06-21-2016, 16:12 | #1 (permalink) |
No Life Poster Join Date: May 2012 Age: 28
Member: 1764566 Status: Offline Sonork: SUSPENDED Thanks Meter: 5,766 | HTC One M8 Sprint Unlock Success One Click Fire HTC Pack HTC One M8 Sprint Unlock Success Easy One Click Fire HTC Pack Free Add On Falcon box Code: Establishing secured session... Session Established.. Checking User Details.. ok Checking User Activations.. ok Checking Device State... Grant any SuperUser and/or adb RSA requests on your device Normal mode Qualcomm Detected Elapsed: 10 seconds Checking User Details.. ok Checking User Activations.. ok Checking Device State... Grant any SuperUser and/or adb RSA requests on your device Normal mode Qualcomm Detected Getting device information... Linux version 3.4.0-g5982d8b (and@AABM) (gcc version 4.7 (GCC) ) #1 SMP PREEMPT Wed Mar 18 12:45:40 CST 2015 Product Model: 831C Device CID: SPCS_004 Hardware Model: qcom Rom Main CID: SPCS_004 Build Product: htc_m8whl Rom Model ID: 0P6B70000 BaseBand Version: 1.09.20.0209 Bootloader Version: 3.19.0.0000 Device Carrier: unknown DEVICE_PROVISIONED: 1 audio.offload.buffer.size.kb: 1024 audio.offload.gapless.enabled: false camera.4k2k.enable: 0 dalvik.vm.dex2oat-Xms: 64m dalvik.vm.dex2oat-Xmx: 512m dalvik.vm.heapgrowthlimit: 192m dalvik.vm.heapmaxfree: 8m dalvik.vm.heapminfree: 2m dalvik.vm.heapsize: 512m dalvik.vm.heapstartsize: 8m dalvik.vm.heaptargetutilization: 0.75 dalvik.vm.image-dex2oat-Xms: 64m dalvik.vm.image-dex2oat-Xmx: 64m dalvik.vm.isa.arm.features: div dalvik.vm.stack-trace-file: /data/anr/traces.txt debug.composition.type: gpu debug.egl.hw: 1 debug.force_rtl: 0 debug.mdpcomp.logs: 0 debug.nfc.fw_boot_download: true debug.nfc.fw_download: true debug.sf.hw: 1 dev.alarm.id: dev.alarm.time: dev.bootcomplete: 1 dev.bootreason: dev.defaultwallpaper: /system/customize/resource/wallpapers_00.jpg dev.pm.dyn_samplingrate: 1 dev.zcharge: false dhcp.wlan0.autoip: dhcp.wlan0.dns1: dhcp.wlan0.dns2: dhcp.wlan0.dns3: dhcp.wlan0.dns4: dhcp.wlan0.gateway: dhcp.wlan0.ipaddress: dhcp.wlan0.leasetime: dhcp.wlan0.mask: dhcp.wlan0.ooxx: dhcp.wlan0.pid: dhcp.wlan0.reason: dhcp.wlan0.result: dhcp.wlan0.server: dm.hfa: 1 dm.lteforceflag: 0 dm.oobe.hfa: 000 drm.service.enabled: true gsm.adn.records.capacity: 250 gsm.cb.max.channel: 5 gsm.cdma.nv.home.country: gsm.cdma.nv.mcc: 111 gsm.cdma.nv.mnc: 11 gsm.cdma.pri.version: 2.62_003 gsm.current.phone-type: 1 gsm.network.type: Unknown gsm.nitz.time: 1466516234084 gsm.operator.alpha: gsm.operator.iso-country: gsm.operator.isroaming: false gsm.operator.numeric: gsm.sim.absent: RIL_2G_SIM_CARD gsm.sim.cbmi.channel: 4370,4379,4096,4356,50 gsm.sim.cbmir.channel: 4371,4372,4373,4378 gsm.sim.change: false gsm.sim.operator.alpha: T24 gsm.sim.operator.iso-country: in gsm.sim.operator.numeric: 405045 gsm.sim.state: READY gsm.sim.types: RIL_2G_SIM_CARD gsm.timezone.isvalid: true gsm.usim.alpha-tag.length: 14 gsm.usim.number.length: 40 gsm.version.baseband: 1.09.20.0209 gsm.version.ril-impl: Qualcomm RIL 1.0 htc.audio.beats.support2v: 1 htc.audio.global.profile: 0 htc.audio.global.speaker: 1 htc.audio.global.state: 0 htc.audio.google.volume: 10 htc.audio.hw_standby: 1 htc.audio.q6.topology: 0 htc.audio.srs.defaultbundleHS: MAX300 htc.audio.txpid: 0 htc.build.stage: 2 htc.camera.0.otp_info: 