Go Back   GSM-Forum > Product Support Sections > Special Solutions / Services / WebShop > GSMFABRICA Products
Old 01-16-2017, 10:46   #1 (permalink)
Electroboys's Avatar
Member: 6594
Sonork: 100.27285
Thanks Meter: 22,500
Arrow eMMC Pro V1.08 - New Features
eMMC Pro 1.08 Release Notes
[16 JAN 2017]
We are trying to make more powerful eMMC software with every each update
There are alof of optimizations and progres based on customers requests and demands.
  1. # Detection Routines improved .
  2. # SW Default Set as "12 Mhz"
  3. # Format Functions added
  4. # Partitioning / GP Area Partitioning features added.
  5. # Config Features Added .
  6. # Soft Erase Function Added .
  7. # Deep Erase Function Added .
  8. # UI - Full Flash mode added .
  9. # UI - Partition mode added .
  10. # UI - Selection USER ( ROM1 ) .
  11. # UI - Selection BOOT1 ( ROM2 ) .
  12. # UI - Selection BOOT2 ( ROM3 ) .
  13. # UI - CID Parsing .
  14. # UI - CSD Parsing .
  15. # UI - Config Added .
  16. # UI - GP Area Partition Settings added .
  17. # New Firmware Released Version = 2016122615000000
When you first run eMMC Pro V1.08 sw will update your firmware .
With the new firmware we have implemented better detection and more features.
and makes it more stable and alot more powerful .
[Config Features Added]
We have added Format , Soft Erase , Deep Erase Function in the software
[Soft Erase]
Provides a host explicit erase function.
The erasable unit of the eMMC is the “Erase Group”;
Erase group is measured in write blocks which are the basic writable units of the Device.
Once the erase command completes successfully, the device address range that was erased shall behave-
as if it was overwritten with all ‘0’ or all ‘1’ depending on the different memory technology.
[Deep Erase]
In addition to the Soft Erase command there is also an optional Deep Erase command.
The Deep Erase command differs from the Soft Erase command in that it requires the device to -
execute the erase operation on the memory array when the command is issued and
requires the device and host to wait until the operation is complete.
This should be executed the Deep Erase command with caution to avoid unintentional data loss.
[Solution for :]
  1. # Wipe failed on MTK devices will be easily fixed with this option.
  2. # Corrupt Disk not functioning will be solved such as Disks
    "not write protected" but devices can not be written firmware.
[Partitioning :]
General Purpose Area Partition, RPMB Partitions can be configured
General Purpose Partitions can be programmed by the setting the corresponding-
values defined on eMMC Pro Software and written into the Extended CSD registers
only once in the device life-cycle.
[UI Improvements : ]
[Full Flash mode : ]
When the file is selected with Full Flash Mode .
You are able to write the complete file as one and whole !
[Partition mode : ]
Partitions of the Dump File Selected will be displayed on the eMMC Pro UI
By selecting each partition and selected partitions will be written into target device .
[Frequency Set : ]
12 Mhz as Default
[Area : ]
USER ( ROM1 )
BOOT1 ( ROM2 )
BOOT2 ( ROM3 )
In order to comply among the eMMC Boxes and for easy understanding for our users .
We have identified the on the software ROM1 , ROM2 and ROM3 for each Area
There is full access (R/W) and all the features are compatible with eMMC Pro.
[CID / CSD Parsing : ]
There is alot of information is provided with the CID and CSD Values
such as Manufacturer Details , Device Configuration , Write Protection ,
Serial Number , etc.. Complete device specifications of the eMMC
Complete identification of the eMMC will be displayed in eMMC Pro UI .
[eMMC Pro Support page : ]
We are sorry we had a down time during the new year season
but we recovered everything is perfect now .
Thanks for all the feedbacks.
Thank you for all eMMC Pro Customers to keep sending us requests and suggestions .
