06-28-2017, 14:30 | #3 (permalink) |
Freak Poster Join Date: Nov 2012 Location: batna.algeria
Member: 1834802 Status: Offline Sonork: 100.1659078 Thanks Meter: 89 | I WRITE DUMP FROM EASYJTAG BUT PHONE ALWAYS DEAD BOOT I HAVE MY ORGINAL BACKUP USING EASY JTAG BAUT SOM PROBLEM PHONE WAS WORKING BUT HAS CROM SERVICE LOCK AND DRK PROBLEM WHEN I WRITE DUMP PHONE TOTALY DEAD CAN YOU HELP ME I HAVE SOME PROBLEM WITH LG D325 OTHER BOX FAILED TO REPAIR BOOT BUT YOUR BOX DO IT ALL TIME THIS THE LOG IS THERE ANY ERROR eMMC PRO eMMC Pro - eMMC Programmer Version V1.09 FIRMWARE(0x4D41494E) version:2017052915210004 SN:XXXX19444BX Connect a Device and Click "Detect" Detect eMMC failed(60)). Detect eMMC failed(60)). . CID:0x15010051 0x33313641 0x4200D9DB 0x9BA6536C Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x513331364142 (Q316AB) Product revision:0x00 Product serial number:0xD9DB9BA6 Manufacturing date:0x53 CRC7 checksum:0x6C CSD:0xD0270132 0x0F5903FF 0xF6DBFFEF 0x8E40400C CSD structure:0x3 System specification version:0x4 Data read access-time 1:0x27 Data read access-time 2:0x1 Max. bus clock frequency:0x32 Card command classes:0x0F5 Max. read data block length:0x9 (512) Partial blocks for read allowed:0 Write block misalignment:0 Read block misalignment:0 DSR implemented:0 Device size:0xFFF Min. read current @ VDD min:0x6 Max. read current @ VDD min:0x6 Min. write current @ VDD min:0x6 Max. write current @ VDD min:0x6 Device size multiplier:0x7 Erase group size:0x1F Erase group size multiplier:0x1F Write protect group size:0xF Write protect group enable:1 Manufacturer default ECC:0 Write speed factor:3 Max. write data block length:0x9 Partial blocks for write allowed:0 Content protection application:0 File format group(R/W):0 Copy flag (OTP)(R/W):1 Permanent write protection(R/W):0 Temporary write protection(R/W):0 File format(R/W):0 ECC code(R/W):0 CRC(R/W):0x6 Not used, always ’1’:0 RCA:0x00000000 EXT_CSD information parsing: FFU features:0x00 BOOT_SIZE_MULTI[226]:0x20 HC_ERASE_GRP_SIZE[224]:0x01 ERASE_TIMEOUT_MULT[223]:0x01 SEC_COUNT(EXT_CSD[215:212]:0x01D5A000) CARD_TYPE(EXT_CSD[196]):0x57 CSD_STRUCTURE(EXT_CSD[194]):0x02 EXT_CSD_REV(EXT_CSD[192]):0x07 PARTITION_CONFIG[179]:0x00 Device not boot enabled (default) BOOT_CONFIG_PROT[178]:0x00 BOOT_BUS_CONDITIONS[177]:0x00 ERASE_GROUP_DEF[175]:0x00 BOOT_WP[173]:0x00 USER_WP[171]:0x10 FW_CONFIG[169]:0x00 RPMB_SIZE_MULT[168]:0x20 WR_REL_SET[167]:0x1F WR_REL_PARAM[166]:0x14 SANITIZE_START[165]:0x00 BKOPS_START[164]:0x00 BKOPS_EN[163]:0x00 RST_n_FUNCTION[162]:0x01 HPI_MGMT[161]:0x00 PARTITIONING_SUPPORT[160]:0x07 MAX_ENH_SIZE_MULT[159:157]:0x0003AB PARTITIONS_ATTRIBUTE[156]:0x00 PARTITION_SETTING_COMPLETED[155]:0x00 GP_SIZE_MULT[154:143]:0x000000000000000000000000 ENH_SIZE_MULT[142:140]:0x000000 ENH_START_ADDR[139:136]:0x00000000 SEC_BAD_BLK_MGMNT[134]:0x00 PRODUCTION_STATE_AWARENESS[133]:0x00 TCASE_SUPPORT[132]:0x00 PERIODIC_WAKEUP[131]:0x00 PROGRAM_CID_CSD_DDR_SUPPORT[130]:0x01 NATIVE_SECTOR_SIZE[63]:0x00 USE_NATIVE_SECTOR[62]:0x00 DATA_SECTOR_SIZE[61]:0x00 INI_TIMEOUT_EMU[60]:0x00 Class6_CTRL[59]:0x00 DYNCAP_NEEDED[58]:0x00 EXCEPTION_EVENTS_CTRL[57:56]:0x00 EXCEPTION_EVENTS_STATUS[55:54]:0x00 EXT_PARTITIONS_ATTRIBUTE[53:52]:0x00 CONTEXT_CONF[51:37]:0x000000000000000000000000000000 PACKED_COMMAND_STATUS[36]:0x00 PACKED_FAILURE_INDEX[35]:0x00 POWER_OFF_NOTIFICATION[34]:0x00 CACHE_CTRL[33]:0x00 FLUSH_CACHE[32]:0x00 MODE_CONFIG[30]:0x00 MODE_OPERATION_CODES[29]:0x00 FFU_STATUS[26]:0x00 PRE_LOADING_DATA_SIZE[25:22]:0x00000000 MAX_PRE_LOADING_DATA_SIZE[21:18]:0x00 PRODUCT_STATE_AWARENESS_ENABLEMENT[17]:0x00 SECURE_REMOVAL_TYPE[16]:0x09 Basic Information: Extended CSD revision: User Data Area Size: 15028MB(0x3AB400000) Boot Partition Size: 4096KB RPMB Size: 4096KB General Purpose Partition 1 Size: 0KB General Purpose Partition 2 Size: 0KB General Purpose Partition 3 Size: 0KB General Purpose Partition 4 Size: 0KB Erase group size: 512KB |
07-19-2017, 09:01 | #5 (permalink) |
No Life Poster Join Date: Mar 2016
Member: 2547620 Status: Offline Thanks Meter: 3,431 | This device had wrong pinout with other boxes . VCC and VCCq was reversed , we fixed it .. How did you connect with the wrong pinout ? you had the fix ? by the way we have the new dump. SM-G6000 G6000ZCU1AOK5 - 5.1.1 ( uploading to support area ) My phone was 8 GB edition of this and you have 16 GB edition in your hand . Code: CID:0x15010051 0x4E313641 0x420BE31D 0xC0FAA2A8 Manufacturer ID:0x15 Device/BGA:1 (removable:1 BGA:2 POP:3) OEM/Application ID:0x00 Product name:0x514E31364142 (QN16AB) Extended CSD revision: User Data Area Size: 7456MB(0x1D2000000) Boot Partition Size: 4096KB RPMB Size: 512KB F4T0N |