0000000000 htc.camera.1.otp_info: 0000000000 htc.camera.sensor.front_fuse1: 0 htc.camera.sensor.front_fuse2: 33 htc.camera.sensor.front_fuse3: 100 htc.camera.sensor.front_fuse4: 90 htc.camera.sensor.main_fuse1: 0 htc.camera.sensor.main_fuse2: 10 htc.camera.sensor.main_fuse3: 87 htc.camera.sensor.main_fuse4: 41 htc.htcmode.state: offline init.svc.adbd: running init.svc.adsprpcd: running init.svc.atfwd: stopped init.svc.audiod: running init.svc.bootanim: stopped init.svc.cand: running init.svc.cir_fw_update: stopped init.svc.config_bluetooth: stopped init.svc.debuggerd: running init.svc.dhcpcd_wlan0: init.svc.dmagent: running init.svc.drm: running init.svc.hcheck: stopped init.svc.healthd: running init.svc.htc_dk: running init.svc.htc_dlk: running init.svc.htc_ebdlogd_rel: stopped init.svc.hvdcp: running init.svc.installd: running init.svc.irsc_util: stopped init.svc.itsonbs: stopped init.svc.keystore: running init.svc.lmkd: running init.svc.logd: running init.svc.media: running init.svc.mpdecision: running init.svc.netd: running init.svc.netmgrd: running init.svc.network_init: stopped init.svc.p2p_supplicant: running init.svc.pnpmgr: running init.svc.qcamerasvr: running init.svc.qcom-c_core-sh: stopped init.svc.qcom-post-boot: stopped init.svc.qcom-sh: stopped init.svc.qmuxd: running init.svc.qseecomd: running init.svc.read_dap_cert: stopped init.svc.ril-daemon: running init.svc.rmt_storage: running init.svc.sdcard: running init.svc.servicemanager: running init.svc.surfaceflinger: running init.svc.thermal-engine: running init.svc.time_daemon: running init.svc.tpd_daemon: running init.svc.ueventd: running init.svc.usbdiag_init: stopped init.svc.usf-post-boot: stopped init.svc.vold: running init.svc.wcnss-service: running init.svc.wpa_supplicant: init.svc.zygote: running keyguard.no_require_sim: true lpa.decode: true lpa.use-stagefright: true media.aac_51_output_enabled: true media.stagefright.enable-aac: true media.stagefright.enable-fma2dp: true media.stagefright.enable-http: true media.stagefright.enable-player: true media.stagefright.enable-qcp: true media.stagefright.enable-scan: true mm.enable.qcom_parser: 37491 mm.enable.smoothstreaming: true mmp.enable.3g2: true net.bt.name: Android net.change: net.usb0.isharing.host2 net.gannet0.cellular: 1 net.qtaguid_enabled: 1 net.tcp.buffersize.default: 4096,87380,110208,4096,16384,110208 net.tcp.buffersize.edge: 4093,26280,70800,4096,16384,70800 net.tcp.buffersize.ethernet: 524288,1048576,3145728,524288,1048576,2097152 net.tcp.buffersize.evdo: 4094,87380,262144,4096,16384,262144 net.tcp.buffersize.gprs: 4092,8760,48000,4096,8760,48000 net.tcp.buffersize.hsdpa: 61167,367002,1101005,8738,52429,262114 net.tcp.buffersize.hspa: 40778,244668,734003,16777,100663,301990 net.tcp.buffersize.hspap: 122334,734003,2202010,32040,192239,576717 net.tcp.buffersize.hsupa: 40778,244668,734003,16777,100663,301990 net.tcp.buffersize.lte: 524288,1048576,2097152,262144,524288,1048576 net.tcp.buffersize.umts: 58254,349525,1048576,58254,349525,1048576 net.tcp.buffersize.wifi: 524288,1048576,2097152,262144,524288,1048576 net.tcp.default_init_rwnd: 60 net.usb0.isharing.host2: all net.wifi.restrit: false net.wlan0.dns1: net.wlan0.dns2: persist.camera.antibanding: 60 persist.camera.forceuseaudio: 0 persist.camera.tuning_spec: htc