how to change smartphone's WM5 start up / shut down screen Hi, Would like to know is there a program or any way that i can change my smartphone WM5 start up and show down screen? currently using Dopod S300 been trying many ways to change the logo but it cant work. is there a way to do? do mine sharing it |
Up 2 now, only HTC Universal and HTC Wizard can change boot image, and it's very complex to do so |
@Polaris: are you sure??? |
1Open your registery 2Goto HKEY_LOCAL_MACHINE/SYSTEM 3Edit Shutdown/1 =>Values/Splash with your new /Windows/xxx.bmp 4Edit Startup/1 =>Values/Splash with your new /Windows/xxx.png (this is 1st splash) 5Edit Startup/2 =>Values/Splash with your new /Windows/xxx.png (this is 1st splash) Use the originals as templates :D |
@cengelbracht : r u sure it will work ?? If so, I think it will be a great discovery :D |
i have a question to make it would be healpful if we want to speedup the startup & Shutdown Process to delete the bmp's? how exactly can we do that? give an empty path to the string? thanks in advance greetings from Greece |
Hi ,guys i did it.I change the shut down screen for test perpose and it works.I did not change the start up screen but i wiil.I change the file I name it "qtek2.bmp" (without quotes) resolution 240x320, color bit 24bit and send it to windows folder.Then go registry and change the entrys above and that's all |
any dopod s300 user... its seem like other brand can work... but why dopod cant...???!!!??!!!:mad: |
