Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Saras Boxes > Twisterflasher
Old 04-03-2005, 08:54   #1 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
Thumbs down SE T630 Problem after Unlock with Twister
Hello
I have There 2 piece of SE T630 ver. R7A011 after Downgrade With Twister On R6C005 Phone dont have acess on Network .... so if somebodey have some expirience please help .....
I try to Flash New AVR+ARM+GDFS same try Other ver. soft but same IMEI is OK ......
REgrads
mario
Old 04-03-2005, 10:19   #2 (permalink)
twisterfan's Avatar
Member: 53791
Thanks Meter: 17
@Jankovic
Did you untick "protect SA" ?
If not then it will not flash all of the GDFS area ..
Dunno if it will help but it is worth a try.
PS. If you flash without protecting SA please remember to give the phone it's own serial back using "init secblk"
Twisterfan
Old 04-03-2005, 11:23   #3 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
Cool Hi
Originally Posted by twisterfan
@Jankovic
Twisterfan
Hello
I Untick Protect SA and after that i use "init secblk" but same
Thanx
Mario
Old 04-03-2005, 11:31   #4 (permalink)
twisterfan's Avatar
Member: 53791
Thanks Meter: 17
@Jankovich
Weird...
Only thing i can think of is if they for example changed the RX/TX chip to a new kind that is only supported by R7 software..
Have seen sometimes in Nokia that they say that from a certain hardware revision you must use at least a certain software version because they had changed to a new chip or display that needed a "driver" only found from a certain software version ...
Have never had a R7 phone in my hands but what was the reason to downgrade ?? (Is it not possible to unlock phones with software R7 ?)
Twisterfan
Old 04-03-2005, 17:22   #5 (permalink)
Member: 34125
Thanks Meter: 4
These is software problem....100% because the new T630 PCB ic like PA is different
with old one, try to get a new file in UFSX site..maay be it can help..
I saw someone using Tornado to solve it, but they not telling me what files to flash.
Old 04-03-2005, 18:19   #6 (permalink)
Member: 86213
well. i had a few t630 here with r7. just used td and flashed with r6c. worked ok. then i upgraded to r7 and worked even better; hehe seems that td is still the best tool for old semc.
br fedjak
Old 04-03-2005, 23:55   #7 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
Cool Hey
Hello
Thanx For Quick Answer And Explanation I Unlock xxxxxx Piece Of R7 With This Flash and on this way Without any Problem But I dont Know What Happend now All is Same Same Box PC Cable just Other Phones
I little Confused dont have Idea any More ....
Regrads
mario
Old 04-04-2005, 00:05   #8 (permalink)
Member: 67805
Thanks Meter: 364
Simple solution, find someone with best tool called Cruiser/Fighter and flash phone with version R7A011
wbr.
Old 04-04-2005, 00:23   #9 (permalink)
Spalato's Avatar
Member: 2236
Thanks Meter: 58
wbr.
Cruiser and Fighter can not repair that phone... tested...
Old 04-04-2005, 00:33   #10 (permalink)
Member: 67805
Thanks Meter: 364
Hmmmm
But can make criuiser this damage with network or only can't repair after another software?
Did work old solution for this phone with UFS and TP?
wbr.
Old 04-04-2005, 01:41   #11 (permalink)
Jankovic's Avatar
Member: 38150
Sonork: 100.1611516
Thanks Meter: 143
Cool Hey
Hello Spalato
Do You Have repair Solution or ???????
Can You share with me and Other member with same Problem
REgrads
mario
Old 04-04-2005, 05:56   #12 (permalink)
twisterfan's Avatar
Member: 53791
Thanks Meter: 17
Hi
Can someone please tell me why it is that Twister cannot flash version R7 ??
Twisterfan
Old 04-05-2005, 19:10   #13 (permalink)
Member: 3508
Thanks Meter: 71
wbr.
I tried to flash it with Cruiser to version R7A011, and phone have the same problem!!
Tried to write new Security area, gdfs, and default calibration values but problem is the same!
Any idea what to do!?
Old 04-10-2005, 14:58   #14 (permalink)
jusluke's Avatar
Member: 26867
Thanks Meter: 3
maybe refurbished unit or converted t637 in your t630. try fullflash and check if you have 1800mhz in your area.
Old 04-10-2005, 17:09   #15 (permalink)
Member: 3508
Thanks Meter: 71
No, phone is original T630, it is buyed from provider in my country, and other friend had same problem, he downgraded phone with DIV and phone lost network!! As fas as I know you must not flash it!! Only solution for now is to unlock it with Cruiser without unlocking RSA - flashing!!
I still didn't manage to repair that phones!!
E820 dead after unlock with twister! mayer Twisterflasher 5 02-03-2011 12:08
SE G900 problem after flash with SEUS AOYUE Cruiser Suite 1 01-20-2010 14:12
SE K550i problem after unlock jammi Sony Ericsson 5 02-22-2008 13:55
t191 locked again after unlock with twister ? TRABEL Twisterflasher 2 12-17-2005 11:32
Nokia 6600 Bluettoh Problem After Flashing With Twister jkgohil WD2 & APE (Symbian Phones) 3 12-23-2004 12:49
Page generated in 0.24145 seconds with 9 queries
