HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
01-14-2010, 12:17 | #4 (permalink) |
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Hi! 1.Use the search before you post. 2.Read the posts,there is a link above where you can find or request for ROM. 3.We need more info about your device,arte 100 is not enough.Things that help us: Does it work or stuck on bootloader?CID locked or not? IPL,SPL,Radio,ROM version,language,provider or CID value is better BR Szig |
The Following User Says Thank You to szig For This Useful Post: |
01-14-2010, 20:43 | #6 (permalink) | |
Member: 365452 Status: Offline Thanks Meter: 838 | Quote:
We need more info about your device,arte 100 is not enough.Things that help us: Does it work or stuck on bootloader? CID locked or not? IPL,SPL,Radio,ROM version,language,provider or CID value is better Give us these informations and we can give you the proper ROM,tools or other solutions. EDIT:I found your picture.So,you have an arte100,IPL,SPL 1.36,movistar telefonica,CID:TELEF301 And the ROM you need: http://www.megaupload.com/?d=6VE5JPDX BR Szig Last edited by szig; 01-14-2010 at 20:49. | |
01-15-2010, 12:26 | #8 (permalink) | |
Disable USB connections in Activesync menu (untick the box). Put your device in bootloader mode: The bootloader is invoked by pressing down the Power and Voicedialer buttons simultaneously, and using the stylus at the same time to press the RESET button at the left side. Continue pressing the two buttons for a few seconds after pressing and releasing the reset button until the bootloader screen appears. If you see the tri-color screen with numbers then connect device to PC.Run the upgrade utility as usual and it has to flash your device. After that your device will boot normally (I hope). BR Szig | |
01-15-2010, 13:55 | #10 (permalink) |
Member: 365452 Status: Offline Thanks Meter: 838 | Hi! For unlock: http://forum.xda-developers.com/showthread.php?t=397718 Download the soft,read the readme file,follow instructions and enjoy your unlocked artemis! BR Szig |
01-15-2010, 18:43 | #11 (permalink) |
Freak Poster Join Date: Dec 2005 Age: 41
Member: 206939 Status: Offline Thanks Meter: 17 | terminal with error Decrypted stored sum: 5ABFA145AB315ED9 Decrypted calcd sum: 914D1000A5A60D57 Checksums did NOT match!! Could not determine a key index to decrypt it. Your CID block must be corrupted or file isn't from a valid CID dump!! Aborting operation. |
30-07-2008 New flash files update! Original flash files added! | GSMtricks | Multi-Box | 5 | 07-17-2009 10:07 |
30-07-2008 New flash files update! Original flash files added! | GSMtricks | Chinese Cocktail | 4 | 08-09-2008 07:30 |
30-07-2008 New flash files update! Original flash files added! | GSMtricks | Multi-box LITE | 4 | 08-01-2008 11:46 |
30-07-2008 New flash files update! Original flash files added! | GSMtricks | PadFinder box | 0 | 07-30-2008 15:22 |
need urgent U8330 original flash with original functions. | gsm_unlock | VygisToolbox | 0 | 06-30-2005 11:55 |
