Old 12-22-2008, 17:17   #1 (permalink)
Member: 453862
Thanks Meter: 53
Plz help me for new 1200
HI GUYS PLZ ANY BODY HELP ME FOR THIS NOKIA 1200
TODAY CUSTOMER PURCHASED THAT MOBILE AND ASK ME TO INSTALL
URDU LANGUAGE IN IT I FLASHED IT WITH 4.11 AND BY MISTAKE I DO NOT NOTE PREVIOUS VERSION OF FLASH FILE
I USE HWK 2.0.8
WHEN I FLASHED IT SHOW
CNT Flashing Completed, Time: 00:01
Extracting Contents Package ...
Init Local Mode Failed
Contents Package Extracting Failed:
Process Failed, Repowering Mobile
I DOWNLOAD UP VERSION (LATEST VERSION) AND TRY TO FLASH IT IN HWK AND JAF BUT FAILED WHEN INSERT BATT AND POWER ON IT SHOW CONTACT SERVICE
WHEN ATTACHED TO FLASHER IT SHOW LOCAL MODE BUT NO UI SETTING
AND NO INFORMATION .WHEN FLASHED IT HAVE LOCAL MODE BUT CONTENT FAIL.AT LAST I OPENED THE MOBILE AND FLASH CHIP IS STRANGE TO ME (SEE PIC) IT IS CZ WARRENTED MOBILE
PLZ GUIDE ME WHAT TO DO.I WILL BE THANKFUL TO YOU
COMPLETE LOGS ARE HERE
1st Boot: Ok, DCT4, UPP: 2292 [Rh-99] [2.0.8.0]
2nd Boot: u3_2nd.fia, Ver: 4.76.0
Fl0: 0x01000000-0x013FFFFF,00898872,Int 28F320W18
Algorithm: u3_intel.fia, Ver: 4.76.0
Algorithm Ok, MSID: 84C90C33E293F6D5C8E9EC9080
Decoded MSID: 3E4EBAE9-001713A1-AA000000
Encoded FAID: 2A8E238E-643C5C4E-4E8426E7
IMAGE: rh99_05.710
Area1: 0x01000000-0x0100FFFF Erasure Skipped
Area2: 0x01010000-0x013AFFFF Erasure Skipped
Area3: 0x013B0000-0x013EFFFF Erasure Skipped
Area4: 0x017C0000-0x017EFFFF Out of Chip Bounds
Area5: 0x01FC0000-0x01FEFFFF Out of Chip Bounds
MCU Flashing Completed, Time: 00:19
IMAGE: rh990_nai5.71ej
Area1: 0x01380000-0x013AFFFF Erased, Time: 00:01
Old 12-22-2008, 17:24   #2 (permalink)
Member: 926493
Sonork: 000001
Thanks Meter: 6
first clean the pcb then erase and full flas u r problem will be slove
Old 12-22-2008, 17:34   #3 (permalink)
Member: 453862
Thanks Meter: 53
Brother it is quit new mobile only two minuts it was opened
why clean ?
I erased full it in jaf and hwk but same it is flash ic pic see it
before it u see in 1200?
Old 12-22-2008, 18:01   #4 (permalink)
Member: 292138
bro first full erase the phone by jaf and flash with the new version file and write with goog pm pro will solve there is no need to cleane the pcb because phone in new
Old 12-22-2008, 18:21   #5 (permalink)
Member: 453862
Thanks Meter: 53
Brother understand after full erase when i flash phone in jaf after writting three files it has local mode on the screen
but no ui setting are appliled and not unlock when press info button it show mobile is not in local mode
Old 12-22-2008, 19:46   #6 (permalink)
Member: 455842
Thanks Meter: 97
chk on easy cable may be it works
Old 12-23-2008, 04:18   #7 (permalink)
Member: 848496
Sonork: 100.1585426
Thanks Meter: 22
check local mode registor
Old 12-23-2008, 07:42   #8 (permalink)
Member: 414225
Thanks Meter: 1
brother
brother try to flash with universal box maybe yur problem solve
Old 01-31-2009, 17:28   #9 (permalink)
Registered User
Member: 473907
Thanks Meter: 63
1ST flash with ub with highest ver. i hope ur prob will be solved
2nd
1 erase
2 flash with highest ver.
3 write pm
4 unlock
5 factory setting
All do with jaf
NOTE: NOT FLASH WITH LOWER VER. UR SET MAY BE DEAD
Old 01-31-2009, 17:39   #10 (permalink)
Member: 774126
Sonork: 100.1645006
Thanks Meter: 42
only soft problem bro,dont even trip. just take your time and before you know it, you will have it back on air. or else try flashing with out cnt file and write good pm then unlock with jaf
Old 01-31-2009, 19:10   #11 (permalink)
Member: 286908
Thanks Meter: 81
your problem will be solved
I USE HWK 2.0.8
IMAGE: rh99_05.710
use only jaf
erase fls, if unable to erase fls then hardware problem (upp,uem,flsh, any one) if erase files
you must select maual flash > use ini
select product > rh 99 - 1200 set ppm lang which you want, then flsh
after flsh > factory set full
write good pm > then unlock
it will be done
Old 02-01-2009, 12:08   #12 (permalink)
Member: 414225
Thanks Meter: 1
bro
brother flash with jaf 1oo% yur problem wll solved try .......
Old 02-01-2009, 15:45   #13 (permalink)
Member: 453862
Thanks Meter: 53
Brothers all you say flash with higher version
one question????
with which version????
This problem solved when i changed the flash chip from a old board
i simply flashed it with hwk and solved.
Now i have 4 more pieces tried all you say
but same.........
if some one have higher version which you say plz upload here
i have 5.71 for 1200
any update file???? plz share
also for
1208
1209
1650
i will be thankful to you
Old 02-01-2009, 15:50   #14 (permalink)
Member: 365744
Thanks Meter: 54
Arrow jst use JAF
I USE HWK 2.0.8
IMAGE: rh99_05.710
bro
jst use JAF and write a good pm .thats why JAF was made to work on small problems like the one u have .
enjoy
Br.T
The Following User Says Thank You to Temani For This Useful Post:
Old 02-01-2009, 15:55   #15 (permalink)
janar_jk's Avatar
Member: 154612
Thanks Meter: 824
Problem is simple u just downgraded the phone, i think ur problems will be solved by flashing the phone with versin 5.80 (Which is latest available)
Br Janar
one question????
but same.........
also for
1208
1209
1650
hi plz help me im new abi.m MXKEY Nokia Flasher and Unlocker (by Alim Hape) 2 03-30-2010 06:43
plz help me to flashing 1200 abousalma007 Nokia Hardware & Hardware Repair 3 08-09-2009 14:44
plz help me in nokia 1200 skyhawk78 Nokia Digital Core Technology 4 ( DCT-4 ) 4 11-20-2008 14:26
plz help me i need 1200 pm file mangaraj1988 Nokia Digital Core Technology 4 ( DCT-4 ) 1 07-19-2008 18:34
plz help me for my new v-power amiriratel VygisToolbox 1 05-07-2007 20:50
Page generated in 0.25800 seconds with 10 queries
