HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
12-19-2008, 00:55 | #6768 (permalink) | |
No Life Poster Join Date: May 2008 Location: C E B U C I T Y
Member: 774786 Status: Offline Thanks Meter: 1,455 | AE Software Button Plus v2.6.4 Quote:
Now you may choose between "long press" and "press & hold" modes! This utility extends functionality of hardware keys on Windows Mobile devices. It allows you to: intercept almost any standard button: application buttons, WM5 SoftKeys, Volume slider, Action and even Red/Green phone buttons distinguish up to 4 different keypress events on each button grabbed (single, double, triple and "long" keypresses). remap each of the keypress events to "virtual" application button or assign them directly to one of the wide set of built-in actions. As a result you may "convert" volume slider to up/down arrows, assign several essential application buttons to these "SoftKey" buttons and even assign your favorit alternative dialer to red/green phone buttons. Current list of built-in keypress actions Run Application Emulate keypress of Enter (Action), Esc and up/down/left/right keys Emulate standard application buttons "Virtual Application Button" Being specified as keypress action, "Virtual button" appears in standard Start -> Settings -> Buttons setup dialog and may be assigned here. Volume up/down Emulate Soft Keys Close (terminate) active application Switch next application Alt+Tab (switch between two last applications) Task Manager with charge level / memory summary info. Task manager may be operated with directional pad (up/down - choose application, left/action - switch to, right - terminate) or finger/stylus. You may apply filters to hide annoying applications (e.g. Phone) Ok/Close Start Menu Switch Display Off/On. Once you switch display OFF you may turn it back ON by the same keypress event or simply pressing Power On button. Switch BlueTooth Off/On Switch WiFi Off/On Vibration mode Off/On (WM5 only) Turn Off PDA Soft-Reset PDA (Soft Reset) Screen rotation Go Online / Drop DialUp connections / Trigger Online Disable "Power Off device if not used..." Switch to Today screen Clipboard operations: Select All / Copy / Cut / Paste Memory Monitor Battery Monitor/Uptime Forecast. It will show battery voltage/current/temperature if corresponding sensors are available Current Date/Time Pop-up menu with important AEBPlus actions. This feature is available in activated version only Any built-in action may be initiated by shortcut calling aebplus.exe with corresponding command line parameter Most of the actions may be initiated by running AEBPlus.exe with command line parameter. All of the action codes and ready to use shortcut files are here Compatibility This utility may be used on the following mobile devices: Windows Mobile 2003SE PocketPC and PocketPC Phone Edition Windows Mobile 2005 PocketPC and PocketPC Phone Edition Windows Mobile 2003SE Smartphone Windows Mobile 2005 Smartphone I don't think this utility is useful on Smartphone (see "Known Issues" below). Anyway be sure to backup your Smartphone before installing AEBPlus. PocketPC users are safe because of touchscreen . ! Since 2.3.2 (beta) "Safe Mode" is implemented. You may press&hold left key during startup to choose AEBPlus load options. Known Issues Some keys may not be emulated after being snaffled from system. So you will loose original functionality green phone button until it assigned to AEBPlus. AEBPlus may not work properly if hardware button click notification sound is on. If you experience problems please try to turn it off by unchecking Start -> Settings -> Sounds & Notifications -> Hardware buttons checkbox AEBPlus Home AEBPlus Screenshots CmdLine Download Purchase Activate F.A.Q. Links History Russian Mobile Credits : rUnLiu | |
The Following 2 Users Say Thank You to eon For This Useful Post: |
12-19-2008, 04:05 | #6772 (permalink) |
Junior Member Join Date: Nov 2008
Member: 905267 Status: Offline Thanks Meter: 1 | HI ALL , my ppc wm5. o2 atom have problem about calender not show appointment and set remind me already , i soft reset but not remind , who know plz help me , thanx mail... [email protected] |
The Following User Says Thank You to hopenew2008 For This Useful Post: |
12-19-2008, 08:45 | #6773 (permalink) |
Junior Member Join Date: Aug 2008
Member: 834551 Status: Offline Thanks Meter: 1 | Thank you all for the great effort in this forum. GOS and EON all I can say is WOW! You guys rock! I am hoping that someone, anyone can help me out. I need Invoice Master v2.0. I have looked everywhere with no luck. Please, Please, Please!! |
The Following User Says Thank You to ricardocabeza For This Useful Post: |
12-19-2008, 11:35 | #6775 (permalink) | |
No Life Poster Join Date: Apr 2008 Location: Trump Tower 725 Fifth Ave, NYC
Member: 759622 Status: Offline Thanks Meter: 426 | LowFat Software Mobile Invoice v5.0.5.XScale WM2003 WM5 WM6 Quote:
http://www.ziddu.com/download/2967377/wFatSoftwareMobileInvoicev5.0.5.XScaleWM2003WM5WM6 .rar.html | |
The Following User Says Thank You to GODofSERIAL For This Useful Post: |
12-19-2008, 14:51 | #6776 (permalink) |
Junior Member Join Date: Dec 2007
Member: 656085 Status: Offline Thanks Meter: 1 | Nobody had any luck finding a key for BookBag Plus? http://www.wakefieldsoft.com/bookbag/download.html |
12-19-2008, 20:32 | #6777 (permalink) |
Member: 904840 Status: Offline Thanks Meter: 1 | Can anyone get me the full version of Universal Remote CE for Windows Mobile Pocket PC 2003 SE ------------------------------------------------------------------------------------------------------------------------ UniversalRemoteCE enables the Pocket PC to function as a universal infrared remote controller which controls TV`s, VCR`s, DVD players, DSS/satellite controllers, CD players, Cable boxes, Amplifiers/Receivers, and Personal Video Recorders. UniversalRemoteCE contains Infrared profiles for more than 1000 different consumer IR devices from over 250 manufacturers, and custom profiles can be learned from a factory remote. For Pocket PC`s with a side mounted IrDA port, UniversalRemoteCE allows the device screens to be rotated so that the screen is upright while holding the Pocket PC sideways so that the IR port points in the forward direction. For demo version go to the link : http://www.getjar.com/products/1690/UniversalRemoteCE |
12-19-2008, 20:42 | #6778 (permalink) | |
Member: 759622 Status: Offline Thanks Meter: 426 | I have it Quote:
Due to my internet connection,i can't upload it...pls be patient...will upload it tomorrow ok,GoS | |
Palm Appz & Games | HuBMOBILE | PalmOS /HP and others | 23989 | 04-01-2023 09:46 |
Nokia Latest Appz & Games Section | HuBMOBILE | Nokia Multimedia | 17 | 11-21-2010 14:03 |
Whats wrong with the "Pocket pc appz & games" thread? | brayndeded | HTC & PDA WM( With Touchscreen) | 0 | 01-15-2008 18:01 |
WM5 Pocket PC Appz & Games | eboy44 | HTC & PDA WM( With Touchscreen) | 2 | 08-08-2006 22:23 |
Pocket PC Appz, games and more | fuzionGSM | GSM Mobile Links | 0 | 05-03-2005 15:58 |
