HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
05-13-2007, 22:11 | #1 (permalink) |
No Life Poster Join Date: Jul 2004 Location: P A K I S T A N Age: 49
Member: 75644 Status: Offline Thanks Meter: 5 | htc wiza200 hanged |
08-05-2008, 13:24 | #3 (permalink) |
Freak Poster Join Date: Mar 2005
Member: 129536 Status: Offline Thanks Meter: 9 | http://forum.xda-developers.com/showthread.php?t=298613 .its like this link will help |
06-22-2009, 10:04 | #5 (permalink) |
Junior Member Join Date: Jun 2009 Location: Bohol, Philippines
Member: 1055462 Status: Offline Sonork: earl ryann Thanks Meter: 0 | how to reset i have same problems with yours.. how to reset wiza200 if its stuck? does it need to connections to the computer.. or any programs to hard reset it? |
06-22-2009, 16:42 | #6 (permalink) |
Freak Poster Join Date: Apr 2004
Member: 63988 Status: Offline Thanks Meter: 100 | to hard reset your device you need to press the the comm center and voice commands buttons (top left and top right side) and while holding them reset with stylus (mid left side) |
08-31-2009, 08:45 | #9 (permalink) |
Junior Member Join Date: Sep 2008
Member: 870001 Status: Offline Thanks Meter: 10 | HTC Wizard (Prodigy) Resetting Your HTC Wizard Occasionally you may need to reset your Wizard. A normal (or soft) reset of your device clears all active program memory and shuts down all active programs. This can be useful when the device is running slower than normal, or a program is not performing properly. A soft reset is also necessary after the installation of some programs. If a soft reset is performed when programs are running, unsaved work will be lost. You can also perform a hard reset (also known as a full reset). A hard reset should be performed only if a normal reset does not solve a system problem. After a hard reset, the device is restored to its default settings â�� the way it was when you first purchased it and turned it on. Any programs you installed, data you entered, and settings you customized on the device will be lost. Only Windows Mobile software and other pre-installed programs will remain. To perform a soft reset â�¢ Use the stylus to lightly press and hold the RESET button on the left side of your device. The device restarts and displays the Today screen. Warning! Always turn off your device before performing a soft reset or installing/replacing the battery and SIM card. To perform a hard reset 1. Press and hold the Comm Manager button and Voice Command button on the device. At the same time, use the stylus to lightly press the RESET button. 2. Keep the Comm Manager button and Voice Command button pressed, and the following message will appear on the screen: 3. Release the two buttons, and press the Send button to perform a hard reset. Vissza a fõoldalra -------------------------------------------------------------------------------- |
The Following 3 Users Say Thank You to mk_akar For This Useful Post: |
Htc wiza200 hard reset | alamgarh | HTC & PDA WM( With Touchscreen) | 5 | 04-08-2013 12:38 |
HTC WIZA200 dead after hard reset.plz need urgent help... | sheikhje | HTC & Smartphones ( WM Without Touch) | 0 | 03-02-2009 08:15 |
HTC wiza200? | FMC_GSM | Gsmfather The Wholesale Unlocking Database | 2 | 06-19-2008 07:54 |
htc wiza200 unlocking pls,,,,,,, | karthik77 | Phone Unlocking Codes & Maps | 0 | 09-16-2007 16:50 |
who connect to internet with wifi, i have htc wiza200 and windows mobile 5, | danisoft5293 | Various | 0 | 08-06-2006 19:45 |