persist.cne.feature: 0 persist.data.netmgrd.qos.enable: true persist.debug.wfd.enable: 1 persist.demo.hdmirotationlock: false persist.fuse_sdcard: true persist.gps.qc_nlp_in_use: 1 persist.htc.audio.soundhound: 1 persist.hwc.mdpcomp.enable: true persist.hwc.partialupdate: 1 persist.loc.nlp_name: com.qualcomm.location persist.omadm.lockstate: -1 persist.omadm.pinenable: true persist.preload.common: 1 persist.radio.adb_log_on: 1 persist.radio.eons.enabled: false persist.radio.prefer.network: 10 persist.radio.snapshot_enabled: 1 persist.radio.snapshot_timer: 22 persist.radio.voice.dom.roam: 1 persist.radio.voice.int.roam: 0 persist.rild.nitz_long_ons_0: persist.rild.nitz_long_ons_1: persist.rild.nitz_long_ons_2: persist.rild.nitz_long_ons_3: persist.rild.nitz_plmn: persist.rild.nitz_short_ons_0: persist.rild.nitz_short_ons_1: persist.rild.nitz_short_ons_2: persist.rild.nitz_short_ons_3: persist.service.adb.enable: persist.speaker.prot.enable: false persist.sys.country: US persist.sys.dalvik.vm.lib.2: libart.so persist.sys.language: en persist.sys.localevar: persist.sys.pms.oobe.done: 1 persist.sys.pms.oobe.operated: 1 persist.sys.prev.powerdown: 1 persist.sys.profiler_ms: 0 persist.sys.strict_op_enable: false persist.sys.timezone: Asia/Calcutta persist.sys.usb.config: adb persist.sys.usb.hsm_detect: 0 persist.sys.vzwlogger.zygote: persist.sys.wfd.virtual: 0 persist.sys.whitelist: /system/etc/whitelist_appops.xml persist.sys.wifi.band: 0 persist.timed.enable: true persist.usb.hvdcp.detect: true persist.wifi.v6.rs.count: 5 persist.wifi.v6.rs.timeout: 5 persist.wifi.v6: true persist.zygote.preload_threads: 3 qcom.hw.aac.encoder: true ril.data.phone.type: 1 ril.data.radio_tech: ril.ecclist: 911,*911,#911,112 ril.gsm.pdplimit: 1 ril.qcril_pre_init_lock_held: 0 ril.reload.count: 1 ril.subscription.types: NV,RUIM rild.libargs: -d /dev/smd0 rild.libpath.ganlite: /system/lib/librilswitch.so rild.libpath: /vendor/lib/libril-qc-qmi-1.so rilswitch.cfilibpath: /system/lib/libcfiril.so rilswitch.vendorlibpath: /vendor/lib/libril-qc-qmi-1.so ro.aa.cidlist: SPCS_004 ro.aa.customizationid: 1053914 ro.aa.maincid: SPCS_004 ro.aa.mainsku: 654 ro.aa.modelid: 0P6B70000 ro.aa.project: M8_WHL_L50_SENSE60_SPCS_MR ro.aa.report: com ro.aa.rid: 182 ro.aa.romver: 4.25.654.14 ro.aa.skulist: 654 ro.aa.taskid: 426233 ro.adb.secure: 1 ro.allow.mock.location: 0 ro.baseband.arch: msm ro.baseband: 1.09.20.0209 ro.bc_tmo: 300 ro.bluetooth.dun: true ro.bluetooth.hfp.ver: 1.6 ro.bluetooth.remote.autoconnect: true ro.bluetooth.request.master: true ro.bluetooth.sap: true ro.board.platform: msm8974 ro.boot.baseband: 1.09.20.0209 ro.boot.batt_poweron: good_battery ro.boot.bootloader: 3.19.0.0000 ro.boot.carrier: ALL ro.boot.ddrmid: (0x1) ro.boot.dq: PASS ro.boot.emmc: true ro.boot.hardware: qcom ro.boot.keycaps: qwerty ro.boot.mode: normal ro.boot.podt: 0x3E8 ro.boot.rom_type: NORMAL ro.boot.serialno: FA44YSF04617 ro.bootloader: 3.19.0.0000 ro.bootmode: normal ro.bt.bdaddr_path: /sys/module/htc_bdaddress/parameters/bdaddress ro.bt.ble_tag: 1 ro.bt.chipset: Qualcomm WCN3680 ro.bt.profiles: 12806403 ro.bt.stack.version: 2.0 ro.bt.stack: Bluedroid ro.bt.tetheringUI: 1 ro.bt.version: 4.0 ro.build.buildline: M8WHL_Sprint_WWE_L50_CRC_Sense60_Stable_MR2_Harman ro.build.changelist: 501086 