redmi note 7 Dead I unlock bootloder then i flash with umt after flash phone cant on and connect QC 9008D Driver , i try may frimwere CN / Global flash succeuse with umt but after flash Conncet QC 9008d |
Good, flash the correct firmware considering whether it is a global version or a Chinese version. |
lavender_FASTBOOT_GLOBAL_ROM_V10.3.5.0.PFGMIXM_9.0 Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 2 GB LU Count : 1 [0x00000001] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 7 [lavender] Software : PKQ1.180904.001, V10.3.5.0.PFGMIXM [Wed Apr 24 13:00:55 WIB 2019] Android Ver. : 9 Patch Level : 2019-04-05 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.7 |
im basically looking for the same solution |
if flashing not succeed... you have to formate emmc chip with umt dongle...and flash with umt your phone has been powered on... but there is no baseband, Can be repaired later simple solution |
