HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
06-07-2005, 19:04 | #1 (permalink) |
No Life Poster Join Date: Mar 2004 Location: Cambodia
Member: 59030 Status: Offline Thanks Meter: 165 | Sidekick II PV-100 Unlocking, HELP!! Thanks |
10-08-2005, 16:18 | #7 (permalink) |
No Life Poster Join Date: Mar 2003 Location: USA N China
Member: 24066 Status: Offline Sonork: 100.9 Thanks Meter: 574 | all of u guys first of all sidekick is made by danger www.danger.com and its original name is hiptop. for unlocking i got this info but not tested it. 1. Register at developer.danger.com. Sign in, and click on the “Downloads” tab. 2. Download the following files: • hiptop 1.1 sdk beta3 • t-mobile 1.1 color library files for build 57324 • htConsole Win32 v40194 3. Get a USB-to-USB-mini cable, and plug your SideKick into your computer. (Trim some plastic from the mini end so that it fits into the SideKick.) 4. Unzip the hiptop 1.1 sdk beta3 folder and install the drivers (located in htConsole folder) on your computer using the Add Hardware wizard. 5. Go to this URL, and enter your user ID and the device ID number from your phone's “System Info” screen. A device key to unlock your phone will be e-mailed to you. Install it by opening htConsole on your computer and typing “flash [name of device key]” in the command line. best of luck all u guys!! |
01-27-2006, 22:42 | #13 (permalink) |
Freak Poster Join Date: Nov 2004
Member: 90106 Status: Offline Thanks Meter: 3 | If you would just read a little bit closer, it's not for SP unlocking, but application unlocking. Please read more carefully in the future. ~Cheers~ P.S. As there is no open firmware, i.e., unbranded firmware, data wouldn't work even if unlocked. Only text and voice calls would work. I have the Danger programmer with firmware only for the various carriers it was released on. |
sidekick II t-mobile unlocking | .::Pieta::. | YESSIM | 2 | 10-26-2009 04:14 |
Help sidekick ii pv-100 special code | dwinex | Phone Unlocking Codes & Maps | 6 | 08-05-2009 10:39 |
Unlocking sidekick II pv-100 | visionmaster20 | HTC & PDA WM( With Touchscreen) | 1 | 11-05-2007 15:56 |
sidekick II pv-100 unlock | gsmsharing | HTC & PDA WM( With Touchscreen) | 10 | 09-09-2007 02:08 |
