HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
06-25-2005, 08:53 | #1 (permalink) |
Junior Member Join Date: Jun 2005 Age: 44
Member: 155621 Status: Offline Thanks Meter: 1 | [Help] MDA T-Mobile Sim UnLock I try to upgrade by using O2-XDA IIs rom, it comes out Radio Rom Error...Thanks |
06-25-2005, 18:08 | #2 (permalink) |
No Life Poster Join Date: Oct 1999 Location: Hong Kong
Member: 596 Status: Offline Sonork: 100.33096 Thanks Meter: 514 | hello acturaly , if you want to unlock your device, there is a simple way to do it. just use the SD card to write the unlocked backup image to your phone. if you need more info just contact me. sorry here is a more simple way to unlock it regards Bert Last edited by Bert; 06-02-2006 at 23:35. |
06-26-2005, 08:40 | #3 (permalink) |
No Life Poster Join Date: Apr 2005 Age: 47
Member: 135671 Status: Offline Thanks Meter: 45 | Oh ! What the T-Mobile is can Unlock. Software is can Unlock HP 6315. I have many prolem and a lot of time to find crack it. But can not. What about you can tell me HP 6315. Best & Regards |
06-26-2005, 11:52 | #4 (permalink) | |
Insane Poster Join Date: Jan 2005 Age: 48
Member: 105916 Status: Offline Thanks Meter: 1 | Quote:
Can you explain more from "just use SD card to write the unlocked backup image"? | |
06-28-2005, 06:17 | #5 (permalink) |
Member: 155621 Status: Offline Thanks Meter: 1 | Is there really any chance to UnLock MDA T-Mobile, since i try to upgrade it into O2 XDA IIs asia rom, the radio rom always refuse to change.What can i do is to upgrade rom and extended rom only. So is there any solution, that i can change the radio rom, without paying Euro 30. thanks... |
06-28-2005, 11:12 | #6 (permalink) | |
No Life Poster Join Date: Feb 2004 Age: 45
Member: 55631 Status: Offline Thanks Meter: 55 | Quote:
Use latest version of winrar to extract a downloaded Rom upgrade utility. (Example: MDA3_TMUK_v106160_SHIP0307.exe) After extraction you will have the following file. Rom Files: ms_.nbf (Extended Rom Image) nk.nbf (OS/WinCE Rom Image) radio_.nbf (Radio Rom Image) Other Files: BaUpgradeUt.exe (Upgrade utility) EnterBL.exe GetDeviceData.exe RUU.conf (Upgrade utility Configuration File) RUU.dll 1: Now you have to delete the unwanted rom images and keep the only image you want to upgrade for Example if you want to upgrade radio rom only then delete ms_.nbf & nk.nbf and keep radio_.nbf... 2: Open RUU.conf in notepad and add the following line in the last of this config file. [CHECKCEID_TYPE]=1 3: Run BaUpgradeUt.exe and follow the on screen instructions. Have a nice try... [PaWaa] | |
06-30-2005, 05:33 | #7 (permalink) |
Member: 155621 Status: Offline Thanks Meter: 1 | i try to follow the instruction that pawaa gave.But the problem is i can't upgrade the Radio rom...it always freeze at 1%, so at the end i can't really unlock the phone... |
06-30-2005, 12:56 | #9 (permalink) |
Freak Poster Join Date: Oct 2003 Location: nigeria
Member: 41664 Status: Offline Thanks Meter: 37 | I think u have to check www.imei-check.com www.unlockitnow.com thats where the solution s for now ...not free |
07-11-2005, 09:21 | #15 (permalink) | |
Member: 155621 Status: Offline Thanks Meter: 1 | Quote:
The Following User Says Thank You to evilon3 For This Useful Post: |
1600 t mobile sim unlock | lilong_lee | HWK | 0 | 10-22-2009 03:05 |
help w375 motorola net10 sim unlock | V.F.C. | Motorola Hardware Repair | 2 | 09-05-2009 09:38 |
Mda T-mobile Pu10 Unlock | Nasmi | HTC & PDA WM( With Touchscreen) | 1 | 02-06-2009 12:57 |
Mda T-mobile Pu10 Unlock | Nasmi | JAFWM | 2 | 05-25-2007 04:47 |
[HELP!!!]MY-X5-2 SIM Unlock Code | PeterW | ARM9 BASED M62 / M62+ | 0 | 01-27-2005 14:59 |
