08-04-2016, 21:51 | #3 (permalink) | |
Member: 163 Status: Offline Thanks Meter: 7,785 | Quote:
For mi3w, was easy, because exists android 4.4.x, and downgrade fix account, but for mi4 and newer models ... will be a bit tricky imho. Maybe some similar tricks as on other brands (Samsung, etc.) should be tried, or via XIAOMI suite, forced apk install etc ... No such phone in my hands, but - who have it, can try various tricks. p.s. downgrading to the lowest existing firmware version, would also help in bypassing, probably. b.r. Alex
__________________ Always press THANKS button if my post was helpful! Please DO NOT send me PM's for help, You can ask for help on forum Do not post THANKS posts - use thanks button ! ALWAYS use SEARCH button before posting! | |
08-05-2016, 05:47 | #4 (permalink) | |
Freak Poster Join Date: May 2012
Member: 1761266 Status: Offline Thanks Meter: 79 | Quote:
08-10-2016, 21:17 | #6 (permalink) |
Member: 163 Status: Offline Thanks Meter: 7,785 | In fact, factory images (at least for mi3-wcdma) are full qualcomm images, intended for QFIL / QPST flashing. Maybe emergency download cable making would help, (data+ and gnd shorted, insert in phone, then connect normal cable) since then phone should be visible as HS-USB Port 9008, after just use provided factory images / loaders to fully flash it. someone should try ... b.r. Alex
08-12-2016, 07:28 | #7 (permalink) |
No Life Poster Join Date: Apr 2008 Age: 28
Member: 745672 Status: Offline Thanks Meter: 555 | with the help of downgrade can removed mi account ... https://www.youtube.com/watch?v=7DUE...f1gowarjhfhb1k |
The Following User Says Thank You to Gsmbizz For This Useful Post: |
08-14-2016, 12:16 | #9 (permalink) |
Freak Poster Join Date: Mar 2008 Location: india
Member: 718313 Status: Offline Sonork: siddgoin@yahoocom Thanks Meter: 12 | 100% it will remove frp lock just do downgrade to lowest version... Search for lowest versions flash file ... Check CLEAR ALL in MI FLASHER in bottom... Continue flashing... Sent from my VS985 4G using Tapatalk |
09-21-2016, 10:35 | #12 (permalink) |
No Life Poster Join Date: Dec 2008 Location: GUJARAT-INDIA
Member: 926215 Status: Offline Sonork: 100.1650776 Thanks Meter: 95 | i am face same issue in redmi note3 (2013121) and mi account reset is not done in anyway and try to full flashing but no result ,,,,,reset with miracle box but no result any other solution ?? |
