ASUS ASUS Devices |
12-17-2018, 04:59 | #1 (permalink) |
Junior Member Join Date: Jul 2018 Location: Los Angeles
Member: 2849208 Status: Offline Thanks Meter: 6 | How To Use ASUS Zenfone Flash Tool Asus Zenfone Flash Tool Key Features
Compatibility Compatible with Windows Vista, Windows XP, Windows 7, Windows 8.1, Windows 10. Asus Zenfone Use Guide Here is the use step guide of the tool. This can be used to flash stock firmware on any smartphone or tablet device using a Windows PC. Step 1: Install Asus USB drivers in your Windows PC as the first step. Step 2: Skip the step one if you have installed them already. Now download Asus flash tool in to your Windows PC. Once the installation is done, open the application. Step 3: Once Asus home screen is loaded connect your smartphone or the tablet to the PC. Step 4: Click on the disconnected button available on the screen in order to connect your device to the tool. Step 5: Once the smartphone/ tablet is successfully connected, a green color connected button will appear on the screen. Step 6: Click on the browse button to locate the Asus firmware which downloaded and saved in your computer. Step 7: When you are done loading the firmware file, click on the start button to begin the flash procedure. Your smartphone or the Tablet will restart automatically. Step 8: Press and hold Volume down + Volume Up key to boot into the recovery mode. Step 9: under the recovery mode click or select "Apply Update from ADB". Step 10. click on the resume button in order to resume the flashing process. This will take a few minutes to complete. Once it is completed, restart the device and disconnect it from the PC. |
The Following 2 Users Say Thank You to gsmkris For This Useful Post: |
