Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > MXKEY (by Alim Hape) > MXKEY Nokia Flasher and Unlocker (by Alim Hape)
Old 03-08-2010, 09:44   #1 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
.::Solution for::. Security Test Fail .: HERE :.
SIMLOCK valid
SUPERDONGLE_KEY seems to be valid
CMLA_KEY seems to be valid
WMDRM_PD seems to be valid
SECURITY_TEST failed!
how to solve this problem ?
1.
First of all u need good pm with SX4
( do SX4/super SX4 after that pm1 and pm309 )
2.
if not solved than
check CCC and HWC certificates
How to repair CCC and HWC certificates ?
backup RPL than open it in notepad
there u will see NPC data after that CCC data and HWC data
just replace CCC and HWC data with manole's uploaded clone RPL's ( of same model )
http://rapidshare.com/files/34542441...e_by_MxKey.zip
http://www.mediafire.com/file/2hijdm...e_by_MxKey.zip
http://www.4shared.com/file/21610198...thout_NPC.html
http://www.megaupload.com/?d=2MSDVYSY
3.
if still not solved than
recover certificates ( go to service --> than imei & security --> than imei rebuild --> recover cert BUTTON )
4.
if still same than
Repair SL
REPAIR SD
SUPER SD AUTH
write PM1 and PM309
5.
if still same than
make RPL backup
full erase
than flash
than rpl
than Repair SL
than SD repair
than super AUTH
than PM
6.
after all these steps if still same than i am here for don't worry
__________________________________________________ ____________
FOR SL3 LIKE 5130 , 6700c ,.................
1.
SIMLOCK invalid
Block1 : open
Block 2 pen
Block 3 : open
in this case just do SX4 and than pm1 and pm309
2.
SIMLOCK invalid
SL data corrupted
in this case u need Nokia RPL ( not supported by MXkey yet )
__________________________________________________ _______________________
PM FILES OF BB5 : just download them from this link and enjoy
http://www.megaupload.com/?d=290ZML6M
The Following 249 Users Say Thank You to hasnain For This Useful Post:
Old 03-08-2010, 10:22   #2 (permalink)
traxgsm's Avatar
Member: 636518
Thanks Meter: 175
thanks for detailled information...please add here any notepad to edit rpl
The Following 2 Users Say Thank You to traxgsm For This Useful Post:
Old 03-08-2010, 10:31   #3 (permalink)
UNLOCK PARK ® SUPPORT's Avatar
Member: 562024
Sonork: +971506319003
Thanks Meter: 135
1.
SIMLOCK invalid
Block1 : open
Block 2 pen
Block 3 : open
Is it supported..........................
Mahadi
The Following 7 Users Say Thank You to UNLOCK PARK ® SUPPORT For This Useful Post:
Old 03-08-2010, 10:35   #4 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
for example here is N91 RPL
[CERT_PROG_DATA_OUT_CMT]
PRODUCTCODE=0535240
PSN=SFE923985
HWID=0600
NPC_DATA_1=CBFC673F0000415000000000000000000000000 00000000000000000303533353234300000000000
NPC_DATA_2=0000000000000000000000009540E094F57E4F4 44E91100000000000000000001E60010556954951
NPC_DATA_3=7D000BE1A830E4982FFCAC24B2E0D53F2FDDF1F C8E55510130F0D067713524354BDF5CEEEC15EBF9
NPC_DATA_4=F5F70C5E875BE02492D9BF5D000000000000000 000000000000000000200000047534D0000000000
NPC_DATA_5=3385930100725682FFFFFFFFFFFFFFFFFFFFFFF FFFFFFFFFFFFFFFFFFFFFFFFF574C414E5F494400
NPC_DATA_6=C47BBD4E1600000000000000000000000000000 00000000000000000000000005B9323A6550F641F
