HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
11-27-2008, 19:32 | #1 (permalink) |
Junior Member Join Date: Sep 2006
Member: 354698 Status: Offline Thanks Meter: 4 | my xda orbit dead Ok now, i hold the voice and power bottons + i reset with stylos ( i keep holding the voice and power btons ) i have a RED, GREEN and Blue colors, when i put my phone to USB i see that in the left down the screen show me that it's connected with USB, so i found some Roms, but i have always problem as : ERROR UPDATE or INVALID VENDER ID ... i'm really confused please i want help really i do need it. and you know somethings ?? hahaha it's not mine i mean XDA ORBIt really waw i'm shocked ... 1- I start the START_USPL.EXE, i just see black windows ( CMD ) and it's hide ( so it's not start already. 2- When i execut " ROMUpdateUtility " with the help Red, Green and blue colors, he switch off and switch on show me the level of progress and when he arrive to 100% after few seconds he give me Error as : ERROR UPDATE. Really i'm confused i don't know how to resolv this problem .... Sorry id i disturb you really Regards and respect Reda XDA ORBIT ( ARTE200 ) |
The Following User Says Thank You to redadido For This Useful Post: |
12-03-2008, 10:31 | #2 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Hi! Check the xda-developers.com for solution. If USPL doesn't work then you have to get the original ROM for your device and try to flash it via USB or SDcard. BR Szig |
The Following User Says Thank You to szig For This Useful Post: |
12-05-2008, 09:54 | #3 (permalink) |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Dont just try several ROM for your Orbit. which country are you from ? send it to O2 service center. this is my opinion. |
The Following User Says Thank You to .:SUBRATA:. For This Useful Post: |
12-08-2008, 21:35 | #4 (permalink) |
Registered User Join Date: Apr 2006 Location: near to hyderabad ap india
Member: 259742 Status: Offline Thanks Meter: 215 | If you have flashed your device and not cid unlocked it, your device maybe salvagable if you can get it into bootloader mode. Hold down the voice speed dial button and soft reset - you should then enter bootloader mode 'multicolored' screen' If you do, attach device to pc via usb cable (a small usb will appear bottom left of screen) and flash factory rom. (run rom executable or RUU updater from pc) You do not need to be activesynced to do this. HTC P3300 WWE factory rom downloadable here http://rapidshare.com/files/19322112...0_WWE_SHIP.rar Dopod P800 WWE factory rom downloadable here http://rapidshare.com/files/21058219...0_WWE_SHIP.rar O2 Orbit WWE Wm5 factory rom downloadable here http://rapidshare.com/files/41574866/Arteimg.nbh Before you flash again with a non-factory rom, your device MUST be cid unlocked. If you cannot enter bootloader mode your bootloader has been damaged and your device will need to be sent away for repair |
The Following User Says Thank You to prasad3223 For This Useful Post: |
12-08-2008, 21:38 | #5 (permalink) |
Member: 259742 Status: Offline Thanks Meter: 215 | Artemis Update SPL (USPL) v.01 - Another way to flash *ANY* rom to your device! This is a patched SPL for HTC Artemis devices (HTC P3300 / T-Mobile MDA compact III / O2 XDA Orbit / Dopod P800W / Dopod P800 / Dopod M700 / Orange SPV M650). This SPL is based on original Artemis 1.11 SPL but includes 3 patches:
This means you can flash ANY ROM to your Artemis after flashing USPL on it, no need to pay for CID unlock anymore! Disclaimer: This is free to use but at your own risk, I take no responsibility for any conflict, fault, or damage caused to your phone by this unlocking procedure. No warranties of any kind are given. Any commercial usage prohibited. Instructions: 1. Unzip 2. Connect your phone to computer, make sure activesync is enabled (green icon) 3. Run start_uspl.exe on your computer and wait until process finishes 4. See Artemis_USPL_Manual.zip (PDF) for more detailed instructions! [/LIST]Attached FilesArtemis_USPL.zip (1.76 MB, 85135 views)Artemis_USPL_Manual.zip (176.5 KB, 38509 views |
