HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
08-15-2005, 01:25 | #1 (permalink) |
No Life Poster Join Date: Dec 2004 Location: Dublin Age: 44
Member: 100436 Status: Offline Thanks Meter: 57 | Need advice with an XDA II backlight problem ! Has anyone any advice on how to repair an XDA II with backlight not working ? Would flashing it help ? TIA Unlock_Ireland |
08-15-2005, 02:56 | #2 (permalink) |
No Life Poster Join Date: May 2001 Location: U.K Age: 54
Member: 4611 Status: Offline Thanks Meter: 68 | Shot in the dark, but we had someone bring a pocket pc in for repair with the same fault. Turned out that he'd turned the backlight off by holding the power button in too long to switch the pda off. Switched the PDA on, pressed and held the power button..Backlight on. I know it's a slim chance, but in this case it was simply user error. |
08-17-2005, 22:10 | #3 (permalink) |
Member: 100436 Status: Offline Thanks Meter: 57 | Thanks Blartiartfast, I've tried it already . It was droped in water and now the backlight doesn't work, so I put it in the ultrasonic cleaner for 20 mins but it's still the same . Would it be possible to flash these ? I have the sync station off it, could I use that for flashing ? Any advice is welcome. TIA BR Unlock_Ireland |
08-17-2005, 23:51 | #4 (permalink) |
No Life Poster Join Date: May 2003 Location: Romania Age: 48
Member: 29006 Status: Offline Thanks Meter: 28 | hope you look at start - settings - backlight and is turned on.try to follow circuit from two leds under the call and end buttons,maybe comand for enabling light is common for lcd and leds. |
08-18-2005, 01:53 | #5 (permalink) |
Member: 4611 Status: Offline Thanks Meter: 68 | Yes you can flash these very easy with the USB sync station. Think there is a link to the official O2 firmware page from the O2 web site, failing that goto xda-developers.com. There are links to firmware pages there. I flashed my XDA11s with the Qtek firmware, and the unit is a much better device now. Don't think that will cure your problem though, but I guess it won't hurt to try. |
I need help with an S5200 | sithlord3k | LG | 0 | 10-02-2008 14:46 |
O2 XDA II Mic Problem | virgix | HTC & PDA WM( With Touchscreen) | 0 | 01-23-2008 08:33 |
Please, advice with an 5500. | eskerra | MT-BOX | 3 | 12-05-2007 20:47 |
Need Help With an Alpine Radio from a Alfa Romeo | dune1982 | CAR Electronics | 7 | 03-15-2007 08:47 |
need advice on 8810 headset/power down problem | goof | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 02-24-2001 20:56 |
