03-08-2009, 06:42 | #1 (permalink) |
No Life Poster Join Date: Dec 2007 Location: PAKISTAN
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | lg boot problem give proper mothed with details i try many time but cannot boot change cable and change mobile but same please help here is log If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! If used non Auto-Ignition cable, press Power-On button No Response from Target ShutDown Done, Wait for Product Start-Up ! this error show in all mobile |
03-09-2009, 13:48 | #4 (permalink) | ||
Member: 654997 Status: Offline Sonork: 1613804(Don't Spam Plz) Thanks Meter: 4,073 | Quote:
thanks for reply i also change cable many time and mobile but same | ||
03-10-2009, 17:05 | #5 (permalink) |
No Life Poster Join Date: May 2008 Location: NC, USA Age: 36
Member: 779665 Status: Offline Sonork: 100.1581784 Thanks Meter: 492 | Mate when you select KG110 you can see in front of tab 18 pin cable or 24 pin cable. make sure you have both working cable for kG110 you have to use 18 pin cable which is simply LG 8110 Cable. 1. select model 2. connect with power of phone 3 press boot & Shortly press power on Button 4. press Unlock 5. GOOD LUCK |
03-11-2009, 07:08 | #7 (permalink) | |
No Life Poster Join Date: Nov 2008 Location: Hate stupidity
Member: 904530 Status: Offline Thanks Meter: 517 | Quote:
schematics can find on support | |
03-11-2009, 07:16 | #8 (permalink) |
No Life Poster Join Date: May 2007 Location: P A K I S T A N
Member: 515406 Status: Offline Sonork: 100.1603457 Thanks Meter: 883 | Cheqthis method b.r use this method 1. Insert Charged batery 2. Use good cable according to phone... 3. Now Press Boot in software 4. If not booting press Power button shortly again and again... here is proof unlocking KG130 http://forum.gsmhosting.com/vbb/show...94#post4231194 CHEQ IT THIS LINKS I HOPE U R CABLE IS PROBLEM 100% CHANGE CABLE OR MODIFY CABLE AND TRY AGAIN U R PROBLEM SOLVED SAQIB- Last edited by GsmMunna; 03-11-2009 at 10:56. |
Lg Kp105 Problem mic plz help | omarfilali | LG | 0 | 03-29-2010 17:02 |
lg ke770 boot problem after backup flash dead | turkcellgsm | Infinity-Box | 3 | 10-29-2008 20:40 |
lg ke770 boot problem | turkcellgsm | LG | 1 | 10-29-2008 09:14 |
LG KG800 Boot problem | algsm2000 | HWK | 1 | 01-28-2008 21:54 |
LG B1300 bootting problem | Porter | LG | 2 | 12-06-2003 11:59 |