12-08-2008, 22:00 | #6 (permalink) |
Member: 259742 Status: Offline Thanks Meter: 215 | now time for wm6 upgrade after the above two steps follow this instructions 1. If you presently run a factory wm5\wm6 rom then uspl cid unlock your rom before you flash cooked rom. 2. If you have a cooked rom on your device already and are changing to another cooked rom (especially if rom is from a different cook) i would recommend you: a) flash back to factory rom first b) then cid unlock c) then flash the new cooked rom. This is because sometimes the new cooked rom does not function 100% on first flash and a repeat flash is required. 3.Alternatively (especially if you dont have access to the factory rom) flash the new cooked rom twice to be sure new rom has taken properly and if device is already cid unlocked there is no need to cid unlock again ---------------------------------------------------------------------- official o2 wm6 rom http://www.4shared.com/file/45953573...6790_Ship.html unofficial cooked rom ARTEMIS & LOVE WM6.1-Build 20931.1.5.0(Manila2D) http://www.mediafire.com/?kzmnynlitni |
04-06-2009, 08:29 | #8 (permalink) |
Member: 365452 Status: Offline Thanks Meter: 838 | Hi! Just extract a ROM upgrade file(usually an .exe) to a folder,you will find an ARTEIMG.nbh file.Copy that to a formatted (FAT16) SD card and you can upgrade your device from card.Prasad posted an ARTEIMG file above. BR Szig |
09-06-2009, 19:46 | #9 (permalink) |
No Life Poster Join Date: Feb 2001 Location: ITALY Age: 51
Member: 3381 Status: Offline Thanks Meter: 1,171 | Similar problem here, i have an Artemis 100 Wm5 come from Netherlands and i want to change language in it, so i do this, USpl for Cid unlock and all ok now i have Ipl 1.12.0001 SPL 1.11.cmon and this is quite, after this i try to update italian Wm6 offical rom P3300 Italy 3.13.408.1_02.94.90 Ship R but always receive this error error 244 ivalid Model ID, and also if i use 1.12.405.01_026790_wwe_ship receive same error, the strange is that i make a lot of this phone and no problem, but i notice this problem phone enter in boot mode only whit program manually can't enter. If someone know why please post a solution. Tanks |
09-07-2009, 08:30 | #10 (permalink) |
Member: 3381 Status: Offline Thanks Meter: 1,171 | Finally i manage to solve problem, now work perfect. The problem is that phone not work sometime whit Uspl so need to use another flash Rom and after all ok. |
09-07-2009, 08:57 | #11 (permalink) | |
Member: 365452 Status: Offline Thanks Meter: 838 | Quote:
Try to make a Goldcard. Infos with links here: http://forum.gsmhosting.com/vbb/show...rd#post4732240 and here: http://forum.gsmhosting.com/vbb/show...rd#post4563412 With Goldcard inside you can flash any OFFICIAL ROM. BR Szig | |
09-07-2009, 09:07 | #12 (permalink) |
Freak Poster Join Date: Jun 2009 Location: !!!! AWAY FROM BOARD, STUDY !!
Member: 1055354 Status: Offline Thanks Meter: 252 | yes, either make GOLDCARD or flash back exact ROM from same CID, language, brand that was on device. |
The Following 2 Users Say Thank You to sergeymkl For This Useful Post: |
O2 Xda Orbit | faustus | HTC & PDA WM( With Touchscreen) | 1 | 06-04-2007 04:57 |
NaviGation Sw O2 XDA Orbit | ZoHaiB_(FoneGSM) | HTC & PDA WM( With Touchscreen) | 0 | 05-21-2007 23:41 |
O2 XDA orbit owners please help | spikescot2005 | HTC & PDA WM( With Touchscreen) | 1 | 05-11-2007 17:33 |
How to unlock O2 XDA ORBIT? | makkan00 | HTC & PDA WM( With Touchscreen) | 2 | 05-07-2007 13:28 |
