01-05-2021, 14:23 | #1 (permalink) |
Junior Member Join Date: Nov 2016 Location: Nigeria
Member: 2651431 Status: Offline Thanks Meter: 6 | MI A3 Completely death after update to Android 11. Fix with UMT Box With so many online searches i arrived at this video: https://m.youtube.com/watch?v=h-Dr2E...ture=********* With the help of this video i was able to recover the phone. So thanks to him. In the above links from the video i used this file https://drive.google.com/file/d/1wId...e-PybCN45/view After Downloading: 1.pls make sure you're using the latest version of UMT_Qcfire. 2. Open the backcover. 3. Disconnect and connect the battery whenever you want connect to System. 4.connect the test point first before connecting to system https://forum.xda-dhttps://forum.xda-developers.com/t/x...point.3968644/ 5.now if the system detects the phone in download mode go to single program mode locate the raw program with the name rawprogram0.xml flash it and then flash rawprogram4.xml too. 6.Finally disconnect usb and connect to charger. If your battery is drained you've to wait a little if the indicator is blinking |
The Following User Says Thank You to faruq484 For This Useful Post: |