ro.build.characteristics: default ro.build.date.utc: 1426653551 ro.build.date: 三 3月 18 12:39:11 CST 2015 ro.build.description: 4.25.654.14 CL501086 release-keys ro.build.display.id: LRX22G release-keys ro.build.fingerprint: htc/sprint_wwe_harman/htc_m8whl:5.0.2/LRX22G/501086.14:user/release-keys ro.build.host: ABM108 ro.build.id: LRX22G ro.build.languageremove: ro.build.product: htc_m8whl ro.build.project: M8_WHL_L50_SENSE60_SPCS_MR:426233 ro.build.sense.version: 6.0 ro.build.sku: Sprint WWE Harman ro.build.tags: release-keys ro.build.type: user ro.build.user: buildteam ro.build.version.all_codenames: REL ro.build.version.codename: REL ro.build.version.htcsdk: HTCExt:HTCExtension_Sense60_L_2;SDK:6.55;hdkbase:19.2 ro.build.version.incremental: 501086.14 ro.build.version.release: 5.0.2 ro.build.version.sdk: 21 ro.carrier: unknown ro.cdma.home.operator.alpha: Sprint ro.cdma.home.operator.numeric: 310120 ro.cdma.prl: 00000 ro.chameleon.HomeOnly.enable: 0 ro.chameleon.MenuDisplay.enable: 1 ro.chk_prd: 1 ro.cid: SPCS_004 ro.com.android.dataroaming: false ro.com.android.dateformat: MM-dd-yyyy ro.com.google.clientidbase.am: android-sprint-us ro.com.google.clientidbase.ms: android-sprint-us ro.com.google.clientidbase.yt: android-sprint-us ro.com.google.clientidbase: android-htc ro.com.google.gmsversion: 5.0_r2 ro.config.alarm_alert: Alarm_Classic.ogg ro.config.low_ram: false ro.config.notification_sound: pixiedust.ogg ro.config.ringtone: Ring_Synth_04.ogg ro.crypto.fuse_sdcard: true ro.crypto.state: unencrypted ro.cwkey: SPCS_004 ro.dalvik.vm.native.bridge: 0 ro.data.large_tcp_window_size: true ro.debuggable: 0 ro.devicerev: 5 ro.efuse_info: FL ro.engid: 0 ro.factorytest: 0 ro.fuse_sdcard: true ro.gps.agps_provider: 1 ro.hardware: qcom ro.hdmi.enable: true ro.hlog_ofs: 628 ro.home.operator.carrierid: SPRINT ro.htc.bluetooth.sap: false ro.htc.checkin.delay: 0 ro.htc.htcmode.socket.type: LocalSocket ro.htc.preprocess: SPRINT_ITSON ro.hw_id: unknown ro.hwui.renderer.disable_opaque: true ro.itson.path: /carrier/itson/ ro.lb: 0 ro.mid: 0P6B70000 ro.net.apn_type.INTERNET: 53:enableINTERNET ro.net.apnroamingwhitelist: fota ro.net.apnwhitelist: none ro.net.net_type.USBNET: 51 ro.omadm.encryptenable: 1 ro.omadm.localsocket: 1 ro.omadm.lockstate: -1 ro.omadm.pinenable: true ro.onecid: 1 ro.op: 0 ro.opengles.version: 196608 ro.pagesize: 2048 ro.phone.min_match: 8 ro.pip.gated: 0 ro.product.bluetooth: 4.0 ro.product.board: MSM8974 ro.product.brand: htc ro.product.cpu.abi2: armeabi ro.product.cpu.abi: armeabi-v7a ro.product.cpu.abilist32: armeabi-v7a,armeabi ro.product.cpu.abilist64: ro.product.cpu.abilist: armeabi-v7a,armeabi ro.product.device: htc_m8whl ro.product.display_resolution: 5 inch 1080p resolution ro.product.front_camera: 5M ro.product.hwreset.timer1: 6 ro.product.hwreset.timer2: 9 ro.product.hwreset: 1 ro.product.locale.language: en ro.product.locale.region: US ro.product.main_camera: HTC UltraPixel Camera ro.product.manufacturer: HTC ro.product.model: 831C ro.product.name: sprint_wwe_harman ro.product.ram: 2GB ro.product.version: 4.25.654.14 ro.product.wifi: 802.11 a/b/g/n/ac ro.prot: true ro.qc.bluetooth.stack: bluedroid ro.qc.sdk.audio.fluencetype: none ro.qc.sdk.audio.ssr: false ro.qc.sdk.camera.facialproc: false ro.qc.sdk.gestures.camera: false