Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Various > HTC > HTC & PDA WM( With Touchscreen)
HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices
Old 03-28-2010, 15:27   #1 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
can i make a gold card with imate jama 101?
hi
mr sziq
plz help me that
can i make a gold card with in i mate jama 101?
or if u make file and me i copy and paste in sd card?
Old 03-28-2010, 16:39   #2 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
Originally Posted by delux_gsm View Post
hi
mr sziq
plz help me that
Good question,I don't know JAMA101 is able to make Goldcard,I have never had JAMA.I use HTC Charmer to do that.Maybe I can make you a file if you can give me the serial of your SD card.(I tried to find a simple tool to get serial from SD,but I didn't find that so far.)
Szig
Old 03-28-2010, 17:31   #3 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
okay brother if u make file 4 me
and send to me i copy and past in my sd card
so i use or not?
Old 03-28-2010, 19:28   #4 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
so i use or not?
Hi!
I think it is possible to make a Goldcard file for you,I never used this method,but I read about it years ago.
I need the SD serial number and the model of the faulty device.
Szig
Old 03-29-2010, 06:05   #5 (permalink)
.:SUBRATA:.'s Avatar
Member: 319447
Thanks Meter: 4,949
There is a possibility to make Gold Card using JAMA or JAMA101.
here comes some question.
can it read SD Card serial? this phone supports Micro SD Card, wont work with phones who not support Micro SD.
Like Wizard Magician. and some other may be.
Old 03-29-2010, 09:20   #6 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
hi
mr sizq
borther when i press get sd card id
he show fake sd card id
where problam ?
i have working i mate jama 101
Old 03-29-2010, 09:49   #7 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
hi
mr sizq
where problam ?
Hi!
I don't know why it shows fake serial,try to get a HTC device and try with that.As I wrote I always used a HTC Charmer to create Goldcard without any problem.Maybe there is something with JAMA that QMAT can't handle or access to card serial is disabled,but it's just an idea,I can't check it.
Szig
Old 03-29-2010, 10:00   #8 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
Originally Posted by szig View Post
Hi!
Szig
thanks for give idea
i try and post
Old 03-29-2010, 10:25   #9 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
i try and post
Hi!
I read about Anton Tomov Pocket Mechanic can read serial from SD,but I don't know it is VSN or PSN.It should run on JAMA,but I can't find the option in the soft,so it would be easier to get another HTC device.
Szig
Old 03-29-2010, 11:05   #10 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
hi
now in my hand htc shdow
but same problam
now he says <not found >
any more idea?
Old 03-29-2010, 11:55   #11 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
hi
but same problam
any more idea?
Hi!
Shadow can see the card? Is Activesync OK?Can you browse the storage card through Activesync browser?
Szig
Old 03-29-2010, 12:07   #12 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
Hi!
Szig
yes brother see in activesync browse
Old 03-29-2010, 12:10   #13 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
[IMG][/IMG]
Old 03-30-2010, 10:23   #14 (permalink)
Member: 765909
Sonork: 100.1608098
Thanks Meter: 855
my gold card making successfull
but when i try to update he give error (270)
any body help me
Old 03-30-2010, 10:43   #15 (permalink)
szig's Avatar
Member: 365452
Thanks Meter: 838
any body help me
Hi!
ERROR 270 (Update Error - The image file is corrupted):
Your device is still CID locked while trying to flash a cooked/custom ROM. Flash the USPL or Hard SPL if you have not already done so! If you were using the temporary USPL (white screen) method when you encountered this, you have to wait for the screen to go completely white before flashing a ROM (reset and try again if the screen did not go white).
Check your Goldcard:
XDADeveloperWiki - Elf_Gold Card
And search for this:
Run MTTY to verify the Gold Card unlocks the CID
You can check the Goldcard,if it's good then you will see that:
g_cKeyCardSecurityLevel = 0
I hope it helps!
Szig
imat jama 101 start up hang pls help gsm_bds HTC & PDA WM( With Touchscreen) 2 05-07-2009 17:02
Imate JAMA 101 plss help kramnosnev HTC & PDA WM( With Touchscreen) 1 03-27-2009 14:47
imat jama 101 avn HTC & Smartphones ( WM Without Touch) 4 03-05-2009 18:19
Imat jama 101 avn HTC & PDA WM( With Touchscreen) 0 07-08-2008 17:19
Page generated in 0.25577 seconds with 10 queries
