i have one q... why does my sms will sent double if i install spb pocket plus, any solutions ? or maybe anyone can help solving this prob ? this s/w is good but i dont like this problem. i use xda iis. :( |
Did Not Know About This Problem Quote:
IT WORK FINE WITH MY I MATE JAM ,.,. ;) I ASK MY FRIENDS ABOUT THIS :rolleyes: ,.,. IF I HAVE SOME SOLUTION I WILL TELL U ,.,.,. :D ONE THING ,.,. CHECK OUT ALL THE SETTING,,.,. :cool: MAY BE IT HELP S U ,.,.,. :cool: |
New Games Posted NEW GAMES POSTED re-markable job man ,.,. tooooooooooo good ,.,. :D like it tooo much ,.,.,imprassive :) post more ,.,. :cool: we grow this theard till it is the best ,.,.,. :D :cool: GOOD GAMES ,.,. EVERY ONE MUST SEE |
SKTools PPC 2002 1 Attachment(s) Quote:
Powerfull maintenance tool. Cleaning registry and file system, databases maintenance, system backup/restore and much more... Cleaning: Find and delete temporary and absolete files Clear temporary and cache folders like IE contents, IE history, Mail attachments, Large mails, AvantGO and custom users folders Find and remove bad registry keys and values Find and delete bad shortcuts Find and delete duplicate shortcuts Find and delete duplicate notify queue entry/entries Find and delete bad uninstall info Find and delete files depending on whose size or/and names (wipe optional) Find and delete duplicate files (find with name,size,crc) Find and delete MS Reader bookmarks (sensitive for bookmark in-use/not-use) Find and delete empty folders Find and delete exceed appointments Find and delete duplicate appointments Delete PIE history (registry) System Information: Device information and features Processor information Memory information Screen information OS version Network Power state ROM information Duplicate Contacts: Find duplicate contacts (by all fields or names,email,company,phones) Show Delete Notify Queue: View records Add records Delete records Find doublicates Memory Usage: Show all folders with size (bytes and percent) Open selected folder Backup/restore: Auto (may disabled) backup registry key before delete it Sheduled weekly full backup Full system backup Full registry backup Full filesystem backup All databases backup ActiveSync Partnership backup MSReader activation backup Self backup Password protection for backup files Find and restore all SKTools backup files Good compression for backup files Storage card maintenance: Show information about card(s) Format Scan and Fix Empty Rename Other... Database maintenance: Show information Delete Empty Export/Import to XML file (as example for partially backup or for transfer contacts database to other PPC) Process list: Show all process Show list of modules of any process Show information about memory usage, threads Show command line for procees (if it exist) Close one or selected processes Today plugins list: Show information about plugins Delete and Uninstall (if possible) Enable/disable plugin Reorganise today plugin order with renumbering Input methods list: Show information about installed Delete and Uninstall (if possible) Enable/disable Select default method Windows Startup: Display list of programs that run when system loading Delete program Add new Startup programs order control Built-in Uninstaller: Show list of installed program with size and date Show list of files and registry keys for installed programs Uninstall program Save installed programs list to text file Automation mode: Run SKtools when system loading Run SKTools every day at user defined time (with power off after work) User defined operations list Silent (run with out any window, only with led blink) mode Other: Multi-language support ( English, German, Spanish, French, Russian, Italian ) Change location of PIE cache, PIE history, PIE coockies, AvantGO datas Soft and Hard reset Command line support (screen off/on,power off, soft/hard reset and more...) Change system path (after this you can move some dlls from windows folder to any location, as example to storage cards) Free customizable today plugin (you can run SKTools and your favourite programs quickly) More... :D :D :D |
Thanks a lot HuBMOBILE, for the Worldmate 2005, and alimazhar. for posting SKTools |
HuBMOBILE, I have already install the Worldmate 2005, and then apply the crack .exe, for some reason when I try to updte the weather forcast, it says "Service Denied contact customer service" therefore I cannot update, what you think is the problem is it the crack doesn't work or what, please help if you know the solution, thanks again. |
1 Attachment(s) @Trek55 Here im Uploading the .nfo file, the cracker states that "when you update flight status the program going to trial mode." but at last he also states that he has fixed that bug, i don't know what could the exact Problem be.. (Maybe this bug has not been Fixed by the cracker still.) |
Hi Guys, Sorry to bug you's but i just got my hands on an xda2, but i'am having problems with some application such as games? The problem being once i've uploaded the game to the xda it says " 'xxxxxx' is not a valid Pocket application.".I dowloaded the games from FuzionGSM's Forum in the pocket pc section.Any Ideas? Regards MFC |
@MFC In Which Format is it..?? Are you trying to transfer the .rar Files, if yes extract this .rar files first in your PC using Winrar, and then Start the .exe file or Simply transfer the .cab fle into your PPC and then it will automatically install the Appz for you.. |
Ya maybe the crack is not fully cracked... |
it cant crack it. pls help |
can anyone help. (tried smartmovie 2.72 cannot work on my pda. izzit i installed it wrongly , ls guide me.) |
@kelvintan81 Download the Latest Version of SmartMovie v2.76 from the Official site.. http://lonelycatgames.com/download/s...c_lcg_2_76.zip NOTE: You can use the Old Keygen(Supplied in the v2.72 in my earlier Post) to Register. And If you need Some Instructions on how to install the App on your PDA, Go here.. http://forum.gsmhosting.com/vbb/show...&postcount=126 |
and how about ******* chinese. i need this software to read chinese characters. can u help me with this also. thanks lots. cheers ;) |
@HuBMOBILE hi dear, do you have Theme dream for ppc registered???? |
