HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
06-06-2007, 22:32 | #3841 (permalink) |
Junior Member Join Date: May 2007
Member: 513283 Status: Offline Thanks Meter: 0 | Pocket Mechanic Pro...no buttons Running it on a T-Mobile Ameo (HTC X7500/Advantage/Dopod U1000). Installation and everything loads up fine, but no matter what version I install, the application does not show me it's execution buttons at the bottom of each Module/page, only in the 'Free RAM' module is the execution button visible and working as expected. Anyone else come across this before or know how to overcome it? It doesn't matter whether it's the cracked version or evaluation version...same result. I'd really appreciate some help on this one guys. Cheers. |
06-06-2007, 23:53 | #3842 (permalink) | |
Member: 513283 Status: Offline Thanks Meter: 0 | Solved it!! Well Partially... Quote:
06-07-2007, 00:28 | #3843 (permalink) | |
Junior Member Join Date: Mar 2006
Member: 252044 Status: Offline Thanks Meter: 0 | What happened to Opera Mobile 8.65? Quote:
06-07-2007, 08:06 | #3844 (permalink) |
Junior Member Join Date: May 2006
Member: 277257 Status: Offline Thanks Meter: 0 | My Little Tank v1.06. It's a Great game. Work for WM5 http://rapidshare.com/files/35702966...Tank.v1.06.rar |
06-07-2007, 17:52 | #3846 (permalink) |
Junior Member Join Date: Jan 2006
Member: 224279 Status: Offline Thanks Meter: 1 | phoneAlarm_Full_v_1602 Supports Windows Mobile 2003, 2003 SE, WM 5.0 and WM 6.0 Phone Edition phoneAlarm is a Today screen plugin - giving you total control over your Pocket PC Phone. Never miss an important call, SMS or Email again. Automatically switch profiles and quickly access Inbox, call history and control the state of bluetooth directly from the Today screen. Optimised for one-handed and in-car use. Quote * Provides repeating alarms on new SMS, Email, missed calls & voice messages * 7 Custom Phone profiles with manual / time-based automatic switching. * Alarm notification on weak battery and phone signal (WM 5.0 only) * Customise sound, volume and options for each alarm type in each profile * Custom Email / SMS alarms based on text or sender * Mute device and phone volume * Skinnable user interface (How to create skins) * Bluetooth and Flight mode control via profiles (also for Widcomm/Broadcomm stack) * Auto-profile change on <'ActiveSync'> (Work) and <'Power - no ActiveSync'> (Car), also based on time or Appointment category * 1-hand skin navigation and quick-dialer for last 10 numbers (only for WM 5.0 & WM 2003 SE) * Icons provide direct access to Inbox, missed call history etc. * Task-switcher pop-up to close running applications * Option to cycle radio (off/on) to change user on dual SIM * English, German, French, Italian, Spanish, Danish, Norwegian, Dutch, Czech, Polish, Hungarian, Russian, Japanese and Chinese user interface * Supports VGA display and square screen devices * Optimised for fast performance and maximum platform support * Simple installation Additional features ONLY in Full version * Location-based information (change profile dependent on current location!) * Billing calculation - keep track of your phone costs * Detailed GPRS/Data volume tracking * Call and SMS forwarding support in each profile * WLAN control via profiles * Skin rotator element to display actual information New/Fixed in v1.60.2: (Build 160) * Fix: Battery drain affecting Artemis / Neo (HTC S200) * Fix: Email alarms not repeated if using push email * Flexmail email count improved (read from Flexmail DB) * Voicemail alarm improved for some devices * Voice Command support improved * Many improvements to settings and alarm issues on WM 2003 link : http://rapidshare.com/files/35789384/phoneAlarm_Full_v_1602.rar.html |
06-07-2007, 22:12 | #3847 (permalink) | |
Member: 252044 Status: Offline Thanks Meter: 0 | Keygen give me an invalid key??? 5670 Quote:
06-08-2007, 03:53 | #3848 (permalink) |
Member: 277257 Status: Offline Thanks Meter: 0 | Another puzzle game. http://rapidshare.com/files/35874280...f.Sherwood.rar if u like zuma u'll like this! http://rapidshare.com/files/35874281/Aqua.Pearls.rar ENJOY!!!!!!!!!! |
06-11-2007, 04:18 | #3853 (permalink) |
Freak Poster Join Date: May 2003
Member: 27993 Status: Offline Thanks Meter: 1 | Hi, really need help on below: (1) i'm looking for a similiar appz like SPB Phone Suite for O2 mini....this SPB Phone suite cannot support for WM2003se, anyone can recommand similiar appz?....Any replacement for it? pls send to my email, coz I cannot download from rapidshare website here... .... email: [email protected] (2) and....why I cannot download from this rapidshare website... got error, said that I already donwload 1 file, need to wait for next time...but I already wait until now (almost 3 weeks, still said error....) .... anyone can help?.... (3) Any appz that can customise my Today's plugin display. Like create chortcut on TODAY display (shortcut for setting, games, memory etc) (4) I'm looking Profiles for Windows Mobile with keygen/crack v. 2.2.0.672 Info: http://www.winmobileapps.com/device/...c/pwm/pwm.aspx Thanks. |
06-11-2007, 20:00 | #3855 (permalink) | |
Member: 504108 Status: Offline Thanks Meter: 0 | Quote:
Point (1) I am doing some research for you regarding it, but you are out of luck... I would suggest go to this page and see what you can download for your phone... or just ask for the application you are looking for and let us try to help you... (instead a set of application like phone suite !!!! ) try http://en.softonic.com/search/spb/1111 if you like anything let search for a crak or serial.... Point (2) you are probably behind a nat or some kind of proxy that is using the same ip for more then one computer... this means you are out of luck as well because somebody is downloading from rapidshare and wile he is doing that you can not. But this does not means you can not download rapget (version 135 is the latest) do some googling and download this wonderfull soft... its not working for megaupload, but working fine for rapidshare.... Point (3) I have to be honest... I duno ( I don't know) if you find one... let me know !!!! Point (4) Windows mobile 2003 se right ? I think I saw it on the board... let me search.... if what you meant is that you could not download it, try point 2 ahahahha Pls let me know your comments brgrds mmarx | |
Palm Appz & Games | HuBMOBILE | PalmOS /HP and others | 23989 | 04-01-2023 09:46 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Whats wrong with the "Pocket pc appz & games" thread? | brayndeded | HTC & PDA WM( With Touchscreen) | 0 | 01-15-2008 18:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
Pocket PC Appz, games and more | fuzionGSM | GSM Mobile Links | 0 | 05-03-2005 15:58 |