ro.qc.sdk.sensors.gestures: true ro.qf_st: 1 ro.qualcomm.bluetooth.dun: false ro.qualcomm.bluetooth.ftp: true ro.qualcomm.bluetooth.hfp.wbs: false ro.qualcomm.bluetooth.hfp: true ro.qualcomm.bluetooth.hsp: true ro.qualcomm.bluetooth.map: true ro.qualcomm.bluetooth.nap: true ro.qualcomm.bluetooth.opp: true ro.qualcomm.bluetooth.pbap: true ro.qualcomm.bt.hci_transport: smd ro.rb_dly: 0 ro.revision: 0 ro.ril.carrier: 3 ro.ril.disable.cpc: 1 ro.ril.disable.fd.plmn.prefix: 23402,23410,23411,23420 ro.ril.enable.a53: 1 ro.ril.enable.gea3: 1 ro.ril.enable.pre_r8fd: 1 ro.ril.enable.r8fd: 1 ro.ril.enable.sdr: 0 ro.ril.hsdpa.category: 14 ro.ril.hsupa.category: 6 ro.ril.hsxpa: 4 ro.ril.oem.ecclist: 911 ro.ril.set.mtusize: 1422 ro.ril.svdo: false ro.ril.svlte1x: false ro.runtime.firstboot: 1466516089740 ro.secure: 1 ro.serialno: FA44YSF04617 ro.setupwizard.mode: OPTIONAL ro.sf.lcd_density: 480 ro.sf: 0 ro.storage_encryption_type: 2 ro.storage_structure: 10 ro.td: 0 ro.td_ofs: 328 ro.telephony.call_ring.multiple: false ro.telephony.default_network: 8 ro.telephony.ipv6_capability: 1 ro.ur: unknown ro.usb.tetheringUI: 1 ro.usb_host: 1 ro.use_data_netmgrd: true ro.vendor.extension_library: /vendor/lib/libqc-opt.so ro.wifi.channels: ro.wifi.hotspotUI: 1 ro.zygote: zygote32 selinux.reload_policy: 1 service.bootanim.exit: 0 supolicy.loaded: 1 sys.aem.debug.flag: false sys.aem.enabled: false sys.aem.registered: false sys.boot_completed: 1 sys.psaver.bright: false sys.psaver.gap: 15 sys.psaver.haptic: false sys.psaver.stat: normal sys.settings_global_version: 5 sys.settings_secure_version: 30 sys.settings_system_version: 6 sys.stt.ssr.no_prompt: 1 sys.sysctl.extra_free_kbytes: 24300 sys.usb.config: adb sys.usb.state: adb sys.zygote.first.init: 1 telephony.lteOnCdmaDevice: 1 tunnel.audio.encode: true tunnel.audiovideo.decode: true tunnel.decode: true use.voice.path.for.pcm.voip: true vidc.debug.level: 3 vold.post_fs_data_done: 1 wifi.country: IN wifi.interface: wlan0 wifi.miracastconcurrent.scan: WCN3680 wifi.softap.interface: wlan0 wifi.softapconcurrent.interface: softap.0 wifi.supplicant_scan_interval: 15 wifi.wpa_supp_ready: 1 wlan.custom.assocmode: 0 wlan.driver.ath: 0 wlan.driver.status: ok wlan.sim.enabled: 1 Done Elapsed: 10 seconds Checking User Details.. ok Checking User Activations.. ok Checking Device State... Grant any SuperUser and/or adb RSA requests on your device Normal mode Qualcomm Detected Starting Htc Sprint Process.. Manufacturer : HTC Model : 831C Android Version : 5.0.2 Platform : msm8974 Release Tags : release-keys Network Type : Unknown Operator : Sprint Ril-Imp : Qualcomm RIL 1.0 Region : US Hardware : qcom Baseband : 1.09.20.0209 Checking Device State... Grant any SuperUser and/or adb RSA requests on your device Normal mode Qualcomm Detected ## Check device screen if SU needs your permission ## Checking SuperUser package... Checking Executable SuperUser(bin)... Executable SuperUser file found ++ Device is ROOT ++ Executing Sys Check.. Reading Data...(DO NOT DISCONNECT DEVICE) Sending data to device.... Data sent successfully Sending data to device.... Data sent successfully Decrypting Data... Unlocking Success.. Msl/Spc : 99xxxxxxxxxxxxxxx_Ì»‘ ĵ¿mÄŽbžLT Elapsed: 31 seconds |
The Following 13 Users Say Thank You to IMRAN_ANSARI For This Useful Post: |
