HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
12-16-2008, 17:15 | #1 (permalink) |
No Life Poster Join Date: Jul 2008
Member: 818352 Status: Offline Thanks Meter: 266 | Htc elf dead after wrting elfin rom i stopped at 1% now elf is completely dead no boot loader nothing How can i revive My Dead Elf Plz Help My Client is like a Bull Reason For Using Rom : Wanted to change Language frm spanish to english By Mistake Downloaded Elfin Rom n made Update Regards,Trigger |
12-16-2008, 19:31 | #2 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Check the battery.If it is OK and you can't take it to bootloader then you bricked the Elf.Maybe a HTC service can help with JTAG repair,but it expensive and takes some time. If you have bootloader mode,then try to flash it with the original Elf ROM(signed SHIP at the end of filename) via USB or SD. Your future favourite ROM source: http://forum.gsmhosting.com/vbb/showthread.php?t=596894 (thanks to Subrata) I will check maybe there is a force usb flash method,but I'm not sure it exists for this model. One tiplug usb to Elf(connected to PC) and try to take it to bootloder mode,sometimes it helps. Post results! BR. Szig |
The Following User Says Thank You to szig For This Useful Post: |
12-16-2008, 20:17 | #4 (permalink) | |
Member: 818352 Status: Offline Thanks Meter: 266 | Quote:
Method Frm Xda Developer But Here Comes No Bootloader Regards,Trigger | |
12-16-2008, 22:52 | #6 (permalink) |
Member: 818352 Status: Offline Thanks Meter: 266 | Problem Solved After Lot of attempts Phone got in Boot Loader Mode i flashed with a custom Rom, Language Now is EnglisH Offcourse Special Thanks To ::M@ster :: Regards,Trigger |
12-17-2008, 06:52 | #8 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | can anyone share that trick ? how you repaired your ELF ? may be this can help someone else. |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
10-05-2010, 19:02 | #10 (permalink) |
Junior Member Join Date: Oct 2010
Member: 1410815 Status: Offline Thanks Meter: 0 | hi i have the Elf ,tried to change rom suddenly all went off it died and now no way to enter in bootloader or try mtty nothing at all ,just black screen and a green light of the batery gets on but nothing else even usb not detect .Any idea of how i can make it run again .I tried all of the post but nothing. somebody help me plz.,.,.,.,. |
HTC Hermes dead after unlock! | Kais_Unlocker | HTC & PDA WM( With Touchscreen) | 17 | 07-13-2013 13:02 |
HTC S710 Dead after opening once | bakhshalvi007 | HTC & PDA WM( With Touchscreen) | 7 | 04-19-2010 04:20 |
help htc elf dead | GSM FREE | HTC & PDA WM( With Touchscreen) | 1 | 01-19-2010 20:28 |
[HTC Wizard] Dead after hard reset | crashmatrix | JAFWM | 5 | 10-08-2006 22:03 |
nokia 2600 dead after wrting pm | satcomhedi | UFS2 + UFS3-Tornadoflasher | 11 | 07-09-2006 16:36 |
