11-18-2018, 16:06 | #316 (permalink) |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good this file is for removes the micloud account. To add does not cost anything, thank you. CuT URLs |
11-20-2018, 09:01 | #318 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | REDMI S2 (YSL): CuT URLs Hi, check if you can disable the wifi, if you do not turn off the phone you enter the recovery and factory reset, when you restart the phone the message or the micloud account lock will have disappeared and now follow these steps: Procedure for its correct use: 1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G. 2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi. 3. Open the tool as administrator and we will give you the unlock box of micloud. Tool link: CuT URLs Thank you does not cost anything, thank you very much. Good, first try a factory reset from recovery and you download the tool and follow the steps, if after the factory reset the message of blocking of account of xiaomi continues to come out then download the modified firmware. |
The Following User Says Thank You to Franky_36 For This Useful Post: |
11-21-2018, 22:22 | #323 (permalink) | |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
CuT URLs and then follow these steps to prevent relock. Procedure for its correct use: 1. We have to disconnect the xiaomi from the Internet, be it wifi, 3g and 4G. 2. We enable debug usb, we accept the rsa key and check the box to trust this computer, this will come out when we connect the usb cable to the xiaomi. 3. Open the tool as administrator and we will give you the unlock box of micloud. Tool link: CuT URLs | |
11-22-2018, 15:46 | #325 (permalink) |
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Good, and I want you to do, do it with another tool that is not miflash, if you do not search the internet that there are professional tools that can be used without box, if you do not ask for authorization to xiaomi. |
11-26-2018, 10:04 | #328 (permalink) | |
Major Poster Join Date: Feb 2017
Member: 2686480 Status: Offline Thanks Meter: 4 | Quote:
I did it, but it did not help, even the lock screen did not go away. but it turned out to be unlocked using your program (Unbricker_S2-YSL.exe) | |
11-26-2018, 10:19 | #329 (permalink) | |
https://forum.xda-developers.com/red...tloop-t3794643 | |
