11-02-2007, 08:52 | #216 (permalink) | ||||||
Freak Poster Join Date: Jul 2005 Location: In Front All of You Guys
Member: 166078 Status: Offline Thanks Meter: 21 | Solved The Problem!!!!!!!!! Quote:
1. Uninstall Old HWK Suite. 2. Install HWK_Support_Suite_Setup_v02.06.000. 3. Run HWK_Support_Suite_Setup_v02.06.000. 4. Click on Next on main window of HWK_Support_Suite_Setup_v02.06.000 (Anactive Internet Connection is Required). 5. When HWK_Support_Suite_Setup_v02.06.000 finishes its process then leave it alone, dont click on "Start HWK update" at this time. 6. Go to C:\Windows\Prefetch and delete all files inside the Prefetch folder (for step 6 you can do it or not no problem). 7. Now Install HWK_Suite_Setup_v02.06.000. 8. This time hopefully HWK_Suite_Setup_v02.06.000 will go smoothly without any error. 9. When HWK_Suite_Setup_v02.06.000 finishes its instllation then go back to HWK_Support_Suite_Setup_v02.06.000 already opened window and click on Quit. 10. Now new setup should be insalled successfully. At this time you may use any of HWK modules without any error. 11. Uninstall old usb driver restart your windows xp sp2 after that put or find new usb driver for your box and run update client to update your box until update succesfully completted. NB: AFTER COMPLETE INSTALL HWK_Support_Suite_Setup_v02.06.000 AND HWK_Suite_Setup_v02.06.000 finishes without any error of HWK modules BEFORE YOU CONNECT TO "Official HWK Support Area" YOU TRY TO RUN "SeDBx" FIRST AND CONNECT YOUR BOX WITHOUT ANY ERROR AGAIN AND DON`T CLOSE IT. NOW RUN "Official HWK Support Area" THAT WILL DETECTED YOUR HWK ORI ID AND YOU CAN ENTER SUPPORT AREA WITHOUT PROBLEM OR DATA ERROR. GO SUPPORT OR FOR LOGIN "Official HWK Support Area" OR http://sarunasoftware.com/supportlogin.html (INTERNET EXPLORER ONLY). TESTED 100% BY ME. THAX`S TO HWK TEAM. BRAVOO!!!! B.R "DOGLAG" | ||||||
11-03-2007, 18:33 | #219 (permalink) |
No Life Poster Join Date: Sep 2005 Location: INDONESIA Age: 38
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | still cant solved my problem... always says "cannot continue report in forum" bwahhhhhhhhhhh................... why this should take our time?? can't HWK make some update easily??? br, kevin168 |
11-03-2007, 21:11 | #220 (permalink) | |
No Life Poster Join Date: Mar 2003 Location: Romania Brasov Age: 46
Member: 25136 Status: Offline Sonork: 1591036 Thanks Meter: 54 | Quote:
run HWK_Suite_Setup_v02.06.000.exe | |
11-03-2007, 21:47 | #221 (permalink) |
Member: 183921 Status: Offline Sonork: 100.1590817 Thanks Meter: 205 | i know and already try all mentioned here before... but, just all try to remove HWK suite, after that Install it again, and tell me when u succes doin that.. coz, i got no success at all, please ODIA, make patch or usefull solution for this.. br, kevin168 |
11-06-2007, 01:19 | #224 (permalink) |
Insane Poster Join Date: Oct 2006
Member: 370047 Status: Offline Thanks Meter: 3 | help for HWK hi im able to update my new ori HWK but im unable to log in to the support it say that my HID is not activated (ACCESS VIOLATION) help pls i have try to contact my reseller but keep tell me is my installation problem. but im a HWK user is just that my old HWK die |
11-06-2007, 16:55 | #225 (permalink) |
No Life Poster Join Date: Apr 2005 Location: india
Member: 135945 Status: Offline Thanks Meter: 85 | @suport Hi! i need to know the password for this file X530_MDL_V001.zip which i downloaded from the official support area? can u please inform me! WBR ReyTech. |
lg brand supported in hwk support area not found in lg software | bkhatti | HWK | 4 | 12-21-2008 17:49 |
Official HWK Support Area Download Problem | .:Towhid:. | HWK | 0 | 04-25-2008 12:01 |
Official HWK Support Area is dawn "closed" | sky178 | HWK | 2 | 03-18-2008 06:48 |
Official HWK Support Area -v- WWW.UFSXHWK.COM | tomtoolbox | HWK | 1 | 03-17-2008 19:22 |
Free Official HWK Support Area | ptnetwork | HWK | 11 | 02-15-2008 10:54 |
