HTC & PDA WM( With Touchscreen) HTC, I-mate, Qtek, HP, Hitachi, and many other Pocket PC windows CE base devices |
04-16-2010, 11:40 | #1 (permalink) |
Product Supporter Join Date: Sep 2006 Location: Kerala-India Age: 46
Member: 351924 Status: Offline Thanks Meter: 12,469 | very big problem faced X1 xperia power on time phone working fine,but when phone going to stand by mode phone going to blue display then trun off then never to power phone just remove bettery then reinsert phone power on wht is the problme? software? i make hard reset but not solved wht is next pls share solution thank u |
04-16-2010, 12:36 | #4 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: I.N.D.I.A(PUNJAB)
Member: 309398 Status: Offline Sonork: 100.1590052 Thanks Meter: 5,455 | Quote:
*** Flash X1 without PC - Micro SD Method *** This is useful if you load a bad image and cannot make an activesync connection for RUU flashing method. 0. Make sure x1 is hard-spl first 1. Make sure yr micro-sd is formatted w/ fat-32 2. rename the image file (normally "ruu_signed.nbh") to Kovsimg.nbh, copy that to the micro-sd, and put that it yr X1 3. Make sure X1 is disconnect to your PC to avoid goes to serial mode (AC power source is OK) 4. Bring x1 to boot-loader mode by turning off the x1 completely. Hold the "volume down" button on the right, and hold the power on button until you see the tri-color screen. 5. Then follow the on-screen instruction ROM > http://forum.gsmhosting.com/vbb/4102923-post1.html | |
The Following User Says Thank You to vinay_sharma For This Useful Post: |
04-16-2010, 12:39 | #5 (permalink) | |
Member: 351924 Status: Offline Thanks Meter: 12,469 | Quote:
not flashing i think rom update not solve this problems how can i flash it this device post result | |
04-16-2010, 12:43 | #6 (permalink) | |
No Life Poster Join Date: Oct 2006 Location: Hungary Age: 47
Member: 365452 Status: Offline Thanks Meter: 838 | Quote:
ROM upgrade=flashing But with this knowledge,don't try that,ask a technician to do that. BR Szig Last edited by szig; 04-16-2010 at 12:53. | |
The Following 3 Users Say Thank You to szig For This Useful Post: |
04-16-2010, 12:49 | #8 (permalink) | |
No Life Poster Join Date: Nov 2007 Location: Dubai.
Member: 625961 Status: Offline Sonork: 100.1590447 Thanks Meter: 1,285 | Quote:
thanks ur repl,y and u gived some information ,but Mr.Shijilfonotly is good Technician , he have lot of experiance in this field . if u check his profile u can see that. ....... | |
The Following User Says Thank You to WAJID PNR For This Useful Post: |
04-16-2010, 12:52 | #10 (permalink) | |
Sorry if I was rude. BR Szig And the solution is flashing/upgrading to a newer ROM,as someone mentioned above. | |
04-16-2010, 12:58 | #11 (permalink) |
No Life Poster Join Date: May 2006 Location: MOBILE SOFTZONE BHUBANESWAR IN
Member: 271478 Status: Offline Sonork: 1590868 Thanks Meter: 1,070 | i know him last 5yrs he is master in NOKIA..but some time ,its necessary to take advice , he is good in nokia but he need SE help let him help now u follow this link u can do it... *** Tutorial: Flashing ROMs (...and debranding the X1) *** - xda-developers br akhil_bbsr |
The Following User Says Thank You to akhil_bbsr For This Useful Post: |
04-16-2010, 13:02 | #12 (permalink) | |
im allready said with out nokia no idea with soft and hard I KNOW ::.::RAMJAN::.:,:.:SUBRATA:. VERY EXPERT LIKE THIS ANY ONE KNOW MORE DETAILS ABOUT THIS PLS SHARE Last edited by SHIJILFONOTLY; 04-16-2010 at 13:08. | |
04-16-2010, 13:26 | #14 (permalink) | |
No Life Poster Join Date: Jan 2008 Location: bangladesh
Member: 672312 Status: Offline Sonork: 100.1589313 Thanks Meter: 876 | Quote:
hi, SHIJILFONOTLY. if never you work in sony x1 than download sony ericsson update service open seus select model follow instruction(seus) update your set ofcourse you need high speed internet connection(minimun 256) done should it can help you.enjoy | |
04-17-2010, 08:52 | #15 (permalink) | |
No Life Poster Join Date: Jul 2006 Location: Bangladesh Age: 42
Member: 319447 Status: Offline Thanks Meter: 4,949 | Quote:
The Following 2 Users Say Thank You to .:SUBRATA:. For This Useful Post: |
6150 Lock Problem | Zeljko | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 2 | 10-16-2013 08:16 |
GId1 problem | old_man | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 10-18-2006 15:21 |
HELP: Problem with 5110 | Xabi | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 1 | 07-16-1999 00:44 |
Really big favour! | MiMiR the WiseMan | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 3 | 06-18-1999 03:21 |
