03-15-2018, 07:42 | #1 (permalink) |
Product Manager Join Date: Oct 2001 Location: GSMFABRICA Age: 43
Member: 6594 Status: Offline Sonork: 100.27285 Thanks Meter: 22,500 | eMMC Pro All in One Version 1.05 - New Models added [15 March 2018] Advanced eMMC Repair eMMC PRo - Universal Device Programmer |
The Following 19 Users Say Thank You to Electroboys For This Useful Post: |
03-15-2018, 20:07 | #3 (permalink) | |
No Life Poster Join Date: Aug 2013 Location: Yangon Age: 29
Member: 2006794 Status: Offline Sonork: 100.1664636 Thanks Meter: 164 | Quote:
Sent from my MI 6 using Tapatalk | |
03-15-2018, 22:35 | #4 (permalink) |
Freak Poster Join Date: May 2006 Location: A
Member: 272591 Status: Offline Sonork: 100.1579461 Thanks Meter: 45 | you can add some convenience to display the correct name of the chip, which configurations are recorded. section GP1 you can create and how to write to it? Code: +CID:1501004D 41473247 4300E6D5 B074B09C Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x4D4147324743 (MAG2GC) Product revision:0x00 Product serial number:0xE6D5B074 Manufacturing date:0xB0 CRC7 checksum:0x9C +CSD:D0270132 0F5903FF F6DBFFEF 8E40400C CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFDB Min. read current @ VDD min:0x6 Max. read current @ VDD min:0x6 Min. write current @ VDD min:0x6 Max. write current @ VDD min:0x6 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:3 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x6 Not used, always ’1’:0 +EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x01D5A000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x04 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x04 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x00 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0003AB PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x00 Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x00 Basic Information: Extended CSD revision: User Data Area Size: 15028MB(0x3AB400000) Boot Partition Size: 4096KB RPMB Size: 512KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB Begin to factory reset factory reset finished. Min GP size is 8192K PARTITION finished successfully +CID:1501004D 41473247 4300E6D5 B074B09C Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x4D4147324743 (MAG2GC) Product revision:0x00 Product serial number:0xE6D5B074 Manufacturing date:0xB0 CRC7 checksum:0x9C +CSD:D0270132 0F5903FF F6DBFFEF 8E40400C CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFDB Min. read current @ VDD min:0x6 Max. read current @ VDD min:0x6 Min. write current @ VDD min:0x6 Max. write current @ VDD min:0x6 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:3 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x6 Not used, always ’1’:0 +EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x01D32000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x00 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x04 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x04 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x00 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0003AB PARTITIONS_ATTRIBUTE[156]:0x02 PARTITION_SETTING_COMPLETED[155]:0x01 GP_SIZE_MULT[154:143]:0x000000000000000000000005 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x00 Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x00 Basic Information: Extended CSD revision: User Data Area Size: 14948MB(0x3A6400000) Boot Partition Size: 4096KB RPMB Size: 512KB General Purpose Partition 1 Size: 40960KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB |
03-15-2018, 22:43 | #5 (permalink) |
Member: 272591 Status: Offline Sonork: 100.1579461 Thanks Meter: 45 | with GPU 1 figured out, and how to expose the configuration from where it is for example this Code: Boot from: no boot , width: 4 bit Boot Partition [179] / Bus Config [177] : 0x00 / 0x01 H/W Reset Function [162] : 0x00 , RST_n signal is temporarily disabled Partition setting [PARTITION_SETTING_COMPLETE] : 0x01 EMMC Permanent / Temporary Write Protection : No / No |
03-16-2018, 02:27 | #6 (permalink) |
No Life Poster Join Date: Jun 2011 Location: PILIPINAS
Member: 1604158 Status: Offline Sonork: 100.1614304 Thanks Meter: 122 | if the most pinout is in the chipset not in board.. it's dangerous move to make jtag.. provide us pinout in the board or via usb repair boot.. |
