Go Back   GSM-Forum > Product Support Sections > No More Supported Solutions (Dead Products) > No More Supported H/W Products > Ultima Box Light
Old 01-23-2007, 08:51   #1 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
L6 dead
i cant flash it always showing error..
Split input file in codegroups:
Processed ok
Establish connection to handset
FLASH Interface established ok
Sending RAMDLD to handset
RAMDLD started ok in handset
Erase flash...
Err no: 01120004
Err no: 01240004
please help!
Old 01-23-2007, 09:18   #2 (permalink)
UBL Support's Avatar
Member: 420649
Thanks Meter: 414
In what state is L6 now and what bootloader version have now?
What exactly file you try to flash?
You use a full charged battery?
Old 01-23-2007, 09:39   #3 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
L6 is totally dead now..i dont know what's the BL version..
when i try to flash the BL,the UBL soft gets hang always..
Old 01-23-2007, 10:03   #4 (permalink)
Amit Tank's Avatar
Member: 219831
Thanks Meter: 104
Processed ok
Erase flash...
Err no: 01120004
Err no: 01240004
please help!
hi
if show b l then
try
dont use tp, direct flash.
may be help u
Amit Tank
Old 01-23-2007, 10:28   #5 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
Originally Posted by Amit Tank View Post
hi
if show b l then
try
may be help u
Amit Tank
mate i'm not using TP..
but the soft always ask me to disconnect the TP..
thats why im wondering..
Old 01-23-2007, 10:29   #6 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
sometimes show on lcd "critical error 84"
Old 01-23-2007, 15:53   #7 (permalink)
ricson's Avatar
Member: 18329
Thanks Meter: 144
can u post a link where to get latest RSD also have a dead L6
Old 01-23-2007, 18:31   #8 (permalink)
Registered User
Member: 274461
Thanks Meter: 17
i have the rsd.. i can send u in msn
Old 01-24-2007, 03:30   #9 (permalink)
fonefun's Avatar
Member: 26187
Sonork: 100:77458
Thanks Meter: 290
this is so easy to fix guys
the problem normally happens at the first take battery out an d re-insert
solution
close and re-launch software
select correct model
take battery out of phone and re insert
connect to box
you will see phone connect in boot mode (its still blank, not dead)
press "unlock" button
let process finish
take out battery and cable
insert battery and connect to cable
now press leave blank and follow prompts
job done
Old 01-24-2007, 06:14   #10 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
solution
connect to box
let process finish
job done
i did this..
the results..the UBL soft always hang..
help pleasse UBL team..
Old 01-25-2007, 14:36   #11 (permalink)
Member: 95745
Thanks Meter: 10
3stan gsm if your infinity box and ubl both are installedin pc then deactiva infinity
i did this..
3stan gsm if your infinity box and ubl both are installedin pc then deactivate infinity software. after deactive infinity open ubl soft. your soft will not be hang.
shahi
Old 01-26-2007, 09:50   #12 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
shahi
thanks mate, but i dont have infinity box..
maybe this is a bug,please UBL team,take a look at this..
Old 01-26-2007, 12:13   #13 (permalink)
Member: 420649
Thanks Meter: 414
i did this..
Your phone PDS is damaged and for that reason software hangs.
If you will plug out USB cable from phone when software hanges you will receive error numbers.
Press Repair now when phone is in Blank mode.
After that flash phone with 1FF file.
Old 01-27-2007, 06:38   #14 (permalink)
3stanGsm's Avatar
Member: 331390
Thanks Meter: 434
Read handset bootcore version
Bootcore version on handset: 0000
ERROR: Not supported Model/Bootloader!
i got this error when i try to enter blank..
what's next?
Old 01-27-2007, 07:21   #15 (permalink)
muksforu's Avatar
Member: 50805
Thanks Meter: 101
what's next?
ur problem is same like me.
1st make tp and run ubl then click on repair tab
2nd disconnect phone put in bootmode now see what
my l6 bootloader 0000 is repair with 08.d0
then do flash 1ff
wbr
L6 Dead after Unlocking with Smart Moto " PHONE CODE SIG ERROR " Aamir_Zia Smart-Clip 53 06-13-2006 19:27
L6 dead trying to unlock SilentKiller Smart-Clip 12 02-28-2006 02:31
L6 Dead กกก I Need Flash !!! Irix Smart-Clip 1 01-27-2006 13:29
L6 dead after Unlock Ran Smart-Clip 0 01-05-2006 01:58
L6 dead (gsmserver help) doudiunlocker Smart-Clip 4 12-30-2005 02:22
Page generated in 0.23751 seconds with 10 queries
