HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
01-05-2009, 19:38 | #2 (permalink) |
Freak Poster Join Date: Feb 2006 Location: ALGERIA (oran city) Age: 46
Member: 227959 Status: Offline Sonork: 100.1589050 Thanks Meter: 254 | hi Here are the steps: Step One: Preform power down *Hold the power button* Till the phone is 100% powered down and all you see is a black screen *keep in mind if your device is plugged into a power source or computer link this will not work!* Step Two: (Use both hands while doing this it will be much easier!) Place 1 finger on each of the Soft keys. Step Three: Press the power Button and hold for no more than 2 sec well holding the two soft keys (do not hold the power button till the phone turns on) ONLY PRESS THE POWER BUTTON DO NOT TURN THE PHONE ON. After pressing the power key keep your fingers on the Two Soft keys until you see a the phone turn on and a black screen come up with white writing. Once you see this screen Press the Green Send key and there you go you have just performed a hard reset on the T-Mobile dash without using the settings screen on the phone. good luck omega-gsm |
The Following 6 Users Say Thank You to omega-telecom For This Useful Post: |
06-12-2009, 05:05 | #8 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Philippines Age: 36
Member: 758106 Status: Offline Sonork: jap_line Thanks Meter: 412 | Quote:
just remove battery, insert it back, then you can now perform hard reset.. follow the procedure carefully! br, | |
The Following User Says Thank You to jap_line For This Useful Post: |
06-12-2009, 14:12 | #9 (permalink) |
Junior Member Join Date: Jun 2009 Location: philippines
Member: 1045746 Status: Offline Thanks Meter: 0 | wow thankyou for reply.. i did it already but still its not work.. question.. i have received message no system device found then my phone did not go to the home page and i did'nt off the power, i need to take the battery so that it will off.. what do you think my solution for this problem..please reply to my account or in this post..thankyou so much i am expecting for the reply. |
08-13-2009, 22:33 | #10 (permalink) | |
Freak Poster Join Date: Jun 2005 Location: tunisie Age: 44
Member: 155719 Status: Offline Thanks Meter: 93 | Quote:
big thanks work perfectly nice work | |
How to unlock HTC EXCA100? | waqarmunir4 | HTC & PDA WM( With Touchscreen) | 50 | 02-17-2011 07:54 |
Unlock HTC EXCA100 | scientist | HTC & PDA WM( With Touchscreen) | 2 | 09-27-2008 12:21 |
Htc Exca100 | GSMBOURGES | HTC & PDA WM( With Touchscreen) | 2 | 11-07-2007 14:17 |
