Old 02-12-2007, 04:57   #1 (permalink)
Member: 310194
Sonork: techsolutiongoa
Thanks Meter: 5
N70 White Screen
Hi, I hv this N70 which was dropped and the screen had cracked. Now I changed the screen but phone doesn't boot up and only the screen lights up( white screen). The phone doesn't switch off either. ny solution guys?????????? wil bw very grateful for ur advice and help
Old 02-12-2007, 05:03   #2 (permalink)
MARCO_LEI24's Avatar
Member: 437292
Sonork: 100.1583093
Thanks Meter: 272
flash your phone with the latest firmware using jaf or hwk
Old 02-12-2007, 05:11   #3 (permalink)
ashrafcell's Avatar
Member: 232622
Thanks Meter: 17
chaige disply ic 100% ok
Old 02-12-2007, 11:59   #4 (permalink)
Member: 200653
Thanks Meter: 719
N70 Lcd white
N70 Lcd white Problem 100%
Old 02-12-2007, 14:34   #5 (permalink)
Member: 139043
Thanks Meter: 27
Have you tried it before? I dont think it will work because the phone lcd is just white and it does not access to the main menu at all. it cannot make any call at all.
Old 02-12-2007, 15:33   #6 (permalink)
Member: 44950
Thanks Meter: 10
well isolating the problem is directly telling the display ic but still other info will help the case. if the phone can call emergency call it mean the lcd and the display properties is concern. but if can't make a call it means that the phone is having a problem on its software, omap, ram, rap3g.......
The Following User Says Thank You to robz For This Useful Post:
Old 02-12-2007, 15:39   #7 (permalink)
Member: 139043
Thanks Meter: 27
This is a good answer but how do we know exactly what is faulty How can we troubleshoot it??
Old 02-12-2007, 16:19   #8 (permalink)
Member: 44950
Thanks Meter: 10
base on the history the unit is dropped change the lcd but the phone didn't response on switching off. it means that the programs is not responding so the phone must need to test it capability to comunicate with the computer and how responsive it is. need to read the phone with jaf to assest the damage and certain information neede...
Old 02-14-2007, 01:41   #9 (permalink)
Member: 310194
Thanks Meter: 5
Yeh Robz and u guys are right da phone doesn't respond to any software, so I think changing the display IC wont help. seems to me that some BGA IC has cracked or damaged but the question is which one??????????? I hv no clue????? can someone help
Old 02-14-2007, 01:52   #10 (permalink)
Lhick's Avatar
Member: 333359
Thanks Meter: 91
Display signal comes from OMAP, if board is busted/bent better quit.
Old 02-14-2007, 14:25   #11 (permalink)
Member: 139043
Thanks Meter: 27
It seems most likely its the rap3g is the problem. I will get to it and will post reply tommorow.
Old 02-14-2007, 15:05   #12 (permalink)
..::Mr_Fone::..'s Avatar
Member: 364745
Thanks Meter: 719
Hi Everbody Same Pro My N70 And Chang Dispaly Ic And Ok 100% .i Think Chaneg Dispaly Ic And Enjoing .(br)
..::mr Fone::..
Old 02-14-2007, 18:48   #13 (permalink)
Member: 101007
Thanks Meter: 27
the post by h.com should be the prob... most of n70
white screen tat cant access to menu cause by tis 10pin diode prob...in tis
case changing display diode wont help... especially cant read by any s/w... i've solve lot of them but not 100%
cuz till now i still got 2 of them inside my drawer waititng for new solution..
reheat the diode and read wit jaf or ufsx or any tools for nk see whats happen.. if can be read u should kno wat to do replace the diode ..
regards
Old 02-16-2007, 09:22   #14 (permalink)
puneet14884's Avatar
Member: 399779
Thanks Meter: 125
Old 02-16-2007, 20:00   #15 (permalink)
Member: 17243
Thanks Meter: 13
@ puneet14884
your solution is working , on liquid damege or droped phones those showing white light ( if its Vcore ic dameged ).if it is same problem after shorting its OMAP is dameged .It is intersting that most of phones working with out any problem , if we removed Vcore ic and short ( make jumper ) it , i tried it on 7610 , 6230 phones , not same different jumper for each phone . ....
N70 white screen plague roglio Nokia Base Band 5 ( BB-5 ) 20 04-04-2007 17:20
Nokia N70 white screen after flash buegi Nokia Base Band 5 ( BB-5 ) 2 10-10-2006 14:45
N70 White Screen chardex Nokia Hardware & Hardware Repair 13 09-19-2006 11:15
Nokia N70 White Screen fusion007 Universalbox 4 07-13-2006 22:35
n70 white screen >>>>>error djyash MT-BOX 3 07-04-2006 10:32
Page generated in 0.28435 seconds with 10 queries