NPC_DATA_7=26CF5AE822A624C48C0B979D56C491782F7A890 2BEF90054728900F515ED2FCD4B6DAA2058456ADB
NPC_DATA_8=2ADABDF753CBDD8BA42BABCA130FD19EFFCE35E 2449D272CDFD0B2638FEEEDF00C9F44BC7A65AF59
NPC_DATA_9=B82759CE95F1FD496D964329FB6225E6FB4CBEA DAEFF3C61CAE3EE271B9F0BB32EA33B2F6033E8BA
VARIANT_DATA_1=357043A5020041500100000030353335323 430430033E09351F51844E9F43E0074A89A0000000000
VARIANT_DATA_2=080000001F00000000000000000000007B3 37D022930ACC4DDC82B3EEDC90233BC9B241CDFDB6A47
VARIANT_DATA_3=0F992E980F27B455BF41ABDB7AA6A6B5189 A971DB6176506478B9D782E86746804844630BFAFD411
VARIANT_DATA_4=80737EA72B6FD38D94FE39CBBC87C99CFA6 339C4CFF5284F630AFF3BA2FCC0A65FE428C6392A6F00
VARIANT_DATA_5=093D97174DC8FC9B181C048ACBD09139C1B CD20457591E96
CHECKSUM=-1
replace the RED lines with the clone RPL
in SL1 have to replace variant
in SL2 have to replace CCC and HWC
is it ok now sir
thanx
The Following 25 Users Say Thank You to hasnain For This Useful Post:
Old 03-08-2010, 10:47   #5 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
1.
SIMLOCK invalid
Block1 : open
Block 2 pen
Block 3 : open
Mahadi
yes
see locks shown open
than means simlock data not invalid
just software shows u that it is invalid
thanx
The Following 6 Users Say Thank You to hasnain For This Useful Post:
Old 03-08-2010, 11:13   #6 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
SIMLOCK invalid!
SUPERDONGLE_KEY invalid!
- WD timer enabled, phone will reboot itself after 3 min.
SIMLOCK_TEST failed!
SECURITY_TEST passed
SIMLOCK_DATA corrupted!
in such cases
Repair SL ( make simlock rpl option ticked )
than SD repair
than Super Auth
than pm
The Following 22 Users Say Thank You to hasnain For This Useful Post:
Old 03-08-2010, 11:30   #7 (permalink)
GsmEasy's Avatar
Member: 608359
Sonork: 100.1576815
Thanks Meter: 6,678
To Everyone Just post here your success and problems for thanks plz use thanks button
The Following 11 Users Say Thank You to GsmEasy For This Useful Post:
Old 03-08-2010, 11:40   #8 (permalink)
Member: 482670
Thanks Meter: 125
how to open security code on 5800D Xm ?? dct 4 n other bb5 is easy to open ..but this show out no responding
...cant read that code oso.. wat can i do ?
The Following User Says Thank You to Brother Hui For This Useful Post:
Old 03-08-2010, 12:03   #9 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
do reset full factory option
The Following 3 Users Say Thank You to hasnain For This Useful Post:
Old 03-08-2010, 12:04   #10 (permalink)
NawabN Sahoo's Avatar
Member: 687312
Thanks Meter: 290
@hasnain!
Bro thanks a lot after doing many tricks and failing all finally step 3 of your manual could solve my N73 Startup failed Problem and thanks to MX-key team for useful option of
: Recover CERT
WBR
The Following User Says Thank You to NawabN Sahoo For This Useful Post:
Old 03-08-2010, 12:06   #11 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
Originally Posted by NawabN Sahoo View Post
@hasnain!
Bro thanks a lot after doing many tricks and failing all finally step 3 of your manual could solve my N73 Startup failed Problem and thanks to MX-key team for useful option of : Recover CERT
WBR
yes step 3 is ready good option by Mxkey in there software
3.
