HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
03-28-2010, 15:27 | #1 (permalink) |
No Life Poster Join Date: May 2008 Location: Dubai(U.A.E) Age: 37
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | can i make a gold card with imate jama 101? mr sziq plz help me that can i make a gold card with in i mate jama 101? or if u make file and me i copy and paste in sd card? |
03-28-2010, 16:39 | #2 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Quote:
BR Szig | |
03-28-2010, 19:28 | #4 (permalink) | |
I think it is possible to make a Goldcard file for you,I never used this method,but I read about it years ago. I need the SD serial number and the model of the faulty device. BR Szig | |
03-29-2010, 06:05 | #5 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | There is a possibility to make Gold Card using JAMA or JAMA101. here comes some question. can it read SD Card serial? this phone supports Micro SD Card, wont work with phones who not support Micro SD. Like Wizard Magician. and some other may be. |
03-29-2010, 09:49 | #7 (permalink) | |
I don't know why it shows fake serial,try to get a HTC device and try with that.As I wrote I always used a HTC Charmer to create Goldcard without any problem.Maybe there is something with JAMA that QMAT can't handle or access to card serial is disabled,but it's just an idea,I can't check it. BR Szig | |
03-29-2010, 10:00 | #8 (permalink) | |
Member: 765909 Status: Offline Sonork: 100.1608098 Thanks Meter: 855 | Quote:
i try and post | |
03-30-2010, 10:43 | #15 (permalink) | |
ERROR 270 (Update Error - The image file is corrupted): Your device is still CID locked while trying to flash a cooked/custom ROM. Flash the USPL or Hard SPL if you have not already done so! If you were using the temporary USPL (white screen) method when you encountered this, you have to wait for the screen to go completely white before flashing a ROM (reset and try again if the screen did not go white). Check your Goldcard: XDADeveloperWiki - Elf_Gold Card And search for this: Run MTTY to verify the Gold Card unlocks the CID You can check the Goldcard,if it's good then you will see that: g_cKeyCardSecurityLevel = 0 I hope it helps! BR Szig | |
imat jama 101 start up hang pls help | gsm_bds | HTC & PDA WM( With Touchscreen) | 2 | 05-07-2009 17:02 |
Imate JAMA 101 plss help | kramnosnev | HTC & PDA WM( With Touchscreen) | 1 | 03-27-2009 14:47 |
imat jama 101 | avn | HTC & Smartphones ( WM Without Touch) | 4 | 03-05-2009 18:19 |
Imat jama 101 | avn | HTC & PDA WM( With Touchscreen) | 0 | 07-08-2008 17:19 |
