Go Back   GSM-Forum > GSM & CDMA Phones / Tablets Software & Hardware Area > Xiaomi > Xiaomi Hardware Repair
Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help
Old 09-04-2021, 15:25   #1 (permalink)
Member: 2570917
Thanks Meter: 3
poco m3 Dead ! qdloader 9008
i took my first poco m3 two month ago and i tried to fix it but whatever i did was not good enough and the phone came back with the same problem .
i have been trying since and it could not solve the problem . i have tried these solution on many devices maybe near to 70 .
these are what i have done since today
1. hit the power ic (PMI632-902)
2. changed the PMI632-902
3. the ic temperature is about 100' degree while fast charging so i tried one ic with no fast charge (PMI632-502) and tried to cool it down
4. reball the CPU and UFS memory
5. flash with hydra, UMT , UFI and even with auth account
6. made OVP jumper
7. tried to format UFS memory and write dump again by EasyJtag and Medusa pro II
everything i did was useless and the problem comes back in a few days .
is there any solution to this ISSUE caused by XIAOMI team ??
and they do not give any answer to this
The Following 3 Users Say Thank You to mesour.m For This Useful Post:
Old 09-16-2021, 15:47   #2 (permalink)
Crazy Poster
Member: 233242
Sonork: www.sonork.com
Thanks Meter: 5
poco m3 Dead
hi i have 2 phones with the same problem
I think there is no solution
The Following User Says Thank You to sebouh For This Useful Post:
Old 09-17-2021, 13:07   #3 (permalink)
Member: 689942
Thanks Meter: 312
https://www.youtube.com/watch?v=J8kFdOPonds ....
The Following 3 Users Say Thank You to celltellpb For This Useful Post:
Old 10-06-2021, 14:21   #4 (permalink)
Member: 913338
Thanks Meter: 6
https://www.instagram.com/p/CUsDeP4D...um=share_sheet
The Following 3 Users Say Thank You to abil_jef For This Useful Post:
Old 10-21-2021, 03:14   #5 (permalink)
Member: 2958818
Thanks Meter: 25
no solution its a board issue
Old 10-30-2021, 15:22   #6 (permalink)
PiratesGSMKing's Avatar
Member: 2684815
Thanks Meter: 133
Just Disconnect betray Connector , after it Charge Full betray 100% Working
Old 11-26-2021, 09:21   #7 (permalink)
Member: 1725869
Sonork: 100.1613228
Red face
sir poco m3 power on but automatic on/off
Old 12-05-2021, 14:08   #8 (permalink)
Member: 2990085
Thanks Meter: 8
POCO M3 - Reboot issue solved!
Hello guys,
This solved the deadboot issue on my end.
Just remove the capacitor encircled below and you will then be able to reboot your unit freely.
Thanks!
The Following 8 Users Say Thank You to nep.malabanan For This Useful Post:
Old 12-20-2021, 14:35   #9 (permalink)
Moderator
chand_gee's Avatar
Member: 668050
Sonork: 100.1656307
Thanks Meter: 991
6. made OVP jumper
hope someone will catch the ant.....
[IMG][/IMG]
Page generated in 0.18367 seconds with 9 queries
