ASUS ASUS Devices |
02-04-2017, 10:46 | #1 (permalink) |
No Life Poster Join Date: Jul 2016 Location: Gods.On.Country
Member: 2602890 Status: Offline Sonork: NOTINSTALLED Thanks Meter: 231 | asus zenfone 5 t00j FLASHING ERROR AT 54% i flashed it with latest version but its error at the point 54% of installation i tried all tool miracle , rb soft also in minimal adb fastboot tool is it baseband or any hw problem like emmc? |
The Following User Says Thank You to Vahidpappali For This Useful Post: |
02-04-2017, 10:50 | #2 (permalink) | |
No Life Poster Join Date: Oct 2013 Location: MajeedGsm
Member: 2046498 Status: Offline Sonork: 100.1676751 Thanks Meter: 162 | post tje screen shot Quote:
to know about whats problem you have | |
02-04-2017, 13:30 | #4 (permalink) | |
Member: 2602890 Status: Offline Sonork: NOTINSTALLED Thanks Meter: 231 | Quote:
its stuck at 54% while installing via adb sideload then i tried a methode flashed both recovery.img and boot.img from a low version via fastboot THEN FLASHED THE FILE VIA ADB SIDELOAD 100% COPLETED SOLVED | |
02-13-2017, 08:46 | #5 (permalink) | |
No Life Poster Join Date: Nov 2012 Location: delhi
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | same problm here Quote:
same problm here can u shere u r file n link ? | |
02-13-2017, 09:00 | #6 (permalink) |
Moderator Join Date: Dec 2010 Location: Malaysia
Member: 1464783 Status: Offline Thanks Meter: 1,091 | Hello extract OTA zip File Select file.... Recovery.img...Boot.img...Fastboot.img.. flash this 3 file with fastboot mode... after done... flash the OTA file with sideload mode.. There have guide in this thread http://forum.gsmhosting.com/vbb/f977...ation-1874625/ BR Nizda Mobile |
02-13-2017, 11:56 | #7 (permalink) |
Member: 2602890 Status: Offline Sonork: NOTINSTALLED Thanks Meter: 231 | I HAVE SOLVED THE PROBLEM BY FLASHING LOWER VERSION RECOVERY.IMG,BOOT.IMG VIA FASTBOOT THEN FLASH WITH LATEST VERSION FILE VIA ADB SIDELOAD DONE.. NB-ASUS STUCK AT 54% IT IS RECOVERY PROBLEM YOU NEED TO DO THE SAME WAY I SAY OR TRY WHAT Nizda Mobil TOLD Last edited by Vahidpappali; 02-13-2017 at 12:02. |
02-13-2017, 14:56 | #9 (permalink) | |
Member: 1845731 Status: Offline Sonork: [email protected] Thanks Meter: 741 | thx for reply Quote: i face strange problem of asus zenfone t00j | |
03-10-2017, 04:23 | #10 (permalink) |
Junior Member Join Date: Nov 2016
Member: 2648918 Status: Offline Thanks Meter: 1 | Hello friends I have sloved Zenfone 5 in flashing error Solution Frist of all mobile are in fastboot after Open mirecle box and select Android after select Intel after choosing model and select flash in (fastboot flash ) After wait (And mobile are recover mode and Check mobile version download file) after fastboot mode and as per select method flash mobile process are complete after Mobile in recovery mode in the mirecle box select model and select flash and select ADB side load after raw select Mobile in recovery mode press down key and select apply form ADB update and press power button after starting process and Done mobile working fine ( Tested by Me 1000℅ working ) |
