Step 1: Connect Device in "RECOVERY MODE" Step 2: Use "Boot To DFU Mode" Button to Boot DFU (DO NOT SKIP) Step 3: Click "Purple Mode" Button This Step NO NEED DCSD for iPhone 7-X (A10/A11) DCSD for iPads and iPhone 6s, 6s Plus Needed After Successful Write, Device Automatically Enters Recovery Mode Step 4: Use "Boot To DFU Mode" Button to Boot DFU (DO NOT SKIP) Step 5: Click "Run PwnDFU" Button Step 6: Click "Boot Device" Button Step 7: Click "Check SSH" (Wait for the Button to light up to become this Check SSH ✔️) Step 8: Click "HELLO BYPASS" Wait for the Device to turn on and the Device is Successfully Activated ————————————————————— Guide (MANUAL METHOD ONLY) : Step 1: Connect Device in "NORMAL MODE" It Will Show Serial To Change Manually Step 2: Connect Device in "RECOVERY MODE" Step 3: Use "Boot To DFU Mode" Button to Boot DFU (DO NOT SKIP) Step 4: Click "Purple Mode" Button You Can Connect DCSD Now and Click OK or Click Close. Click Close and Connect DCSD Cable for Manual Methods Step 5: Open MagicCFG or Any Tool to Edit Serial You Copied in Step 1 PLEASE VERIFY IF SERIAL CHANGED SUCCESSFULLY and Proceed Next Step Carefully. Read Device info in Normal Mode to verify Serial Change. Step 6: Click "Hello Bypass" Button in Normal MODE FIRST (DO NOT SKIP) This Checks if Device Data is OK For Bypass. Proceed Next Step After Success Message. Step 7: Connect Device in "RECOVERY MODE" Step 8: Use "Boot To DFU Mode" Button to Boot DFU (DO NOT SKIP) Step 9: Click "Run PwnDFU" Button Step 10: Click "Boot Device" Button Step 11: Click "Check SSH" (Wait for the Button to light up to become this Check SSH ✔️) Step 12: Click "HELLO BYPASS" The service is now fast and stable Best prices for delegates Special prices for individuals We welcome you for your inquiries 24 hours 📥 Telegram Channel Link - https://t.me/GSMJordanEN 📜 WhatsApp : +962788860606 🌍 Facebook : @gsmjordanjo 📧 Email support: [email protected] 🔁 website: gsmjordan.com |