The Following 2 Users Say Thank You to hasnain For This Useful Post:
Old 03-08-2010, 12:16   #12 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
For SL1 mobile
SIMLOCK seems to be valid
SIMLOCK_TEST passed
Imei net: 359367007671670
Version: SIMLOCK SERVER VERSION 58
Counter: 0/3, 0/10
CONFIG_DATA: FFFFFFFFFFFFFFFF
PROFILE_BITS: FFFFFFFFFFFFFFFF
BLOCK 1: 1=CORRUPTED
a.
First Do
REPAIR SL
b.
if not solved than
Repair SD
Repair SL
Super Auth
pm
c.
1. write full PM from SAME phone model (not care if contains fields 1, 120, 308, 309)
2. make Simlock RPL repair
3. make SX4 Auth then write PM1 and PM309 from SAME phone model
if still same than contact me
always there for u
thanx
The Following 17 Users Say Thank You to hasnain For This Useful Post:
Old 03-08-2010, 12:19   #13 (permalink)
kapilgupta's Avatar
Member: 681945
Thanks Meter: 422
3.
yes mr. husnain's trick is best and tested by me
big thanks to mr. hasnain for shareing....
The Following User Says Thank You to kapilgupta For This Useful Post:
Old 03-08-2010, 12:32   #14 (permalink)
Y.P.Y's Avatar
Member: 1010502
Sonork: whats this?!
Thanks Meter: 316
PRODUCTCODE=0535240
PSN=SFE923985
HWID=0600
CHECKSUM=-1
is it ok now sir
thanx
thats NOT TRUE!
because product code is MISMATCH.
certificate product code must same as npc product code.
The Following 3 Users Say Thank You to Y.P.Y For This Useful Post:
Old 03-08-2010, 12:34   #15 (permalink)
hasnain's Avatar
Member: 265626
Sonork: 100.1591486
Thanks Meter: 2,982
Phone Type: RM-379 (Nokia 7310 Supernova)
SW Version: V 09.40 06-11-08 RM-379 (c) Nokia
Imei plain: 12345610654321-?
Product Code: 0559926
Language Pack:
- not available.
SIMLOCK invalid!
SIMLOCK_TEST passed
TimeStamp: 2008-11-18T09:56:29Z
SW Version: 09.40
Variant Version: 005
ProductProfile: RM379_0559926_09.40_005.spr
Simlock: 0559926_simlock.bin
Imei plain is invalid !!!
in such cases
u could only get mobile out of contact service
but can't repair the imei
after fix it will show u logs like this
e.g,
Phone Type: RM-237 (Nokia 3110c)
SW Version: V 07.21 05-11-08 RM-237 (c) Nokia.
Product Code: 0544343
Language Pack:
- not available.
SIMLOCK_TEST passed
Imei net: 12345610654321?
Version: SIMLOCK SERVER VERSION 63
Provider: Nokia Test, Country: Finland
Counter: 0/3, 0/10
CONFIG_DATA: 2440700000000000
PROFILE_BITS: 0000000000000000
BLOCK 1: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 2: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 3: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 4: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 5: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 6: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
BLOCK 7: 1=OPEN 2=OPEN 3=OPEN 4=OPEN 5=OPEN, DATA=FFFFFF
The Following 13 Users Say Thank You to hasnain For This Useful Post:
N73 security test fail start up fail mobile_mania MXKEY Nokia Flasher and Unlocker (by Alim Hape) 31 03-14-2013 19:33
succes full repair phone startup failed and security test failed jagdish puri MXKEY Nokia Flasher and Unlocker (by Alim Hape) 0 03-12-2010 14:17
Success two security TEST failed but faile in one 5220 FAILE khokonhajigonj MXKEY Nokia Flasher and Unlocker (by Alim Hape) 5 02-09-2010 15:38
3110C security test fail after sd repair now tested ok GSMaxx MXKEY Nokia Flasher and Unlocker (by Alim Hape) 3 02-06-2010 11:19
Please HELP security test -Failed rakishi Universalbox 0 01-18-2007 23:45
Page generated in 0.55333 seconds with 10 queries
