HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
10-06-2006, 22:35 | #1 (permalink) |
Junior Member Join Date: Jul 2006
Member: 321866 Status: Offline Thanks Meter: 2 | Qtek S200 problem whit sound Last edited by Anev; 10-06-2006 at 23:20. |
10-10-2006, 19:29 | #2 (permalink) |
Member: 321866 Status: Offline Thanks Meter: 2 | Qtek S200 problem whit sound ISSUE :) I have sound again .Ok i thing i find the problem ,when i plug the headset to listen my MP3s everything works just fine,BUT when unplug the headset the sound dont appear from S200 speaker behind(this was my problem) and after that i dont have any sound,BUT i start to plug and unplug the headset many times(crazy...) and SURPRISE the sound appear.My conclusion is that when i plug the headset his jack touching some parts of the PDA inside and that disable the sound |
10-18-2006, 00:32 | #3 (permalink) |
Member: 321866 Status: Offline Thanks Meter: 2 | s200 Ok,finally i leave my Qtek S200 in the shop from where i buy it to see if they can find the problem ,they tell me taht i must wait 2 weeks ,ok i will wait and then i will tell you people whats the conclusion .by the way is there someone else whit the same problem??? |
05-26-2007, 08:29 | #6 (permalink) |
No Life Poster Join Date: Jul 2003 Location: Thessaloniki,Hellas Age: 44
Member: 33547 Status: Offline Thanks Meter: 17 | Your S200 has been dropped and the small audio daughter board has a damaged connector. You also had to check the receiver (speaker) contacts. Common fault after drops |
probleme hard reset in Qtek S200. | techno-gsm | HTC & PDA WM( With Touchscreen) | 3 | 08-27-2009 22:55 |
Qtek s200 greek language ? where???? | ZetMen | JAFWM | 1 | 05-16-2006 10:56 |
SPV M600 or Qtek S200 | deYo | HTC & PDA WM( With Touchscreen) | 1 | 05-08-2006 09:16 |
Looking to buy locked PROPHET(known as Qtek S200 ) | Raskal | Wanted Products | 3 | 04-21-2006 21:35 |
How can I flash an english ROM into a a Qtek S200 which current rom isn't english? | nikolsky | JAFWM | 1 | 04-11-2006 20:20 |
