11-27-2018, 17:17 | #168 (permalink) |
No Life Poster Join Date: Jan 2002 Location: tunis,Tunisia Age: 54
Member: 8228 Status: Offline Sonork: 12399830 Thanks Meter: 136 | hi Lumia 520 tring to unlock get error : *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. i flashed but always the same error ! Any help |
12-05-2018, 17:48 | #170 (permalink) |
No Life Poster Join Date: May 2003 Location: POLAND
Member: 27761 Status: Offline Thanks Meter: 55 | hi, i just unlock lumia 635 RM-975 phone i had to reflash it to lower version so now when simlock is OFF can i reflash phone to same version like it was before ? I wonder after reflash simlock will back. |
12-06-2018, 12:59 | #171 (permalink) | |
Member: 27761 Status: Offline Thanks Meter: 55 | Quote:
to clarify you have to flash FFU file with lower version then you have now (older version will allow PC to detect lumia as a device when it's switched to test mode while new versions trick it unidentified device in PC device manager ), flashing you have to make using nokia client tool not original nokia recovery | |
01-10-2019, 15:36 | #175 (permalink) |
Crazy Poster Join Date: Nov 2015 Location: Chittagong
Member: 2491964 Status: Offline Sonork: 100.1672132 Thanks Meter: 21 | Hard Reset Nokia Lumia 430,435,520,530,535,630,635,720 https://www.youtube.com/watch?v=ZOoYRsdw1z4&t=2s |
02-08-2019, 16:13 | #176 (permalink) |
Major Poster Join Date: Feb 2008 Location: San Salvador
Member: 703919 Status: Offline Thanks Meter: 3 | Server down? Hi. Can help me? Have 2 days with this message: *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 435 (RM-1070) Sw Version: 02075.10000.15215.36107 Product Code: 059W9P2 IMEI: 357782062943446 NETWORK LOCK: ACTIVE PHONE LOCKED An error while downloading Test Mode DataPackageInfo. Reason: No es posible conectar con el servidor remoto Testing connection with Unlock Server ... FAIL Thanks for your help |
02-09-2019, 17:04 | #177 (permalink) | |
No Life Poster Join Date: Dec 2008 Location: Apple pocket Age: 32
Member: 936020 Status: Offline Sonork: 100.1611462 Thanks Meter: 2,771 | Quote:
hope all will be ok | |
02-22-2019, 21:01 | #178 (permalink) |
Junior Member Join Date: Dec 2018
Member: 2880598 Status: Offline Thanks Meter: 0 | Can you help me please. I have changed my computer, changed the firmware of the phone several times and I still get the same error, help me please. *** Welcome to Client Lumia 8 Plus Series | Version 4.5.0.1 *** Hints 1. Your phone is not listed? Check if drivers (Settings->Drivers) are installed. 2. Need view phone info? Connect it and press 'Get Info' button. 3. Select as many rows as you want and press Ctrl+C to copy it content. 4. More than one phone connected? Connect the device to unlock. 5. Use reload button for rescan the connected devices. Application info Version 4.5.0.1 Copyright © 2017 Created by dk Enjoy it ;-) Updating devices list. Done! Testing connection with Unlock Server ... OK Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 635 (RM-975) Sw Version: 02173.00000.15154.50006 Product Code: 059W663 IMEI: 35645406438XXXX NETWORK LOCK: ACTIVE PHONE LOCKED Connecting to server... Loading device info... Setting phone to TestMode... Updating devices list. Done! Updating devices list. Done! Flashing RAM Image. Image flashed successfuly, now it will boot. If takes more than 5 seconds, please reconnect USB. Updating devices list. Done! Updating devices list. Done! Connecting to device... Ok Sending data to server... Process completed with ERRORS. ***Wait for reboot to confirm the SIMLock status.[Reasons] 1. An error occurred while passing secure commands to terminal ***Hints*** 1. There are communication errors between PC and phone. Try restart the unlock process. Restarting the phone... Updating devices list. Done! Loading device info (Client Version 4.5.0.1). Done! ***Device Info Model: Lumia 635 (RM-975) Sw Version: 02173.00000.15154.50006 Product Code: 059W663 IMEI: 35645406438XXXX NETWORK LOCK: ACTIVE Updating devices list. Done! PHONE LOCKED SIM Unlock Failed *HINT: Please reflash it using LumiaRecoveryTool and try again the unlock procedure. |
02-23-2019, 06:05 | #179 (permalink) | |
open ticket i will refund you | |