There is a lot more to come
Best Regards
eMMC Pro Team
Advanced eMMC Repair
eMMC PRo - Universal Device Programmer
The Following 28 Users Say Thank You to Electroboys For This Useful Post:
Old 01-16-2017, 10:46   #2 (permalink)
Member: 6594
Sonork: 100.27285
The Following 12 Users Say Thank You to Electroboys For This Useful Post:
Old 01-16-2017, 11:16   #3 (permalink)
Fast Unlocker's Avatar
Member: 95960
Sonork: 100.1574721
Thanks Meter: 14,047
seems you still uploading cant got it from support
The Following 3 Users Say Thank You to Fast Unlocker For This Useful Post:
Old 01-16-2017, 11:47   #4 (permalink)
Member: 2547620
Thanks Meter: 3,431
eMMC Pro V1.08 Alternative Download Link
The Following 7 Users Say Thank You to FAT-ON For This Useful Post:
Old 01-16-2017, 13:17   #5 (permalink)
Faisal_Computer's Avatar
Member: 151871
Thanks Meter: 71,421
yes. Great update. already tested while it was on beta !!
The Following 5 Users Say Thank You to Faisal_Computer For This Useful Post:
Old 01-16-2017, 14:51   #6 (permalink)
Member: 1886712
Thanks Meter: 53
thanks for new update
i check and post
The Following 2 Users Say Thank You to aliusmanbava For This Useful Post:
Old 01-16-2017, 15:20   #7 (permalink)
Member: 1886712
Thanks Meter: 53
htc desire 816 phone not detect i try other box detecting good
eMMC PRO
eMMC Pro - eMMC Programmer Version V1.08
FIRMWARE(0x4D41494E) version:2016122615000000
SN:5DF371F02AD356DE
eMMC Pro is Ready ..
Connect a Device and Click "Detect"
Detect eMMC failed(16)).
The Following User Says Thank You to aliusmanbava For This Useful Post:
Old 01-16-2017, 15:48   #8 (permalink)
vickyjadhav6161's Avatar
Member: 2386560
Sonork: NOW I DON'T USE IT
Thanks Meter: 561
Hello fat-on bro,
what about emmc fimware update and motorola dead cid repair?????????last time you have promiss me that you wiill add in next update....what happen with this matter...
The Following 3 Users Say Thank You to vickyjadhav6161 For This Useful Post:
Old 01-16-2017, 16:28   #9 (permalink)
Member: 2547620
Thanks Meter: 3,431
eMMC PRO
SN:5DF371F02AD356DE
Is it model "T" ?
Originally Posted by vickyjadhav6161 View Post
Hello fat-on bro,
Hi
Most work is done ,
in order to control dev flow we need too see feedbacks and push another update
CID patch , Firmware update is connected to same update Samsung Vendor Commands and consequences
So please be patient , we will deliver another update very soon
Also some moto update very soon
Best regards
F4T0N
The Following 2 Users Say Thank You to FAT-ON For This Useful Post:
Old 01-16-2017, 19:12   #10 (permalink)
otherboy123's Avatar
Member: 2006794
Sonork: 100.1664636
Thanks Meter: 164
Window 64bit can't use
The Following User Says Thank You to otherboy123 For This Useful Post:
Old 01-17-2017, 02:13   #11 (permalink)
ngocdiemmobile's Avatar
Member: 1781157
Sonork: 100.1624851
Thanks Meter: 167
64 bit win 7 working ok
The Following 3 Users Say Thank You to ngocdiemmobile For This Useful Post:
Old 01-17-2017, 06:28   #12 (permalink)
Member: 325999
Thanks Meter: 113
Thanks for wonderful update , please need resume support for download .
Regards
Old 01-17-2017, 06:50   #13 (permalink)
citra kalasan's Avatar
Member: 389262
Thanks Meter: 46
when EMMC pro support FFU/tespoint for hinyx and sandisk...?
is world be waiting for this
The Following User Says Thank You to citra kalasan For This Useful Post:
Old 01-17-2017, 07:51   #14 (permalink)
Member: 844866
Thanks Meter: 22
err cmd
What About This ???
The Following User Says Thank You to zacxrhay For This Useful Post:
Old 01-17-2017, 08:45   #15 (permalink)
Member: 1886712
Thanks Meter: 53
my phone model 816w pinouts same check my words other box detect good but emmc pro not detect
816t and 816w dump same?????
Page generated in 0.23090 seconds with 8 queries
