11-19-2019, 22:00 | #1 (permalink) |
Freak Poster Join Date: Apr 2013 Location: lisbon
Member: 1917749 Status: Offline Thanks Meter: 90 | redmi note 7 Dead |
11-20-2019, 14:42 | #3 (permalink) |
Member: 1917749 Status: Offline Thanks Meter: 90 | lavender_FASTBOOT_GLOBAL_ROM_V10.3.5.0.PFGMIXM_9.0 Operation : Read Information Checking for existing devices...Found Port : Qualcomm HS-USB QDLoader 9008 (COM9) Driver Info : Network Connect, qcusbser.sys, 3.0.0.0 Opening Port...OK Init Handshake Sequence...OK Hardware ID : E1C00800 [8996] 00000000 OPK_DATA : F7337FE47B192EF4D1BA34CB4E879F0C6B771D06D2DE87BF21 F65BA3303834E1 Initializing Protocol...OK Sending Loader [prog_emmc_firehose_Sdm660_ddr.elf]...Done Executing Loader...OK Detecting Chip Type...OK Hardware : MSM8996, eMMC, 2 GB LU Count : 1 [0x00000001] WARNING! High Speed Driver is not installed. Please install driver from QcFire\Drivers folder using Device Manager. Payload Info : In: 65536 [4096], Out: 131072, Sector Size: 512 Reading Partition Table...OK Reading Device Information...OK Device : Xiaomi Redmi Note 7 [lavender] Software : PKQ1.180904.001, V10.3.5.0.PFGMIXM [Wed Apr 24 13:00:55 WIB 2019] Android Ver. : 9 Patch Level : 2019-04-05 USERDATA : Normal You can use RESET LOCKS to remove Pin/Pattern/Password WITHOUT Data Loss. Operation Finished. QcFire Ver. 4.7 |
11-20-2019, 16:52 | #4 (permalink) | |
Product Supporter Join Date: Dec 2016
Member: 2665389 Status: Offline Thanks Meter: 2,342 | Quote:
10-26-2020, 15:52 | #7 (permalink) | |
Junior Member Join Date: Sep 2017
Member: 2756269 Status: Offline Thanks Meter: 0 | Quote:
if flashing not succeed... you have to formate emmc chip with umt dongle...and flash with umt your phone has been powered on... but there is no baseband, Can be repaired later simple solution | |
