Xiaomi Hardware Repair General Xiaomi phones discussion, firmwares, solution, help |
01-15-2020, 15:11 | #1 (permalink) |
Junior Member Join Date: Nov 2017
Member: 2774789 Status: Offline Thanks Meter: 1 | Xiaomi Redmi 4a battery drain i searched the forum to try and solve my problem, but no luck. I have Xiaomi Redmi 4a and it has problem with battery drain (even when turned off). I disassembled the device, and disconnected everything from mainboard, connected external power supply to the battery connector, and i found that turned off mainboard uses about 0,2 amps of current... What can be the solution to this power drain? Thank you in advance. |
