HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
04-25-2006, 18:53 | #1 (permalink) |
Freak Poster Join Date: Sep 2004 Age: 44
Member: 84100 Status: Offline Thanks Meter: 69 | Device 1. Prior to upgrading the operating system of your JAM, ensure all data is backed up either using Activesync or the Permanent Save program in your JAM (Under Start -> Settings -> System). The i-mate™ support team is available if you have any problems doing this. REMEMBER THAT THE UPGRADE PROCESS OVERWRITES ALL DATA CURRENTLY ON YOUR DEVICE. 2. Switch on the JAM and connect to your PC via the USB lead. The PC should make a sound to indicate the connection and the following message should appear. Press cancel to stop Activesync. 3. If this doesn’t happen, check the connection settings for Activesync by right-clicking the Activesync icon in the bottom right of the screen and ensure the USB tick-box is ticked. Also check that the Activesync version is up to date (Version 3.7.1 at time of writing). If this is still correct, perform a hard restart of your JAM, by holding the power button and pressing the reset button using the stylus. ENSURE ALL DATA IS BACKED UP BEFORE YOU DO THIS. 4. Having pressed cancel in (2), you should get the following message. Press OK 5. This will leave you in this state. 6. Now double click the .exe RUU upgrade application application. 7. This should now take you through the install procedure. In our experience, the device can be left connected and no reset is required. Press Next. 8. You see the following window. Before pressing Update, ensure the power lead is connected that the next 10-20minutes will be uninterupted. (Sound of USB disconnecting.) 9. You will now see the 3 stages of screens indicating the device is being upgraded. 10. Finally you are offered the finishing screen. The reboot process first installs the new operating system, followed by an automatic reboot to take on the new settings. During the reboot process, ensure the date and time are set accurately, as some applications rely on this being correct. Any required changes to date and currency formats can be made in Start -> Settings ->System -> Regional Settings. You will also have to restore your contacts, appointments and operator’s settings such as GPRS connection details and contacts (e.g. from Activesync or Permanent Save). Mr/konsowa Last edited by essojay; 04-27-2006 at 17:01. |
03-19-2008, 08:57 | #3 (permalink) |
Freak Poster Join Date: Apr 2005 Location: Ketchery Bazar FSD Pakistan Age: 49
Member: 135718 Status: Offline Thanks Meter: 5 | mt k-jam version is 000000 whn i try to upgrad it stop at 7 or 6%n says reset ur k-jam n contect again i did many times but still hava problem cant upgrad ma k-jam n network gone |
How To Setup Windows Operating System ASUS P750 | kmshawon | HTC & PDA WM( With Touchscreen) | 9 | 10-27-2009 11:23 |
HELP!!! tell me how to upgrade the language of Qtek 9100 (english) | lovely_dash | HTC & PDA WM( With Touchscreen) | 0 | 08-18-2007 21:21 |
HELP!!! tell me how to upgrade the language of QTEK K-JAM (English) | lovely_dash | HTC & PDA WM( With Touchscreen) | 0 | 08-18-2007 21:07 |
Does anyone know how to replace the operator on a Nokia 6200? | RMskater | Nokia Digital Core Technology 4 ( DCT-4 ) | 0 | 09-16-2003 01:29 |
How to change the operator name of MY3026(D74,5I)? | sagemland | Infineon C16X M51 & ARM7 M52 BASED | 1 | 03-08-2003 06:26 |
