06-14-2005, 06:21 | #1 (permalink) |
Junior Member Join Date: May 2005 Location: Liverpool, England Age: 45
Member: 145690 Status: Offline Thanks Meter: 0 | Patching the Widcomm stack at install time without safe mode can be done I have tested this using the EPOX 1.2.4.10 drivers for my non-Epox dongle and it appears to work. In the install folder, you will find a file called SVCPACK.INI. This file can be configured to copy additional files to various locations, and also run applications during install. I've put together a demo here, you'll need to rename it from SVCPACK.TXT to SVCPACK.INI and copy it, along with the cracked files into the SVCPACK folder. Unfortunately Widcomm 4 doesn't work on my laptop so I've not been able to test it. I'm sure someone can give it a try. The ini file is well documented and the installer is the same. |
06-16-2005, 04:41 | #2 (permalink) |
Junior Member Join Date: Jun 2005 Age: 33
Member: 153769 Status: Offline Thanks Meter: 0 | Okay trying now so just to confirm, I replace it before I install in the folder created after file extraction. Also how do I know it doesnt work? Will it reject the file exchange? |
06-16-2005, 14:31 | #3 (permalink) |
Member: 153628 Status: Offline Thanks Meter: 1 | Okay, it works well. I did mine on Widcomm 4 version. The only extension to make in the file is that all the numbers under the "SourcenameX" (X is 1,2,3,...) must be the same in each category (see example below). So this mean you can put firmware upgrade file here too. This is a part of them took from Hp/Compaq SVCPACK on forcing firmware upgrade after installation of Widcomm... SourceName2=hp-t19a.dfu DestinationName2=frmupgr.dfu DestinationFolder2=1 DestinationSubFolder2=bin OS2=15 CopyOnlyIfExists2=Y |
06-17-2005, 16:32 | #4 (permalink) | |
Freak Poster Join Date: Sep 2003
Member: 39443 Status: Offline Thanks Meter: 2 | https://forum.gsmhosting.com/vbb/1097243-post.html Quote:
06-18-2005, 14:38 | #5 (permalink) |
Member: 154303 Status: Offline Thanks Meter: 0 | This simpler method did work for me initially but not after I upgraded to Widcomm 4.01.1500. Now I have a process btwdins.exe that seems to shut but restarts before I can copy wbtapi.dll although all the other files can be copied after shutting the two processes as you describe. |
06-18-2005, 15:27 | #6 (permalink) |
Member: 153628 Status: Offline Thanks Meter: 1 | Ok, let try this one out again. I simply just find the way to attach file here Then, you can get the modified file without effort Here the instruction.... after you extract Widcomm download file to new sub-directory (Mostly Rar can handle that). Get into SVCPACK subdirectory in the installation directory... copy this attacthment file (SVCPACK.txt), change the extension to .INI and all the extracted patched files there... Finally... do installaion... This method is work on any version since it contain the same SVCPACK.... I did mine and every easy to install... not need to kill process... safe mode... and you can do install anytime... |
06-22-2005, 01:37 | #7 (permalink) | |
Member: 145690 Status: Offline Thanks Meter: 0 | Quote:
Also if the people who do the cracks include an SVCPACK.INI file, then it's simply a case of unraring to the correct place and installing as usual. It's also something you can burn to CD and give to friends and not have them phone you up when they can't figure out how to apply the crack MrAnthonyWong: This is a modification to the Widcomm installer, so yes you extract your cracked files into the SVCPACK folder and put the SVCPACK.INI file there too, then you run the installer as normal Satein: Glad you've got it working for the newer versions. Hopefully it is useful for people. | |
06-22-2005, 11:38 | #8 (permalink) | |
Insane Poster Join Date: Jun 2005 Age: 42
Member: 151745 Status: Offline Thanks Meter: 1 | Quote:
THNKYOU FOR UR SUGGESTION. I M NEW TO SUCH THINGS SO KINDLY REPLY MY MESSAGE.IN UR POST YOU HAVE MENTIONEDV RENAMING OF 4 FILES TO .original PLZ TELL ME WHICH ARE THOSE FILES WHERE ARE THEY LOCATED. THANK U ONCE AGAIN | |
06-22-2005, 15:45 | #9 (permalink) | |
Member: 153628 Status: Offline Thanks Meter: 1 | Quote:
Hope this help | |
06-22-2005, 22:53 | #10 (permalink) |
Freak Poster Join Date: Jan 2002 Location: Iloilo City, The Philippines
Member: 8396 Status: Offline Thanks Meter: 2 | The svcpack.ini works well. Saves the effort of manually rebooting to safe mode and do all patching. For now,it's just one boot and all is good to go. |
06-24-2005, 11:54 | #12 (permalink) | |
I HAVE TRIED UR METHOD BUT I M STILL HAVING LICENSE.DAT PROBLAM PLEASE HELP BECAUSE NOTHING IS WORKING YAAR PLZZZZZZ HELP | |
06-24-2005, 17:18 | #13 (permalink) | |
Hope this help.... | |
06-28-2005, 10:58 | #14 (permalink) | |
no i didn't get it while instalation, i have two patched BTTray.exe & wbtapi.dll patched by Billyx I have done everything plz help one more important thing i think its important to tell u that my bluetooth hardware is with CSR CHIP & it isntal driver CSR bluetooth drivers | |
How can be done the test point in k800 | mimounts | DreamBox | 5 | 11-11-2009 04:12 |
N95 flash ok but black screnn , test mode and local mode can't be done | ali_alper | Nokia Base Band 5 ( BB-5 ) | 0 | 05-28-2007 13:59 |
Language changing in ppm file can be done by ppm splitter? | Abe | Nokia Legacy Phones ( DCT-1 ,2 ,3 ,L ) | 0 | 03-28-2002 10:47 |
t28 poor signal - what can be done? | sat | Sony Ericsson Hardware Repair | 5 | 11-22-2001 12:14 |
What can be done about cheaters | g2000 | The Market Feed Back | 0 | 12-11-2000 15:36 |
